which rear sway bar best compliments the one I have? #444243
08/20/09 02:42 PM
08/20/09 02:42 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Im just curious to what would be the best suited rear sway bar to be used with my Addco 150 (1-1/8")front bar? looking at either the addco 675 (7/8") or the 919 (3/4") any opinions is appreciated! thanks
-kevin
btw, car in question is for my 71 scamp.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: which rear sway bar best compliments the one I have? [Re: mopars_1] #444244
08/20/09 02:56 PM
08/20/09 02:56 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Hellwig 3/4", adjustable,dogbone style links. Just put one on my 69 B'cuda! Love it! Had a couple Q's during install and actually talked to a person who has done the installs!!! Phone was answered in 2 rings(no press 1 for english,etc) Excellent product AND customer support!! I believe Dave? hangs out over on FABO.
Re: which rear sway bar best compliments the one I have? [Re: mopars_1] #444245
08/20/09 03:11 PM
08/20/09 03:11 PM
Tampa, Fl.
tampacuda69 Offline
tampacuda69  Offline
Tampa, Fl.
I have a 1 1/8" front and 7/8" rear Addco bars on my '69 Barracuda. Works great.
Call Addco or other mfgrs. for their recomendations.
Re: which rear sway bar best compliments the one I have? [Re: tampacuda69] #444246
08/20/09 04:43 PM
08/20/09 04:43 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Well the size is more your call. The bigger the bar more spring rate is added as the rear end corners. Essentially the rear bar is suppose to help understeer. But go too big and the rear end will want to come around on you if you are pushing it through corners. I would say a ¾" bar is plenty.
But then again, loose is fast!! You need to find out if you like a loose car or a tight car.
