Hood scoop or cowl hood?
#426410
08/02/09 03:36 PM
08/02/09 03:36 PM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
As my plastic front end is still in work, it`s final time to make decision about what to do with scoop... What you guys suggest - front open scoop or cowl hood. I used to have 5" cowl hood I`d also like front opened scoops but I cant decide which style is best and also looks best? Can you give any suggestions? My car is `74 Dodge Charger, R5/P7 motor, shortened rear end, 10 point rollgage Thanks, Georg
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: Hood scoop or cowl hood?
[Re: 85_Ram_4speed]
#426413
08/02/09 10:18 PM
08/02/09 10:18 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I tossed and turned several nights thinking about the same thing. I decided to take my 3 inch HEMI scoop and add an inch of height all the way around then install it on a VFN glass hood. A friend of mine is working on the scoop and I am waiting on the hood and bumpers to arrive from VFN.A cowl hood would look good on that long front end however.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#426416
08/02/09 10:51 PM
08/02/09 10:51 PM
Posts: 989 Rather be in Fallon, Nevada
RussW
super gas
super gas
How much you figure the stock ft bumper and brackets weigh ?
[Re: ScottSmith_Harms]
#426420
08/03/09 02:34 AM
08/03/09 02:34 AM
I guess I'm a purist, no matter how many Mopar racers flock to them, I just can't stand the cowl style hoods on Mopars, everytime I see one I think "Chevy", and on most cars I think they dominate rather than enhance the cars appearance, especially the tall/monster versions.
Personally I'd use a Six Pack scoop, maybe add an inch or two in hieght if you feel you need it and call it a day.
I agree..cowl hoods have no place on a Mopar..
#426421
08/03/09 02:34 AM
08/03/09 02:34 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
At this point I would just leave a hole in the hood, and have both the cowl & front facing scoop available, and try which one is better for your performance. The problem with the front facing factory style scoops is, that they create a lot of lift, so you have to attach them better and perhaps even make the parts more rigid = heavier. Problem with the cowl style is, that it may or may not work, and because it's realtively long and wide it blocks the visibility more than a purpose built, low pro style scoop.
Plynouth VIP '67 TT IC EFI
#426422
08/03/09 08:25 AM
08/03/09 08:25 AM
Posts: 4,799 ILL
MLR426
ILL
I agree those tall monsterous COWL hoods look aweful on mopars, well they also look bad on chevy's too.
logan426
[Re: MLR426]
#426423
08/03/09 09:34 AM
08/03/09 09:34 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
logan426
Same here I just dont think the cowl looks right on a Mopar. Ron
[Re: Garceau]
#426425
08/03/09 10:08 AM
08/03/09 10:08 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I'm also one of the guys that think a cowl has no place on a mopar. That said, it's your car, do as YOU want.
Mine is a galss buldge hood W/ an aero scoop. I had them take 2 inches off the bottom of the scoop so it flowed with the lines of the hood rather than sittng way to high in the air.
If you want I have pics from a few different angles.
Post deleted by Defbob
[Re: HardcoreB]
#426428
08/03/09 01:13 PM
08/03/09 01:13 PM
[Re: Georg]
#426429
08/03/09 01:21 PM
08/03/09 01:21 PM
Posts: 13,345 Marion, South Carolina [><]
an8sec70cuda
For a cowl hood to work, the rear of the cowl scoop needs to be close to the windshield. I only have enough room to get my fingers b/t my windshield and the back of the cowl scoop. If it doesn't get close to the windshield, it won't pull any air in.
I switched from a six pack hood to the cowl hood and saw no change in ET or MPH. Both were sealed to the carburetor.
The problem I had with the 6 pack scoop was that above 120 mph the hood tried to lift off the car REAL bad. CHIP
