Re: Front framerail replacement supports
[Re: 6pkaar]
#448191
08/25/09 04:36 PM
08/25/09 04:36 PM
Posts: 1,551 Massachusetts
NortheastMopar
Massachusetts
I'd sure like to find plans for a jig like Auto Metal Direct has their Road Runner project on that they show in their ads (except I need an E-body). I've got to replace a frame rail, floor pan and some firewall work too. It sure would be nice just to secure everything in a jig to make sure it is straight and weld away!I asked this same question awhile back and got no responses....I even called AMD about their jig and they said they would have someone call me back, I'm still waiting on that call......
I have to make something and level it to the concrete floor and just don't move it once it is level. I was wanting to know the best point to secure it to, where I will be removing both front frame rails, I surely can't fasten anything to them? I was thinking the door hinge blocks of steel straight to the floor. Ther is really not a lot of weight there.
[Re: NortheastMopar]
#448192
08/25/09 04:43 PM
08/25/09 04:43 PM
Posts: 12,229 Looking for a way out of Middl...
IMGTX
I am interested in this too. I have my plan of supporting my car along the rockers and rear spring mounting points with adjustable screw type jack stands and taking detailed measurements before I cut but I have another car that really isn't too straight to begin with I need to do also. Call this a bump
[Re: IMGTX]
#448193
08/25/09 06:06 PM
08/25/09 06:06 PM
NortheastMopar
Massachusetts
Call this a bump
I was thinking about making up either an angle iron or a U channel which would get drilled and through bolted into the door pillar hinge steel blocks. The bottom would rest on the concrete floor and be shimmed level before work begins. I was thinking about the rockers but the door hing bolts seemed in a better location, easy to bolt into, and right where the car seems to have the most structural integrity.
