67 b body disc brake upgrade #449085
08/25/09 02:07 PM
08/25/09 02:07 PM
NH
W
watsonpoint Offline OP
W
NH
Hi there. New to the forum. I just bought a 67 satellite with drum brakes. would like to upgrade to front disc brakes using OE parts. would also like to keep my 14" wheels. trying to keep costs down. Any help would be great. Thanks
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449086
08/25/09 02:50 PM
08/25/09 02:50 PM
Virginia
JimG Offline
JimG  Offline
Virginia
You can just follow the Mopar Action guide, and make sure to not to use the larger 11.75" rotors, and you can keep your wheels.
ETA: Opps, here's the link:
http://www.moparaction.com/Tech/archive.html
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449087
08/25/09 04:07 PM
08/25/09 04:07 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I did the conversion on a friend's '67 Coronet using one of the kits of new parts but some parts had to be modified. This was a kit based on the '73-6 A-body. The holes in the spindles didn't line up with the lower ball joints.
On my '64 Dodge, I did the conversion with factory parts off a Dodge Dart and it worked much better, no problems with bolt holes being off. And much cheaper.
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449088
08/25/09 04:41 PM
08/25/09 04:41 PM
minnesota
P
president61 Offline
president61  Offline
P
minnesota
If your car has a 66-69 type sway bar, it will interfere with the brake calipers.
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449089
08/25/09 04:47 PM
08/25/09 04:47 PM
NH
W
W
NH
The car does not have sway bars at this time but I do have a set of lower control arms to add sway bars. IS there way that does not interfere?
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449090
08/25/09 04:55 PM
08/25/09 04:55 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
You have two choices on the caliper interference.
1. Swap spindles/calipers side to side.
2. Run shorter end links.
I like the shorter end links anyway so I'd do that no matter how you mount the calipers.
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449091
08/25/09 05:06 PM
08/25/09 05:06 PM
NH
W
W
NH
Nick, What year was the dart? sliding calipers or pin type calipers?
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449092
08/25/09 05:10 PM
08/25/09 05:10 PM
Andrewh Offline
Andrewh  Offline
m body parts with the 10 inch rotors will let you run the 14's still.
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449093
08/25/09 05:28 PM
08/25/09 05:28 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
1973. Sliding calipers. Any 1973-76 Dart, Valiant, Duster will work. Calipers are easily available as are rotors and pads. Mounted the calipers on the front on the Coronet. Had to mount them on the rear on my '64 because of sway bar clearance. On the new kit it came with an adjustable proportioning valve which I didn't care for. On my '64 I used the Dart one.
Some people mix parts from various vehicles but I wanted it all to be consistent. Plenty of stopping power. I didn't put a booster on my '64 but I may since I tow with it.
Re: 67 b body disc brake upgrade [Re: watsonpoint] #449094
08/25/09 05:52 PM
08/25/09 05:52 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
A-bodies never used the pin-type calipers......
