Which ignition? #429096
08/05/09 11:05 AM
08/05/09 11:05 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What ignition box do you folks recommend for a 600hp street/strip application?
I've been looking at the MSD digital 6, 6AL-2, and 7AL-2.
FYI: 500ci, 727, 4.10, 30" tire.
What do you folks run?
Re: Which ignition? [Re: mopowers] #429097
08/05/09 11:26 AM
08/05/09 11:26 AM
I'm a firm believer in buying more than you need on hi po parts, especially ignitions, fuel systems, exhaust sytems and so on. I use a MSD 7C on my street Duster (518 C.I. 700HP+pump gas motor) mainly because I had it as well as a 7AL2. Both of those boxes leave room to grow if I decide to up the compression or add some power adders like NOS or others Buy a good once and don't look back
