Air Bleed Tuning #457422
09/02/09 09:28 AM
09/02/09 09:28 AM
Out West
408strokerdart Offline OP
Out West
Is it possible to accurately tune air bleeds without a wide band O2?
Re: Air Bleed Tuning [Re: 408strokerdart] #457423
09/02/09 09:43 AM
09/02/09 09:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When you say accurately I would say no... but you could
get it so it runs fine.... with alot of playing
Re: Air Bleed Tuning [Re: 408strokerdart] #457424
09/02/09 09:49 AM
09/02/09 09:49 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Do it all the time If you have to change more than a few steps up or down then your primary jetting is off.We get the carb tuned as close as possible then fine tune at the air bleeds. Assuming you mean tuning for max power and efficiency and not specific a/f ratio.
Re: Air Bleed Tuning [Re: 408strokerdart] #457425
09/02/09 11:30 AM
09/02/09 11:30 AM
Thats the way it had to be done before wide bans where available Jet it until you find the best jetting and then tune the bleeds up and down for the best results
Re: Air Bleed Tuning [Re: Cab_Burge] #457426
09/03/09 12:02 AM
09/03/09 12:02 AM
Out West
Out West
Carb has so many air bleeds that I don't know what they are all for. I think I am getting close on jetting so I was thinking about playing with air bleeds to get a little more. It is a quickfuel dominator with screw in bleeds. How many sizes does it take up or down to see a change?
Re: Air Bleed Tuning [Re: 408strokerdart] #457427
09/03/09 06:26 AM
09/03/09 06:26 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I wouldnt do it.
If you tune it at the track the car can go faster but still have a lean spot somewhere in the fuel curve.
Aldough if you just change them by a very a small amount 0.003" i guess it would be safe.
Re: Air Bleed Tuning [Re: 408strokerdart] #457428
09/03/09 10:48 AM
09/03/09 10:48 AM
I have no idea what your carb will take on the size change to make a noticeable effect, I would start with the idle bleeds and once your happy with that go to the high speed bleeds unless it is a three circuit, if it is a three circuit do the intermeddiate next and then the high speeds. I would call the carb. company and use there suggestiion for your carb. on your car Sometimes the carb is dead on out of the box and sometimes they need tuning
Re: Air Bleed Tuning [Re: Cab_Burge] #457429
09/03/09 11:31 AM
09/03/09 11:31 AM
Out West
Out West
I expect the carb to be off since I got it second hand from dad. It was originally built for his 540 and now it's on my 417 with only main jet changes so far. I might just call them with recommendations.
Re: Air Bleed Tuning [Re: 408strokerdart] #457430
09/03/09 12:30 PM
09/03/09 12:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Brian, Quick Fuel has great customer service .
Re: Air Bleed Tuning [Re: justinp61] #457431
09/03/09 12:51 PM
09/03/09 12:51 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
In my opinion, the only accurate way to fine tune the high speed air bleeds, is on the dyno, anything else is a guess. You really need to be able to see a wideband and the BSFC numbers to do it right. As someone else said, you could have a pretty good hole in the fuel curve and never know it.
Monte
