Page 10 of 12 1 2 8 9 10 11 12
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: cheapstreetdustr] #44528
09/15/09 09:31 PM
09/15/09 09:31 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
What ever floats your boat, I use a cowl hood on my 70 Cuda
This is my friends Duster.
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: B1KILLER] #44529
09/15/09 09:36 PM
09/15/09 09:36 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Bird catcher
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: juicedcuda] #44530
09/15/09 09:41 PM
09/15/09 09:41 PM
Pennsylvania, USA
Big_Fish Offline
Big_Fish  Offline
Pennsylvania, USA
Billy, just for the record, I'm the new owner of your "cousins" Cuda. The 6" cowl hood was too small so it's already off! With my tunnel ram and 2 1050 dominators the carbs were too close to the hood. Instead I'm hoping to use a Pro stock style hood scoop (ie similar to DTHEMI's). But if it doesn't work out I'm upgrading to an 8" cowl scoop from AAR Quality Fiberglass just for you
Aar doesn't offer an 8" cowl hood. Glasstek would be your best bet for quality after Aar.
Went with the forward facing, but thanX for the heads-up on AAR. Pic of hood while we fitted up with the new scoop.
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: 383man] #44531
09/15/09 09:45 PM
09/15/09 09:45 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
I like the vintage SS look and of course the Mopars did not use a cowl. But it's up to the cars owner as what they like on their car. I just like the factory racer look myself. Ron
ooooh yeaaaaaaaa!
Re: Cowl Hood Scoops.. Why on a MOPAR????? #44532
09/15/09 09:57 PM
09/15/09 09:57 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I really like the looks of this car.......Is it running in any headsup stuff? If so, what's it run and what's it got for motorvation?
N/T car, from da Bronx $$$
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: BILLYJAY] #44533
09/15/09 10:03 PM
09/15/09 10:03 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Classic looks good 2
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: B1KILLER] #44534
09/15/09 10:05 PM
09/15/09 10:05 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
some more
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: B1KILLER] #44535
09/16/09 05:58 PM
09/16/09 05:58 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
I think if you research it..Don Carlton was testing/using cowl hoods in 1972 on dusters..
so i wouldnt call it a new fad..fwiw
\cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: cheapstreetdustr] #44536
09/17/09 06:58 AM
09/17/09 06:58 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
my cowl
Re: Cowl Hood Scoops.. Why on a MOPAR????? #44537
09/17/09 11:41 AM
09/17/09 11:41 AM
Pennsylvania
proshiftcharger Offline
Pennsylvania
the original design of the cowl hood scoop was to direct cool air by picking it up from deflecting it off the windshield
And it does function fairly well. There is a high pressure area at the base of the windshield.
And to those that posted they went slower, have you given any consideration that the difference in air (be it less or more with the cowl hood) affected your a/f ratio at certain speeds?
Just a though.....
Cowl hoods DO FLOW AIR into the engine.
I dont like the looks either.
but if you study the various configurations and placement you will see that many are too far from the glass to catch the air and let the scoop do it's job.
Since the advent of the taller heads/intakes from Indy, Preditor & B-1 as well as class rules its clear as to why so many are using cowls but some followup questions for the cowl hood.....
1) Should you seal the cowl scoop to the carbs?
2) How close to the front windshield should the end of the cowl scoop be for maximum air? I see some real close to the windshield almost touching it and others 6 inches or more away from the windshield.
thanks,
Doug
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: proshiftcharger] #44538
09/17/09 01:18 PM
09/17/09 01:18 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I don't like the cowl scoops on a Mopar. I guess they are functional, but look like they belong on a Camaro or a Shevelle. I don't even like the aero scoops on an old Mopar. I like the ones correct for the period. I don't even like the really TALL MW and early Hemi scoops on the NSS cars. I like the AFX scoop on the NSS cars. Again, period correct. They actually had those back then. Leave the aero scoops for Comp or SS/GT cars with modern bodies. Too bad they don't make a TALL T/A scoop. I think that would look good on E-body cars and probably A-body Dusters, etc.
Floyd Lippencott IV
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: BILLYJAY] #44539
09/17/09 02:05 PM
09/17/09 02:05 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
will probably use a cowlhood, cant realy see any other way of hiding a aircleaner on top of a dominator wish will sit very far back on a lysholm twinscrew supercharger under anything else than that, i have a sixpack scoop on my current hood but i think that will have to be changed, i realy dont like having both carb and aircleaner up in the air and vissible
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: 1Fast340] #44540
09/17/09 02:59 PM
09/17/09 02:59 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I don't like them on many mopars but I really like them on E-Bodies but they have about the same bodies lines as 67 - 69 Camaros. It's just a personal preference. I don't think I would get anywhere near the complements I get on my car if it has a 6 pack hood on it.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: WadeMetzinger] #44541
09/17/09 06:16 PM
09/17/09 06:16 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Another look
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: proshiftcharger] #44542
09/18/09 08:50 AM
09/18/09 08:50 AM
Pennsylvania
Pennsylvania
Just a though.....
thanks,
Doug
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: B1KILLER] #44543
09/18/09 10:00 AM
09/18/09 10:00 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Bird catcher
If I had to use a mopar hood, I would want one like on the Killer (Hemi scoop) I always liked Mike Daugherty's cuda in KOS with that hood.
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: BILLYJAY] #44544
01/31/13 01:00 AM
01/31/13 01:00 AM
Maryville tn
67coronetman Offline
Maryville tn
Why not the guy that owns that car can do whatever he wants.... period he paid for it not me or you.... I say use what you want and what works for you my friend is on his 68 charger because he needs the hood clearance.
Old car are me......
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: 67coronetman] #44545
01/31/13 01:21 AM
01/31/13 01:21 AM
fresno ca
mikeysmopars Offline
fresno ca
I say they all look like an upside down bass boat molded to the hood.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: mikeysmopars] #44546
01/31/13 01:54 AM
01/31/13 01:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A cowl hood came stock on my mopar... mines just a
little higher
Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: MR_P_BODY] #44547
01/31/13 09:22 AM
01/31/13 09:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
one more for the haters...
