Re: SB stroker options for track car
[Re: Mattax]
#432408
03/04/11 12:08 AM
03/04/11 12:08 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Dang that's serious $ for a distributor ...
Agreed. I'd rather set up 4 or 5 stock distributors with different specs and just swap them out. That's partly because I have a pile of them though.
[Re: @#$%&*!]
#432409
03/04/11 12:33 AM
03/04/11 12:33 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
on the weight of the tti headers... tti has some seriously thick tube wall.. doubt theyll be rusting through anytime soon. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: autoxcuda]
#432412
03/12/11 01:43 AM
03/12/11 01:43 AM
Posts: 30,947 Oregon
AndyF
I used ARP main studs. The ARP studs have a hex broached in the end so they are a little nicer to work with. We had to notch the pan for the windage tray nuts so it took some effort to get everything to fit.
It ran nice on the dyno today. No leaks anywhere after plenty of stress testing, valve lash looked good, cranking compression is identical in all 8 holes, plugs look good. So she should be ready to drop back in the car so Tim can take it to the track this summer.
[Re: AndyF]
#432413
03/12/11 02:58 AM
03/12/11 02:58 AM
Posts: 27,444 So Cal
autoxcuda
So Cal
Were did you notch? The same two I dimpled? Pics?
Did you do something different to it since the last dyno test you did to it?
[Re: AndyF]
#432415
03/12/11 11:56 AM
03/12/11 11:56 AM
autoxcuda
So Cal
I didn't take any pics of the windage tray mods. The engine builder did the work and he had it all together before I showed up with the camera.
Main change since last time on the dyno was the oil pan. Also changed the valve covers in an attempt to stop the various oil leaks. Ran a belt driven water pump this time so we chould check for leaks but it didn't seem to cost any power. Engine still made almost identical power to a year ago even though the dyno cell had seen a number of changes. Power curve is very similiar to a Viper, 520/520.
Oh, you meant notch the windage tray. I thought you meant notch the oil pan.
Was this at the pick up tube to windage tray area? We did that too.
[Re: AndyF]
#432419
04/03/11 12:15 AM
04/03/11 12:15 AM
autoxcuda
So Cal
June issue of Mopar Muscle has a follow up feature on this engine as well as a few pics of the car.
Awesome!!
I just took my 416 on it's maiden voyage last night. Gobs of torque. Glad I took Tim Werner's advice and went single plane for this kind of application. I think I'm going to have to be careful getting on the throttle on corner exits.
What is your feeling on running a PCV for this? I've heard it could be beneficial when getting off the throttle and on the brakes hard??
[Re: AndyF]
#432422
04/03/11 10:13 PM
04/03/11 10:13 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Why not like it? Who wrote the article? If it was you I think we can assume it's good, if it's regular MM staff...not so much. Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: AndyF]
#432424
04/04/11 02:08 AM
04/04/11 02:08 AM
autoxcuda
So Cal
He might not think the picture is very flattering! We were both a little tired and dirty when I snapped the photo.
I've never worked on a car with a white shirt and light colored pants. Looks pretty clean and spotless to me.
...Put about 150 miles on my new stroker SB since Friday night driving around L.A.. These things are awesome!! Time to change oil, bump timing, and get it out on the track April 14th at Willow Springs!
