Alternator low out put #446354
08/22/09 05:33 PM
08/22/09 05:33 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
Having some problems with my alternator not putting out enough voltage. Checking the voltage at the alternator B+ terminal and to ground, its only putting out 12.9 volts at idle. At the battery its at about 12.7. That usually increases when I'm on the throttle according to the voltmeter inside the car.
I decided to do the amp gauge by pass to see if that would be any help and it really didn't change anything (but for some reason my AMP gauge is always showing a reading even though its not even connected..hmm).
I have a brand new 65 amp alternator on there so I know its not the alternator itself.
Where should I go from here? How can I test the voltage regulator?
Re: Alternator low out put [Re: chache876] #446355
08/22/09 05:44 PM
08/22/09 05:44 PM
Deleted prior to arrival of politically biased moderators
Re: Alternator low out put #446356
08/22/09 06:05 PM
08/22/09 06:05 PM
Costa Mesa, CA
Costa Mesa, CA
When I said its probably not the alternator because this was happening with the previous alternator as well. I had a broken mounting tab on that one so I decided to replace it hoping thats all it was...
Ok, I have the two wire alternator so I found the correct wire ground wire and grounded that terminal. It increased voltage by about .1-.2 volts at both the alternator B+ post and at the battery.
At the voltage regulator the green wire has power and key on and the blue wire has ground. Should that be right? Are those the same wires that came from the alternator?
Re: Alternator low out put [Re: chache876] #446357
08/22/09 09:46 PM
08/22/09 09:46 PM
No not correct. What car is this in, IE is this stock wiring, or has it been added, or did you just hook it up? That is, DID it work sometime earlier?
Here's a simplified diagram:
Normally the wire which goes from ign to igniton and to one field is blue. This should have 12V from key in "run"
The wire from the other field to the regulator is normally green. The regulator controls the "grounding" so to speak of that wire. It sounds like the blue is not getting 12V
Have you been doing some rewiring, like, changing the igniton?
Re: Alternator low out put [Re: chache876] #446358
08/22/09 10:07 PM
08/22/09 10:07 PM
I'd clean each & every terminal/connection & do 440sixpack's voltage drop tests(esp on the bulkhead/ign sw & blue sense wire circuit) to see if there's a problem. The "blue" constant voltage reg might be a solution and with our alt's having chronic low rpm output's it may not be (totally) fixable without going to a high dollar unit.
Re: Alternator low out put #446359
08/23/09 09:14 PM
08/23/09 09:14 PM
Costa Mesa, CA
Costa Mesa, CA
72 Demon, original /6 car now has a 360. It has a mallory hyfire ignition system (no ballast resistor). I have done some rewiring in that area so its possible I may have hooked them back up wrong. I will do some investigating into that.
Honestly the car has sat so long I can't remember the last time it had a full tank of fresh gas lol.
I'll look into the wiring of the regulator and see whats going on with that, thanks.
Re: Alternator low out put [Re: chache876] #446360
08/23/09 09:46 PM
08/23/09 09:46 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
This may help...
Re: Alternator low out put #446361
08/23/09 11:16 PM
08/23/09 11:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The fact that the alternator is new means nothing It could be defective.
What system you running? 69/ earlier or 70/ later?
That is, one or two push-on field wire connections?
The "jump" past the regulator on a 69/earlier, disconnect the one field wire, and clip a lead to the exposed push on at the alternator, and jumper to the battery (output) stud. This should cause a LOT of output to happen at a fast idle, and the voltage should climb right up.
If you have two field wires (70/later) Pull one off and use a light or meter to determine which wire is hot with ign on. Should be blue. Leave the blue hooked up to the alternator, and ground the other alternator field terminal. It should charge as above.
If that works. check the wiring from there to the regulator. Make sure the regulator is getting ign (switched from key) and is grounded.
If that checks out, probably the regulator
X2
