Gas Ports
#452592
08/28/09 04:22 PM
08/28/09 04:22 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Are they worth any power on N/A engines? Seems I read Reher-Morrison was claiming 30-60hp on N/A engines in the 900-1000hp range....
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Gas Ports
[Re: dthemi]
#452594
08/28/09 04:53 PM
08/28/09 04:53 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
They are worth a good amount of HP when coupled with a vacume pump, and low tension narrow ring pack. You would also want a different bore finish...TotalSeal rings can set you up with what you need there, and then just have the pistons ported. I prefer lateral gas ports most of the time, unless it's a true drag engine that will be freshened often.
Brian Hafliger
Re: Gas Ports
[Re: Brian Hafliger]
#452595
08/28/09 07:23 PM
08/28/09 07:23 PM
Posts: 2,410 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
All things being equal...if you changed nothing but going to the gas ported piston direction how much, if any, would it change the lean/rich tune-up? Sorry for the requested simple answer to a probably complicated question but...guess?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: Gas Ports
#452596
08/28/09 07:24 PM
08/28/09 07:24 PM
Bob_Coomer
Rock Springs
Well my are already purcashed, and they do NOT ave gas ports. Here's the deal, my machinist doesnt have a hone/torque plate for a large bore Hemi. This guy does A1 work, and he is considered a good friend also. I was thinking, that have a so-so hone job, that the gas ports would make up the diff and maybe then some. He explains to me that the Hemi although benefits from a Torque plate, he is confident in making good ring seal without. He said some engine really need them like small block Fords etc.
OK How much does it cost to have a set of piston machined for lateral gas ports? I figure $150 range...but I dont know.
Re: Gas Ports
[Re: dizuster]
#452598
08/28/09 09:04 PM
08/28/09 09:04 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
To be honest, you'd probably be better of spending the money on a torque plate...
10-4, if not, you'll be in my prayers......
Re: Gas Ports
[Re: emarine01]
#452600
08/28/09 09:59 PM
08/28/09 09:59 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
RPM plays a major role in the question of does my engine need gas ported pistons...
I should say piston speed, so if you have alot of stroke (4.500) and plan on 7000rpm, then I would do the gas ports, and change the ring's around. But without the vacume pump, it'll be alot of money spent with little gains.
It all needs to be done to really see the big gains.
Brian Hafliger
