Re: E body frame rail splash shield
[Re: cataclysm80]
#455400
08/31/09 05:21 PM
08/31/09 05:21 PM
Posts: 821 NW Ohio
6pkaar
NW Ohio
I was wondering why they wouldn't put it on a manual trans car.
I was wondering the same thing. I'm building a 440/6 clone that was an auto and is going to be a 4 speed. From my research it should't be on a 4 speed car......but why?
[Re: 6pkaar]
#455401
08/31/09 06:44 PM
08/31/09 06:44 PM
Challenger 1
Cincinnati, Ohio
I think many were taken off by the first mechanic to work under the car, they are a pain to work around. FWIW they cleanup very nicely with a pressure washer, mine looked worse than yours and this is what it looks like 3 years later sitting in my garage. If you don't mind me asking, How were they held on? Screws or rivets? If it is rivets, is this the right type of rivet? If it is I have plenty I could send you some.
[Re: cataclysm80]
#455403
08/31/09 07:27 PM
08/31/09 07:27 PM
Posts: 3,287 Stroudsburg, PA
Erik
Stroudsburg, PA
I just looked at my car and it is not on it. All of the other splash sheilds are there, but that one is missing. I thought I pulled one off of a 340 4-spd car once. I could be wrong.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
[Re: gtx6970]
#455405
09/01/09 03:45 AM
09/01/09 03:45 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
also used on the E-body rear muffler shields
AND have been found on the 2 smaller ft shields on some cars in place of the rivets
The shields were bolted or riveted. The rivets’ would have been steel and not aluminum. The large shield that Tav originally posted about was on automatic cars only and was considered a starter shield on the drivers side frame rail only.
[Re: MLR426]
#455408
09/01/09 12:24 PM
09/01/09 12:24 PM
360six
1/4-20 w/ 3/8 head should also have an anchor
[Re: 360six]
#455410
09/01/09 08:37 PM
09/01/09 08:37 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
They do, just can't see it in the picture
[Re: gtx6970]
#455411
09/03/09 09:15 AM
09/03/09 09:15 AM
Posts: 4,799 ILL
MLR426
ILL
So I would assume if your using these screws for the front splash shields and heat shields on a 71 e-body you would need (6) OR (8) total ?
logan426
[Re: gtx6970]
#455412
09/03/09 09:36 AM
09/03/09 09:36 AM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Heat shields 3 each Starter splash shield 4 ? K frame shields 2 each Rear axle rebound bumpers 2 each I count 16
CHECK OUT MY NEW WEB SITE !
[Re: anlauto]
#455413
09/03/09 09:48 AM
09/03/09 09:48 AM
Challenger 1
Cincinnati, Ohio
I count 16
Sounds about right.
