440 oil pressure to high #448279
08/24/09 07:11 PM
08/24/09 07:11 PM
ILLinois
DartGTS Offline OP
super street
DartGTS  Offline OP
super street
ILLinois
Hello:
I have a fresh built 440 on my test stand that is running 80 lbs, oil pressure.I'm thinking of pulling the spring out if the oil pump and shorting it to drop the pressure. AAnybody have any experience on doing this?
Maynard
Re: 440 oil pressure to high [Re: DartGTS] #448280
08/24/09 07:16 PM
08/24/09 07:16 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
80 psi cold ? .. that is not bad. Is it a new pump? .. try an old well-used spring out of a junker pump.
Re: 440 oil pressure to high [Re: dOc !] #448281
08/24/09 07:29 PM
08/24/09 07:29 PM
MNobody Offline
MNobody  Offline
My 318 runs 85 cold,try lighter oil.
Re: 440 oil pressure to high [Re: MNobody] #448282
08/24/09 08:59 PM
08/24/09 08:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It that is a cold reading it will come down when the engine and oil warms to operating temp.
Re: 440 oil pressure to high [Re: MoparforLife] #448283
08/24/09 11:00 PM
08/24/09 11:00 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Using a Hi volume pump?
Been there....
Switch to a standard one. It is a common myth that a hv pump provides better oiling. Hv pumps were designed to restore pressure in engines with excessive clearances(worn out)
A fresh engine should have a standard volume pump. The proof is your 80 psi.
Stock pumps protected most of these engines for 100000 plus miles, so it should work for you now.
Re: 440 oil pressure to high [Re: dave571] #448284
08/25/09 09:33 AM
08/25/09 09:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Hi volume pumps more oil.Hi pressure adds pressure.My 440 runs 85 cold and proballt 65 hot.Its been like that for at least 10 years.I run hi volume hi pressure.My kids old OE 413 runs 65 cold and 55 hot.His has been like that for 12 years.Rocky
Chrysler Firepower
Re: 440 oil pressure to high [Re: therocks] #448285
08/25/09 02:30 PM
08/25/09 02:30 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
High volume will simply put you against the bypass sooner. The bypass sets the max pressure. Milodon makes and adjustable unit that works very well.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 440 oil pressure to high [Re: therocks] #448286
08/25/09 02:51 PM
08/25/09 02:51 PM
dave571 Offline
dave571  Offline
Yes. and more oil through the same clearance means more pressure. That's why a HV pump improves pressure in old engines.
As mentioned, the spring is what decides the pressure. but ONLY if the pump is capable of moving enough oil to reach the spring pressure.
From my own experience, a HV pump is nothing but a waste on a fresh motor. I had a the relief stick on std pump once. It moved enough oil at just off idle, that it blew the filter up like a balloon. All this, on a motor with .003 main clearance.
I reringed a 400 a few years back, and had teh same issues as the original poster while using an hv pump. Switched to standard, no problems since.
Re: 440 oil pressure to high [Re: dave571] #448287
08/25/09 03:07 PM
08/25/09 03:07 PM
Upper Midwest
Upper Midwest
had the same issues as the original poster while using an hv pump. Switched to standard, no problems since.
The OP has no problem.
Re: 440 oil pressure to high [Re: dave571] #448288
08/25/09 03:26 PM
08/25/09 03:26 PM
My stock rebuild with stock pump and higher pressure spring put out 80 psi cold at idle but would drop to 65-70 warm. No biggie.
Re: 440 oil pressure to high #448289
08/25/09 03:40 PM
08/25/09 03:40 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what bearings are you running in that brand new 440? OEM style half groove bearings? then yea, standard pump is all you need.
but if you're running full groove bearings that oil the journals all the time instead of just half the time, then an HV would help you out.
my big block is running an HV, and it sees 75psi cold at start up, but warm idle it's around 30. at cruise it's 65.
**Photobucket sucks**
