OK, how the heck does the stock Hurst shifter handle go into the shifter mechanism on a 68 Road Runner???? No way that thing is going in the shifter port. It looks like all that holds the handle to the shifter mechanism is two tabs that when the handle is pushed in, slip into grooves on the side of the handle mount. Is that it? My question is, how do you slip that handle into the shifter? Everything is brand new rebuilt from Jamie Passon. Since the handle is too big, you think the rechroming may have thickened the base so it won't fit into the slot? You'd think that this really shouldn't be the hardest part of the installation, but cripes. How about just a bolt or something??? HELP!
Cheers
