Six Pack Idle #439645
08/16/09 10:00 AM
08/16/09 10:00 AM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
I had an issue with my idle on my six pack . It was all over the place. My Mopar performance dist. had 2 light advance springs in so I replaced one with a heavier one and now it returns to whatever I have it set at and that is great.My question is at 1000Rpm's at idle when I put it in gear it drops 300 rpm's . I don't ever remember that it should drop that much.The engine has a 484 lift cam 30 over 915 heads and a Hemi street stall converter.
Thats Moparts
Re: Six Pack Idle [Re: 72 RR DUDE] #439646
08/16/09 10:19 AM
08/16/09 10:19 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
whats your timing at? vacuum advance hooked up? it could be on vacuum advance at idle that disappears whenyou put it in gear. disconnect thevacuum advance and plug it at the carb. set the timing to 15-20 degrees initial and see what it does
Re: Six Pack Idle [Re: aarcuda] #439647
08/16/09 12:02 PM
08/16/09 12:02 PM
Hamburg, Pa.
Hamburg, Pa.
I have the vacumn hooked up and the timing at 10 degree's Just took it for a ride and it is really lazy in low gear but much better in 2nd and drive.Stopped and put the timing up a little and it was better didn't ping but not great.
Re: Six Pack Idle [Re: 72 RR DUDE] #439648
08/16/09 01:34 PM
08/16/09 01:34 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
set the timing WITHOUT the vacuum hooked up. the hook it up and see what happens.
Re: Six Pack Idle [Re: aarcuda] #439649
08/16/09 03:36 PM
08/16/09 03:36 PM
Hamburg, Pa.
Hamburg, Pa.
Thats what I've been doing I guess I need to know what to set timing at and if I should or should not run it with vacunm hooked up.Do I really need it hooked up.
THanks
Re: Six Pack Idle [Re: 72 RR DUDE] #439650
08/16/09 08:52 PM
08/16/09 08:52 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I agree with the others on the vacuum advance. Set timing without it, but still use it even if you adjust it so it doesn't contribute much
Personally, I think your idle problem is the carbs being too lean at idle...mine did what you describe...took a lot of playing around to get it. A vacuum gage absolutely helps to do it.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
