Re: Hood scoop or cowl hood?
[Re: cbarracuda]
#426470
08/05/09 10:37 AM
08/05/09 10:37 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
You tell that to a pro stock owner, maybe he'll go faster with the scoop taped.
You can't compare a pro stock scoop to a hemi or 6 pack scoop. The pro stock scoops sit high enough that they do work, the hemi and six pack scoops are MUCH shorter. CHIP
[Re: an8sec70cuda]
#426471
08/05/09 11:56 AM
08/05/09 11:56 AM
Posts: 778 Sherwood park, Alberta.
go green
Oh boy nobody mention the Ford 9" or the GM transmissions or there will be a brawl . I like the factory scoops they suit the cars . I was able to fit my tunnel rams underneath them with a little as a 1 " lift on the design. Its pretty tough to put on a pro-stock style scoop and not have it overpower the lines of the car. There are to many different combinations to dismiss any one hood scoop .Cowls look good on some cars and bad on others and vice versa for the pro-stock style hoods. Plop any thing you want on your hood its yours.
[Re: go green]
#426473
08/05/09 09:04 PM
08/05/09 09:04 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Factory scoop for me. Runs a big enough number for my brain which finally a Godsend. Looks like SS/BA but is 1/2 price. Scoop worth 15 hp.
The little old lady from Pasadena is back!
[Re: BloFish]
#426475
08/05/09 09:39 PM
08/05/09 09:39 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
I don't think I have enough clearance between my carb, and top of my scoop. I have been toying with the idea of switching to an aero scoop, or cowl scoop
Thats what I ran into, and I don't like the aero scoops...
[Re: 70dusterjohn]
#426476
08/05/09 09:49 PM
08/05/09 09:49 PM
Barnstorm
Minnesota
Look at all the SS/AH cars. They are resricted on height, and those carbs are TIGHT up againt the scoup. Alot don't run air pans.
#426486
08/06/09 12:38 AM
08/06/09 12:38 AM
TMP66
anyone want to buy a hood
I don't blame you for wanting to get rid of it.....Jon Boats are for fishin'!
