Re: Cone type 8 1/4 suregrip rebuild
[Re: 340dart4spd ]
#446494
08/22/09 10:58 PM
08/22/09 10:58 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Yes.
There was an article how to do it in a magazine a while ago.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#446495
08/22/09 11:03 PM
08/22/09 11:03 PM
Posts: 28,576 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Yes you machine some off to place the cone further down since it is worn and you shim it. Forgot who the memebr was that sold me the shims. The down fall is as it wears it puts metal into the lube I run the "dana power locks" with clutches but have a few cones did not want to toss them out Even with the clutches ya have to be caefull they sell sets of clutches that are not right as well
[Re: 340SIX]
#446496
08/23/09 04:10 PM
08/23/09 04:10 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
This pertains to the 8 3/4 not the 8 1/4
[Re: maxwedge1]
#446498
08/23/09 05:32 PM
08/23/09 05:32 PM
Posts: 3,344 Central TX
roe
Central TX
alot of dakota trac- locs laying around that will drop in.
Thats what I was thinking but didnt want to say b/c I dont know for sure. IIRC a few other threads have said that the suregrips from these 8-3/8 rears will drop right in. What about the gears themselves, do they transfer over as well?
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: T2R9]
#446501
08/23/09 06:07 PM
08/23/09 06:07 PM
340dart4spd
Parts Problem
Parts Problem
Auburn makes a new unit as well as Mopar Performance, both are priced from $318 for the MP unit on Summit to about $400 for the Auburn unit. With these available why bother trying to fix a worn high millage unit?
Have you run it and know it's bad or just looking to sell it as a "Rebuilt" part?
Hey Jeff... it's my Nephews junk..he is 20 and on a tight budget... I guess we will try to score one out of a Dakota....
[Re: JohnRR]
#446504
08/23/09 07:33 PM
08/23/09 07:33 PM
340dart4spd
Parts Problem
Parts Problem
Then get some steel shimstock and make shims the thickness of what was removed. these shims go between the cone and the spurgear. That will not only restore the spring pressure but also get the gear mesh back to were it should be. Can only really be done once but that basicly doubles the life of the sure grip.
You might want to rethink that , the spiders have already lost their factory preset backlash , taking material off the cone only allows them to move further away from each other , the amount of shim added had nothing to do wit hthe amount taken off the cone , it's the amount WORN off either the cones or the case ... or both ... that needs to be restored wit hthe shim stock .
The cone type setup is a POS design , plain and simple ...
Thanks.. sounds like junk then... LOL
[Re: mod5v]
#446506
08/23/09 08:00 PM
08/23/09 08:00 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
Ring gear diameter makes no difference. You can still machine 0.040" off the base of the cone, then shim the side gears inward to restore the tolerances between the side gear/spider gear teeth.
Dakota (clutch style) track-locks have 29 spline side gears. You probalby need the currently unavailable 27 spline unit.
[Re: DoctorDiff]
#446507
08/23/09 08:15 PM
08/23/09 08:15 PM
340dart4spd
Parts Problem
Parts Problem
so it will work for then.. I will pass it one
