How to remove spindle from trailer axle??? #435302
08/11/09 09:49 PM
08/11/09 09:49 PM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
I need help with my trailer. I siezed a bearing and ruined the spindle. I thought I would just put a new spindle in it and be on my way.....wrong!! I removed the axle assembly to make things easier to work with, ground the welds holding the old spindle and beat on the spindle with a sledge to free it up. I can see that all the welds are broke free but I can't get the spindle to budge out of the axle tube. Is there a trick to this or do I just need to spend the money and get a new axle?
Re: How to remove spindle from trailer axle??? [Re: AeroMonte] #435303
08/11/09 10:13 PM
08/11/09 10:13 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
hmmm, there is a plate welded to my axle tube and the spindle just bolts on.....
pics would help
Re: How to remove spindle from trailer axle??? [Re: AeroMonte] #435304
08/11/09 10:13 PM
08/11/09 10:13 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Do you have a Photo of it?
Could you heat the tube with a Torch?
Re: How to remove spindle from trailer axle??? [Re: D_C] #435305
08/11/09 10:32 PM
08/11/09 10:32 PM
S.E. Missouri
S.E. Missouri
Sorry no pics. I'll try to snap some in the morning. It's a 3500# axle from my car trailer. The square plate on mine is welded all the way around the tube. It does have four holes to bolt a spindle to it... but the spindle is welded in four places to the square plate. I'll try to heat it at work tomorrow to see if it will budge.
Re: How to remove spindle from trailer axle??? [Re: AeroMonte] #435306
08/11/09 10:34 PM
08/11/09 10:34 PM
D_C Offline
D_C  Offline
Could you Torch-Cut the spindle off then grind the plate to clean it up?
Re: How to remove spindle from trailer axle??? [Re: D_C] #435307
08/12/09 01:29 AM
08/12/09 01:29 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
that lil plate is welded on to bolt the backing plate to. the back side of the spindle sticks into the axle tube about 3 inches. check to see if its been plug welded also...
I am truckless..
Re: How to remove spindle from trailer axle??? [Re: AeroMonte] #435308
08/12/09 04:12 AM
08/12/09 04:12 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
If it's like most trailer axles it's a tube with a spindle stub welded into it behind the backing plate, it may be plug welded also.
Good luck with it.
