Help me pick a rear-end gear - SB 390 stroker, 28" tire #450518
08/26/09 10:26 AM
08/26/09 10:26 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
My wife's '68 Cuda has been built as a double duty car but since we bought a Challenger a few months ago and I can go borrow my Dad's '66 Cuda to take to cruises we are going to turn her '68 into a 100% drag car.
Here is the info that may be needed to help determine, if you need other details let me know.
Motor:
318 w/ K1 4" crank, eagle H-beams, Ross pistons making 390cid and currently running 11:1 compression
M1 intake
Edelbrock heads OTB (I may get a little porting done and shave the heads to bump up the compression this winter but have to see how the budget for the other project first)
TTI headers
Barry Grant Silver Claw 750 carb
Comp solid .540/.550 252/262@.050 106 lob sep/Centerline
727, Turbo Action reverse VB
Dynamic 9.5 converter stalling to around 4k
28x10 Good Year slicks
Car should weight 3,200lbs after the roll bar is put in, will be removing stock front and back seats and full exhaust system, also remove fuel tank and installing 5 gal fuel cell.
Running Cal-Tracs full system, front/Back shocks, mono-leaf and bars. Braced 8 3/4 housing.
Currently it's ran a best of 11.57 @ 114, 1.587 60' times, with full exhaust and full tank of fuel, I'm currently running a 3.91 gear with 26x10 slicks (17psi), shifting at 5,800 and going through the traps at 5,800.
I think the SB 4" strokers make their power at lower RPMs so we'll probably want to keep the shift points at 6,000 or 6,200 (not sure about that, anyone with input on this would be appreciated)
I'm thinking a 4.30 would be a good gear but it may be too much and may just need a 4.10?
Here is a video of it launching:
http://www.metzinger.oxentenko.com/videos/Abbey.MPG
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: WadeMetzinger] #450519
08/26/09 10:43 AM
08/26/09 10:43 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Honestly, with 11:1 compression and 106º lobe center, I'd run the 3.91s.
I'll bet, it's close.
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: WadeMetzinger] #450520
08/26/09 10:49 AM
08/26/09 10:49 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Nope,...you are right,..... 4.30 is perfect.
I've got 4.30 and 28" tall tire. Trap at 6400rpm with tight converter at 120mph.
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: LAR_414] #450521
08/26/09 10:59 AM
08/26/09 10:59 AM
S/ST 3040 Offline
S/ST 3040  Offline
3300 lb. Duster, Edelbrock heads on stroker SB,
9" J converter, 29" tire and 4.10s........
1.43 60 ft.
10.53 @ 127 MPH
I'd give the 3.91s a shot before I went to the trouble.
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: S/ST 3040] #450522
08/26/09 11:49 AM
08/26/09 11:49 AM
Tulsa, Ok
Tulsa, Ok
I'm running the 3.91 with a 26" tire now and she is shifting at 5,800 and going through the traps a 5,800 so going to 28" and making a little more power I figured the 3.91 wouldn't be enough figure 4.10 or maybe 4.30.
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: WadeMetzinger] #450523
08/26/09 12:00 PM
08/26/09 12:00 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Wade I would try shifting it at 6400/6600. Also a 950HP carb will help it. With a 28" tire a 4.30 should be real close. As stated with a 28" tire and a 430 gear mine went thru at 6300/6400. Jim
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: WadeMetzinger] #450524
08/26/09 12:02 PM
08/26/09 12:02 PM
S/ST 3040 Offline
S/ST 3040  Offline
The engine that was in that Duster is 13:1 comp. 421" 274º @ .050" 108º lobe
separation installed @ 104º and ported heads.....so it's making a little more steam.
......but, OOTB Edelbrocks and 252º @ .050" on 106º lobe centers isn't
going to make power very high anyway.
edit: Maybe I should stick with 340s and 5.57 gears?
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: S/ST 3040] #450525
08/26/09 01:21 PM
08/26/09 01:21 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
If you change from 3.91 to 4.10 you won't even be able to tell the difference.
SRT DEMON ONE SEAT
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: Ron Silva] #450526
08/26/09 02:34 PM
08/26/09 02:34 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I don't think you will see much difference with a gear change. Those 4" strokers with eddie heads make alot of torque. I think 4.3 might gain you a tiny bit of e.t. but it isn't gonna be enough to justify the change.
Also, I disagree about the 950 carb. A 750hp is just fine and not worth $600 to gain half a tenth.
Re: Help me pick a rear-end gear - SB 390 stroker, 28" tire [Re: Ron Silva] #450527
08/26/09 05:17 PM
08/26/09 05:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I run a 28" tire on my Dart. I changed the 3.91s to 4.30s and only picked up a few hundredths. It was all in 60' and carried it all the way through, 1/8 mile. This was when it had the 340 in it. The 408 broke the 4.30s but I did order another set.
