Re: V21 - Performance Hood Treatment
[Re: UCUDANT]
#45042
02/21/11 12:07 PM
02/21/11 12:07 PM
Posts: 9,407 Brantford Ontario
69_SIX_PACK
Brantford Ontario
Here's a closeup of the Performance Hood Paint on my Charger. It is coded for it but this was a mid 1980's repaint...not very correct. Great topic! Dave
[Re: 72 RR DUDE]
#45048
02/21/11 02:06 PM
02/21/11 02:06 PM
Posts: 904 Berwyn, IL
Moparlar
Berwyn, IL
I just went and checked my 72 6pack car and the hood is painted black behind the bubble and the cowl is also painted black inside the outline of the hood gasket. Larry Quote:
This is V21 in 71-72. The Organisol on the louvered area:
71 Road Runners had the grill behind the air grabber bubble black. 72 didn't have it on the grill area behind the air grabber. Anyone who does have one like that it had to slide thru from the factory.V21 in 72 were the long stripes on the hood aside the air grabber bubble.
[Re: NV69B7RR]
#45050
02/22/11 09:36 AM
02/22/11 09:36 AM
Posts: 4,165 Florida
cataclysm80
Can't leave 72 Demons out..
Those Demon stripes look awesome!
Tav
[Re: UCUDANT]
#45052
03/01/11 12:16 AM
03/01/11 12:16 AM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
This thread started in 2007 Lower grille on this car would not have been painted body color from the factory, it should be argent
Good point, but man does it look good!!!
Is that a turbo or supercahrged small block under the hood?!?!?!?!?!
[Re: max]
#45055
08/09/11 11:20 PM
08/09/11 11:20 PM
Posts: 2,648 USA
max
super gas
super gas
USA
on the 70 Challengers, were any of the V21 hood treatments painted on and how many different ways were those hoods blacked out?
I forgot about this post, but here's a photo of the painted treatment on mine.
[Re: CUDAJAS]
#45056
08/09/11 11:24 PM
08/09/11 11:24 PM
Posts: 8,128 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
tease ....you have more right?!?!??!
Looks good!
check the project/survivor section for my post
[Re: 471Magnum]
#45058
08/10/11 12:21 AM
08/10/11 12:21 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Here are the corresponding V25 stripes. Also, V21/V25 stripes were always black.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#45059
08/10/11 08:31 PM
08/10/11 08:31 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
Original paint / owner 71 GTX NOT coded for V21 on the tag....looks like this one slipped through the cracks. I talked to the owner and he confirmed it had always been that way.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: 471Magnum]
#45061
08/10/11 11:09 PM
08/10/11 11:09 PM
Butterscotch71
Lost Title
Lost Title
No slip on that car. Pretty common actually but there has been some debate on 71 N96 Roadrunners and GTXs. Seems pretty much all came with the paint behind the scoop. Since it was bundled with the N96, the extra code on the tag wasn't necessary. Some plants started leaving the code off.
Same thing with the 72 V21/V25 combo. Since V25 stripes always were packaged with V21 stripes, the code was redundant. Whether or not you got a V25 code depends on the plant and broadcast date. V25 is found on all V21 Windsor cars, but few St. Louis cars. Just saves space on the tag.
Actually, my experience with 72s is just the opposite, V21/V25 is coded on St Louis cars, but Winsor cars only had V21 on the tag.
As for 71s, I have to disagree with you on that too. I've been tracking these cars for a long time now. I have very early cars from all plants with N96 and no V21, and I also have very late build cars with V21 and N96 on the tag. There is no coding trend based on build plant either. The car pictured was a two tag car, so there would be no reason to try to save tag space.
