Brake line help #427611
08/03/09 07:09 PM
08/03/09 07:09 PM
Roanoke Va
beerwolf Offline OP
beerwolf  Offline OP
Roanoke Va
I am trying to run new Stainless brake lines and cannot find a good flaring tool for this. Any help please, Advance auto does not have any"good" brake line flaring tools, stripped 2 of them on regular lines trying to get it right. Building a 34 Ford Tudor with a 72 Caddy motor. 500 with 2x4 intake. I know not a Mopar........
Thanks in advance
Dan
Re: Brake line help [Re: beerwolf] #427612
08/03/09 08:52 PM
08/03/09 08:52 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
SS is TOUGH stuff, as you have found out. It also requires different flares and adapters.
Here's a google search, but unless you want the no rust and race level lines, why not go with good ol' regular steel?
http://www.google.com/search?hl=en&s...vision&cd=1
http://auto.howstuffworks.com/auto-parts/brakes/brake-parts/brake-lines.htm/printable
Re: Brake line help [Re: RodStRace] #427613
08/03/09 08:57 PM
08/03/09 08:57 PM
Roanoke Va
beerwolf Offline OP
beerwolf  Offline OP
Roanoke Va
Stainless looks so much better under the car.Better quality I believe.
Dan
Re: Brake line help [Re: beerwolf] #427614
08/10/09 08:54 PM
08/10/09 08:54 PM
Pa. bucks county
cuhemida Offline
cuhemida  Offline
Pa. bucks county
i won't say i know it all but from what i read SS brake line and less flex and can cause stress at fittings before i make my mind up i would read more about that difference between all froms of brake lines
Re: Brake line help [Re: cuhemida] #427615
08/11/09 03:45 AM
08/11/09 03:45 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Does anyone know if regular steel brake line is offered in larger rolls than 25 feet ?
Re: Brake line help [Re: dOc !] #427616
08/30/09 12:26 PM
08/30/09 12:26 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
a) I have the3 MasterCool 71475 flaring tool kit. You have to watch the stainless tube because it comes in various wall thickness.If you buy too thick of a tube the tool will break every time. You might want to call and talk to Mastercool or perhaps someone at Eastwood?
b) For getting a roll of tubing longer than 25 ft. I'd call these folks and see what's up:
http://www.tiautomotive.com/bulktubing/double_wall.php
