7.5 x 14 tire size conversion #447447
08/23/09 07:40 PM
08/23/09 07:40 PM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
What would these two tire sizes convert to by today's tire standards:
7.50 x 14"
9.00 x 14"
Tom
68 Charger
70 Cuda
Re: 7.5 x 14 tire size conversion [Re: FC7cuda] #447448
08/23/09 08:06 PM
08/23/09 08:06 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
best guess with todays tire sizes (78/80 series tires would be closer match height-wise)
7.50 x 14 - 205/75/14
9.00 x 14 - 235/75/14 (good luck finding that much sidewall)
Re: 7.5 x 14 tire size conversion [Re: 6bblgt] #447449
08/24/09 02:29 PM
08/24/09 02:29 PM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
If you know which speedometer pinion and axle you have, you can calculate the correct size tire to keep your odometer accurate. I've written a page about this on the ACCCC web site. See the following page:
ACCCC Tire Upgrades
You could also consider upgrading to 15" tires while you're at it.
Re: 7.5 x 14 tire size conversion [Re: Frank Raso] #447450
08/24/09 02:53 PM
08/24/09 02:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
since this is the second time you have posted this advice .......
I would think the importance of speedometer pinion/rear axle ratio being the "driving" factor in tire selection to be very minimal in the mind of a car enthusiast. Most often the tire/wheel combination is about a "look", changing the speedometer pinion to allow the speedometer to read accurately is a cause of tire selection not the other way around.
BTW - the article is a good read, has good information in it but suggesting this early a-body tire solution is comical. What corner(s) are you going to put this tire on?
Because larger tires are easier to find that smaller, we can replace our orange 17-tooth speedometer pinion with a 16-tooth brown gear. Without changing the 2.93:1 axle gear ratio, our new corrected required tire diameter is 26.64" and would allow us to use a P225/70R15 tire (26.4" calculated static diameter). This would make our odometer record 0.9% more miles than actually driven.
Recalculate your 225/70/15, isn't it closer to 27.4"?
Re: 7.5 x 14 tire size conversion [Re: 6bblgt] #447451
08/24/09 03:39 PM
08/24/09 03:39 PM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
Since FC7cuda inquired about modern equivalent-sized tires, I thought the tires mentioned were listed on his tire placard. Therefore, I thought that he was looking for an OEM-size tire without changing pinions.
Thanks for reading the article and for finding a typo. I meant to write P225/70R14 and I've made that correction.
Since I have a 1965 Barracuda of my own, I just used those tires as an example for the math. I suppose I could have used a later model as an example but I thought that the older cars originally equipped with 13" tires would be more likely to be facing problems finding replacement tires. I'm not sure why this would be comical.
