AMC 360 vs Chrysler 360... are they different? #445129
08/21/09 02:15 PM
08/21/09 02:15 PM
N. Syracuse, NY
'64 Belvedere Offline OP
N. Syracuse, NY
I have a AMC 360 out of a Jeep. Is it different than a Chrysler 360. Do they have different motor mounts or are they the same. Will a Chrysler tranny match up or do you need a AMC tranny.
Re: AMC 360 vs Chrysler 360... are they different? [Re: '64 Belvedere] #445130
08/21/09 02:20 PM
08/21/09 02:20 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Different.
Designed/produced by different companies at different times.
Different mounts, different bellhousing patttern, even though both used Torqueflite transmissions among others.
Re: AMC 360 vs Chrysler 360... are they different? [Re: '64 Belvedere] #445131
08/21/09 02:22 PM
08/21/09 02:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Two totally different engines. I don't think there is any parts interchangablity between the two at all. AMC engines are durable and can be built up the same as anything else.
Not sure on the trans. I know they put torqeflights behind amc's, but I don't know if those had an amc specific bolt pattern.
Re: AMC 360 vs Chrysler 360... are they different? [Re: D_C] #445132
08/21/09 02:24 PM
08/21/09 02:24 PM
N. Syracuse, NY
N. Syracuse, NY
That is what I thought but just wanted to make sure before I sold the motor I have and started looking for a new one.
Re: AMC 360 vs Chrysler 360... are they different? [Re: '64 Belvedere] #445133
08/21/09 02:35 PM
08/21/09 02:35 PM
scratchnfotraction Offline
jeep gran cherokee wagons had amc 360 and are a BB
amc 360 sb are diff also
jeep also has a 304 which look close to a sb mopar..but not the same
Re: AMC 360 vs Chrysler 360... are they different? [Re: scratchnfotraction] #445134
08/21/09 02:54 PM
08/21/09 02:54 PM
D_C Offline
D_C  Offline
Yes, I have two of those AMC 304 V8's, each in CJ-5 Jeeps.
It is the same basic engine block as the AMC 360, just different bore and stroke length.
The entire AMC family of V8 engines, from the 290 CID to the 401 CID, use roughly the same cylinder block.
There was a deck-height change (1966 - 69 = 9.175" versus 9.208" for the 1970 and later engines.)
Re: AMC 360 vs Chrysler 360... are they different? [Re: scratchnfotraction] #445135
08/21/09 03:30 PM
08/21/09 03:30 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
AMC engines were 290, 304, 343, 360, 390, and 401 cubic inches. They shared the same dimensions and all were SMALL BLOCK. No engine hard parts interchange with Mopar engines and the trans bolt pattern is also different.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: AMC 360 vs Chrysler 360... are they different? [Re: Evil Spirit] #445136
08/21/09 04:33 PM
08/21/09 04:33 PM
well the big ol engine in the late 70s mid 80s jeep wagon was no sb and the dizzy was in front like a ferd,IIRC
the amx (like a javlen) had a BB 390 ferd looking engine also,they may be sb to amc...but they are a lot bigger looking to me...sorta like a pontiac mid size block...big but called small
not say I am right,just what I think
I know the 304 v-8 in my 75 scout II is a big azz engine also
Re: AMC 360 vs Chrysler 360... are they different? [Re: scratchnfotraction] #445137
08/21/09 04:37 PM
08/21/09 04:37 PM
I don't know where you got all that but it's not correct
Re: AMC 360 vs Chrysler 360... are they different? [Re: D_C] #445138
08/21/09 04:41 PM
08/21/09 04:41 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
At least AMS put the dizzy in the right spot!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: AMC 360 vs Chrysler 360... are they different? #445139
08/21/09 04:46 PM
08/21/09 04:46 PM
D_C Offline
D_C  Offline
Well, the "BB" part is incorrect,...
But, Chrysler built/used the former AMC V8 engine design and (engine production plant) in their Jeep line, through 1991.
(360 CID)It was the last AMC V8 to be manufactured. It was used exclusively in Jeep J-series Trucks 1970-1987, Jeep Wagoneer models from 1972-84, Cherokee from 1974 to 1983, and Grand Wagoneer from 1984 to 1991 - becoming the last carbureted engine built for car or truck use in North America.
click for AMC V8 Engine Information Link
Re: AMC 360 vs Chrysler 360... are they different? [Re: Rug_Trucker] #445140
08/21/09 04:48 PM
08/21/09 04:48 PM
just going on what I have seen,the jeep and 390 amx car seemed to look big to me but the jeep cj7 304s and matador/javlen car 304s did not seem that big to me
I stand corrected
Re: AMC 360 vs Chrysler 360... are they different? [Re: scratchnfotraction] #445141
08/21/09 06:49 PM
08/21/09 06:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
AMCs did not have big or small block engines since they were all the same basic package with different displacements.
Re: AMC 360 vs Chrysler 360... are they different? [Re: HotRodDave] #445142
08/21/09 06:58 PM
08/21/09 06:58 PM
Rug_Trucker Offline
Rug_Trucker  Offline
AMC built 'SMIG BLOCK" engines......................................
industry term guys....................
Re: AMC 360 vs Chrysler 360... are they different? [Re: '64 Belvedere] #445143
08/21/09 07:58 PM
08/21/09 07:58 PM
Medford OR
FrankenScamp Offline
Medford OR
Lots of cool info here...
Re: AMC 360 vs Chrysler 360... are they different? [Re: scratchnfotraction] #445144
08/21/09 09:59 PM
08/21/09 09:59 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
There were Gen 2 290, 343, and 390 ('66-'70) and Gen 3 304, 360, 401 ('71-'91) engines. The Gen 3 had slightly taller decks, but with only a 9.208 max deck height (Gen 3) were all considered small blocks. (SB Mopar is 9.600) The intakes were slightly different, but could be slightly modified to fit.
But there were no major changes as in the SB-BB Mopars,Chevys, or Fords.
Re: AMC 360 vs Chrysler 360... are they different? [Re: '64 Belvedere] #445145
08/22/09 11:00 AM
08/22/09 11:00 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
About the only thing that swaps between the AMC and Mopar 360 are the lifters.
I like AMC's but wouldn't want to restore one, I've rode in 4 of their performance models and they all run real good for stock type cars.
One of my H.S. friends had a 68-69 Javelin with a 343/4 speed and traded that for a 71 AMX 401/auto, both cars were pretty ahead of their time, the 343 was one of the better running base model cars I've ever been in. Another one that suprised me was the Gremlin X, I rode in one with a 304/4 speed/3.90's(3 speed/hwy gear stock) that would give most 340/833 A bodys a good run.
Re: AMC 360 vs Chrysler 360... are they different? [Re: Evil Spirit] #445146
08/23/09 02:28 PM
08/23/09 02:28 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, technically the lifters interchange, and the rockers on the 5.2 & 5.9 magnums are carryover AMC 290-401 parts.
2017 Grand Cherokee Overland
Re: AMC 360 vs Chrysler 360... are they different? [Re: patrick] #445147
08/23/09 03:35 PM
08/23/09 03:35 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
AMC did some goofy stuff back in the day.
We had a 1975 4X4 wrangler with the 304 or
something close to it. The trans had GM Turbo
400 guts in it. We gutted the trans and put
everything in the Chevy trans case. The transfer
case bolted right up to the Chevy Turbo 400 case.
Then we made mounts and tossed in a 350 Chevy.
All fresh with parts from Northern Auto out of
Sioux City, IA. It all depends on what trans
is in the thing. AMC used alot of parts from
different manufacters.
Snap your neck, mega G-force launch, is all I want!
Re: AMC 360 vs Chrysler 360... are they different? [Re: BDS871Cuda] #445148
08/23/09 09:27 PM
08/23/09 09:27 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
The 4x4 trans' were T-400's made by GM with an AMC bolt pattern case. The auto trans in cars starting in '72 were made by Mopar - 904's or 727's with AMC bolt pattern cases.
