Will 15x8 w/ 245/60's fit on 65 Barracuda? #435644
08/12/09 03:00 PM
08/12/09 03:00 PM
Blairsden, CA
Triggerfish Offline OP
Blairsden, CA
Just sold my new set of small bolt pattern Cragars & T/A Radials if they'll fit on a 65 Barracuda. Rears are in question: 15x8 Cragar SS, 4.125" backspacing, 245/60x15 T/A Radials. Will they fit on the back? Fronts are 14x6 w/ 205's so I know they'll fit. Thanks for any info.
Re: Will 15x8 w/ 245/60's fit on 65 Barracuda? [Re: Triggerfish] #435645
08/12/09 03:37 PM
08/12/09 03:37 PM
scratchnfotraction Offline
does it have the 8 3/4 with skinny 1 3/4" brakes?
if so,I dont think that back space is gonna work
I ran 7" with 4 1/2" bs with 245/60/15 on a slab sided 68 Dart
but had large offset on the axle to run the larger brakes and greens in the 8 3/4 rear
that made it 1/2" wider..1/4" each side
with a lage brake 7 1/4" rear axle it would rub and needed 4 1/4" back space on the rims
I think the back space is gonna be the problem,the 68 cuda has more room to the out side than to the inside,and the skinny brakes make it close on the spring as it is
might have to bolt them up to check for sure.
hope that helped and did not confuse and kill your sale..
Re: Will 15x8 w/ 245/60's fit on 65 Barracuda? [Re: scratchnfotraction] #435646
08/12/09 05:36 PM
08/12/09 05:36 PM
Blairsden, CA
Blairsden, CA
Thanks for the info & I'll see which rear end & brake combo it has. Much appreciated.
Re: Will 15x8 w/ 245/60's fit on 65 Barracuda? [Re: Triggerfish] #435647
08/12/09 08:34 PM
08/12/09 08:34 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Your title says '65, but your post says '68?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Will 15x8 w/ 245/60's fit on 65 Barracuda? [Re: Triggerfish] #435648
08/12/09 09:26 PM
08/12/09 09:26 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
A 275/60/15 Micky Thompson drag radial JUST fits under my 65 Barracuda mounted on a 15x8 Weld wheel with 5 1/2 inch back space. You will need to do the 3/4 inch inboard relocation to fit these, plus I had to roll the lip.
Hope this helps.
Jim Burch
Re: Will 15x8 w/ 245/60's fit on 65 Barracuda? [Re: GO_Fish] #435649
08/12/09 11:41 PM
08/12/09 11:41 PM
Blairsden, CA
Blairsden, CA
Thanks Scott. I didn't catch the mistake & its for a 65 barracuda. I corrected the post.
Re: Will 15x8 w/ 245/60's fit on 65 Barracuda? [Re: Triggerfish] #435650
08/13/09 08:07 AM
08/13/09 08:07 AM
65 would be a diff measurment than a 68
so what I posted might not apply
results will vary
