Jeep Techs HELP #431651
08/08/09 07:25 PM
08/08/09 07:25 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
2005 Grand Cherokee Limited AWD 49000miles. It started shuttering when turning the wheels Like a 4WD truck will do on a tight turn. But it only does it after it has been driven a while then cools off & will only do it until it warms up again.So far Tech has replaced front & rear drive shafts Taken transfer case apart to inspect for worn parts & flushed out the PS pump & rack.I still think it is Transfer case related could something be worn but not appear to be visually.Checked the front end its tight said CV joints were OK.Anyone have any ideas
Sal
Re: Jeep Techs HELP [Re: gts1] #431652
08/08/09 08:02 PM
08/08/09 08:02 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Sal any chance you have new tires in the front and worn tires in the rear? This would make your transfer case work extra hard. Are using the right Mopar fluid? Also not common in Jeeps but your posi rear could be chattering.
Re: Jeep Techs HELP [Re: SALEM1912] #431653
08/08/09 09:29 PM
08/08/09 09:29 PM
Dallas, TX
71_Demon Offline
71_Demon  Offline
Dallas, TX
All that is good info. Do you have quadadrive on the jeep?
'71 Demon 383 auto '12 Ram 2500 6.7 Diesel
Re: Jeep Techs HELP [Re: 71_Demon] #431654
08/08/09 10:53 PM
08/08/09 10:53 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Tires are the original ones all inflated correctly
Noise is not a rear end chatter.Any other suggestions
Re: Jeep Techs HELP [Re: gts1] #431655
08/09/09 11:32 AM
08/09/09 11:32 AM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
If it is awd I would guess that the viscous coupler in the transfer case is bad or the transfer case has the wrong fluid in it
Re: Jeep Techs HELP [Re: mod381] #431656
08/09/09 12:06 PM
08/09/09 12:06 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Thats what I thought to Can you visually tell if the VC is bad, Techs say they have taken the Transfer Case apart & found no worn parts.Fluid was Original Thanks
Re: Jeep Techs HELP [Re: mod381] #431657
08/09/09 12:47 PM
08/09/09 12:47 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Re: Jeep Techs HELP [Re: RussW] #431658
08/09/09 08:54 PM
08/09/09 08:54 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Recommended lubricant for the NV140 transfer case is MoparŪ ATF+4, Automatic Transmission Fluid. Recommended lubricant for the NV245 transfer case is MoparŪ NV245/247 Transfer Case Fluid. Recommended at 30k miles.
Re: Jeep Techs HELP [Re: gts1] #431659
08/11/09 10:02 PM
08/11/09 10:02 PM
Dallas, TX
71_Demon Offline
71_Demon  Offline
Dallas, TX
Check you pm's
