Page 6 of 7 1 2 3 4 5 6 7
Re: Dodge Truck Registry 1972-1980 [Re: smallblock666] #4237
02/07/09 11:12 PM
02/07/09 11:12 PM
Midwest
Sidewinder Offline
Sidewinder  Offline
Midwest
Here's another for the registry MachoMan.
79'Macho longbed
Canyon red
bucket seats with center jump
black int.
CP1 3500/4000# frt.axle
RU9 special wheels
AB2 321 8 3/8 rear axle
ec4 360
LF4 tuff strg.wheel
LP6 roll bar
NT3 tire carr underslung
SW4 skid plate t.case
HAP air pump
NE5 headlamps quad rect
LM4 AM FM
LB2 oil pressure gauge
FA3 727 auto trans
HL7 18 gal.f/tnk frm MTD
RX2 spare wheel
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4238
02/25/09 08:11 PM
02/25/09 08:11 PM
metro Detroit
Swinger367 Offline
Swinger367  Offline
metro Detroit
here is my 1979 WarlockII
W13JE9S******
Canyon red, red interior, bench seat, black rubber mat.
NP435 NP203
Dana 44, corporate 9 1/4 3.55
radiator tag:
130023 WI 115 conv cab
LY3450
W13JE9S****** GQ349901
CH3 cab $ utiline
CP1 frt axle 3500/4000
??5 power disk brakes
??1 eng 8cyl 318-1
HCC cat conv
HF3 batt 46 amp
HLC light duty cycle
LH2 glove box lock
LK3 glove box light
NE1 exterior cargo light
NT3 tire carrier under slung
RX2 spare wheel
SJ6 1650 rear spring
TK9F 10.00X15 4 rwl
WP2F highway tread poly thumpless ([Edited by Moparts - Keep it clean]?)
YF1 convenience pkg
LX3 11 inch clutch
HL2 alternator 41 amp
HK4 sound control label
HL7 18 gal tank frm mtd
LF4 steering wheel 15in Tuff
LJ1 cigar lighter
LK4 ash receiver lamp
NG1 in cab hood release
RA6 whls 15X8 chrome road
SF1 SP1 frt sprg 1400 lbs
ST1 power steering
TK9R 10.00x15 4 rwl
WP2R highway tread poly thumpless
YS1 std cab
i found only a few scraps of confetti, i mean build sheet. and it looks like there was a second label under the hood next to the one that is there. it still has all of the pin stripping, and the wood racks.
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4239
04/05/09 12:46 AM
04/05/09 12:46 AM
ok heres one of my three for ya vin:d14af2u564108 my truck is a 1972 d-100 posi rear, 83/4, a new prosses 4530 true 4 speed, 360 with elbrock intake and carb headman headers with a true dual exhaust. it put 200 hp and 262 ftlbs at the wheels on a local mustang dyno and ran 15.5 in the 1/4 mile . in may it will be no longer forest service green thanks to a local friend . and i have a 1973 w200 big block truck (not orignal ) but it will be my tow/ 4 wheel truck dana 44 front and dana 60 rear 727 and np 203.and a 1978 camper special d200 with 318 and 4:10 gears and im going to buy a 1971 duster 318/904 and a 1975 ramcharger 318 4x4 have yet to seen ramcharger yet but will
1978 D150 utiline #4240
04/06/09 11:43 PM
04/06/09 11:43 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
recent aquisition...
1978 D13BD8J503870
Black utiline truck with some remnants of gold striping on the cab....
Yeah, it also has the black dash benzel with the gold striping on it too...
Lack of rust is nice since it came from southern nevada....
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4241
04/13/09 10:11 PM
04/13/09 10:11 PM
I got a 1980 Power wagon
vin#w14jeac119403
Red exterior
Black Interior
318 engine
gear ratio 2.94
the interior is a real fixer upper But I only paid 600 for it 84000 original miles.
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4242
04/29/09 12:52 PM
04/29/09 12:52 PM
I recently purchased a 1980 Power Wagon. Im the third owner. It spent all of its life in service. Previous owner kept it at his small airport (moved around alot of planes). Purchase price was $350.00. What a steal!
Here are the Specs...
VIN# W14JTAS131800
GH4 CAB & SWEPTLINE
CP1 RRT AXLE 3500/4000#
DS4 HYD DL BRK BSTR
EC5 8 CYL 360-1 4BBL
FY7 NPG 208 TRANS CASE
HAP AIR PUMP
HCC CAT CONV
HE2 ALT 41 AMP
HLC LIGHT DUTY CYCLE
LFA 16.5 IN DIA STBG WHEEL
LM2 RADIO AM/FM MUL STEREO
RX2 SPARE WHL NON STYLED WHL
NH2 BRIGHT HUB CAPS
SJ6 1650 REAR SPRING
WFA P235/75R15 PG B
YS1 STD CAB
AV6 R/A CHRY 9 1/4 3600 2.94
DF1 10X2 5 HYD RR BRAKES
FA3 TRANS A727 AUTO
HAE MAXIMUM COOLING
HB1 NORMAL DUTY HEATER FRT
HCF FED LESS CALIF EMISS SYS
HF7 BATTERY 59 AH375 CCR
HL7 18 GAL F/TNK FRM MTD
LJ3 COURTESY LAMP SWITCH
NT1 TIRE CARR INSIDE
RB4 WHLS 15X6 5 5 STUD DISC
ST1 POWER STEERING
SF1 FRT SPRG 1400 LBS
WN4 MUD & SNOW TREAD
MNX DECAL DODGE RAM BLACK
PY1417 WHITE
So far I have replaced the dash pad and glove box cover, rebuilt inst. cluster, installed newer factory radio, replaced steering wheel with NOS, replaced turn signal cam switch, new steering coupler, new front shocks, new rear shocks(coil type), new brakes and components inc. rubber lines, new fuel pump, rebuilt carb, complete tune-up, new tires, new front bearings, new WARN GOLD locking hubs, new fluid in trans axle and axles, new REESE class 4 reciever, replaced tail gate.
Next week...
New windsheild, and a new fuel sending unit.
Near future...
Fix small rust spot dr side rear quarter, New rubber all over, paint, new floor pan, new interior.
I have had this truck for almost two months now, I love this truck!!!
Will get some pics up if you are interested.
Dodge Truck Registry 1972-1980 [Re: MachoMan] #4243
10/17/09 01:50 AM
10/17/09 01:50 AM
1980 Dodge D150 Stepside
Vin # D13ANAS12****
318 Four Barrell Edelbrock
I need a dashboard and side mirror brackets. It's tough to find parts for a 29 year old truck.
Re: Dodge Truck Registry 1972-1980 [Re: Sidewinder] #4244
10/19/09 05:25 PM
10/19/09 05:25 PM
NEW YORK
SPRBEE1971 Offline
SPRBEE1971  Offline
NEW YORK
Hi, I have a 1980 dodge stepside pickup truck 318 4 speed, was wondering if anyone knows what rear is in the truck, it has a 10 bolt rear, not sure exactly what rear it is??I need a pinion seal and auto parts store says it could be a 9 1/4 ?? any help would be appreciated, thanks
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4245
01/08/10 04:38 PM
01/08/10 04:38 PM
Windsor Ontario Canada
rammer64 Offline
rammer64  Offline
I've had a 1975 D150 C/C
a 1977 Warlock
a 1987 Rod Hall D150
a 1988 B150 Van
a 1984 B150 Shortbox Van with 340/4 speed
a 1973 Challenger R/T 360/4 speed
a 1974 Newport
a 1970 Chrysler 300
a 1971 Chrysler New Yorker
a 1977 Volare Wagon (WOODY)
a 1973 Fury
a 1970 Duster w/slant 6
a 1971 Duster 340/4 speed
a 2001 P/T Cruiser (recently sold)
and my current corral has
a 1970 Chrysler Imperial
a 1981 D150 Pickup 318/727 auto
a 1992 D150 Pickup 3.9 v/6 auto
and a 1993 D350 C/C Duelly Diesel
"AND PROUD TO SAY I'LD OWN THEM ALL AGAIN" if I could...
Re: Dodge Truck Registry 1972-1980 [Re: rammer64] #4246
03/31/10 01:49 AM
03/31/10 01:49 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
Here's my 78 4x4 RC Custom
A10BF8S
318/2bbl
904 auto
I bought it from the second owner, and his neighbor was the original owner. Pretty rust free, and only 146K on the clock. My wife said my nephew, the gas company guy, and a lot of neighborhood kids have already asked her if it's for sale.
OIF V and OEF X veteran and proud of it!
1981 Big Horn D150 [Re: 69HemiGTX] #4247
05/11/10 08:10 PM
05/11/10 08:10 PM
dynotune440 Offline
dynotune440  Offline
D150 Big Horn...
318 4bbl California Emissions engine
727 Auto
Tilt, Cruise, Digital Clock, A/C, Leather Wrapped Wheel, Pwr Windows, Pwr Locks, Original Sweade/Lambs wool buckets with center console, sliding rear window, am/fm stereo, and what appears to be 72K miles.
Re: 1981 Big Horn D150 [Re: dynotune440] #4248
09/19/10 10:28 PM
09/19/10 10:28 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
here's one, i've just sold:
1978 Dodge Adventurer 150
Li'l Red Express Truck
D13BS8J512744
TON: FW006496
Bright Canyon Red
Black Buddy Seat Interior
3:55 open rear
A/C,
K85 deluxe vinyl buckets, YA1 adventurer package, YH6 lil red package, ZF3 build to US specs, EH1-360-4BBL SPECIAL ENGINE, HF7 5.9 amp battery, LM2 multiplex am/fm radio, PY3442 monotone paint, WMHR, WN9R highway tread pass.car radial, YF1 convenience package, YW4 GVWR, ZK2 add 4,2 gallons of gas
original order form, bill of sale, sales receipt, title transfer, and other assorted original paperwork. pretty standard LRX truck
Re: Dodge Truck Registry 1972-1980 [Re: 69HemiGTX] #4249
12/23/10 07:53 PM
12/23/10 07:53 PM
Cleveland, Ohio
northcoastmopar Offline
Cleveland, Ohio
78
Custom 1/2 ton
Long bed
318
A/C
Power steering
Auto
45,000 original miles
third owner
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4250
01/30/11 10:33 PM
01/30/11 10:33 PM
Canada
mopartruck Offline
mopartruck  Offline
Canada
I have 2! 75 D-100 Adventurer se. vin D14BD5S071*** Its a 440-1 truck ,Also a 76 D-100 Adventurer SE, vin D14BD6S241*** Also 440-1 truck with air and cruise.Tan and cream purchased from Idaho in 2007 now in Canada 3rd owner ,This truck has no rust and run perfect all original not molested.My 75 has been bored and stroked but she ran out of time.But will be getting a full resto.Here is a pic of my 76
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4251
02/27/11 01:42 AM
02/27/11 01:42 AM
Alabama, moving to Pennsylvani...
blueovalguy Offline
blueovalguy  Offline
Just bought a truck today. It is a 1976 Dodge D-100, Adventurer, Sport, Club Cab, Long Bed pickup. Has the factory 440/Auto trans.
Black with gold stripes and a black interior with bucket seats and center console. VIN # is: D17BD6S302182. Has Tachometer and turbine wheels and tool box under the bed on the passenger side.
Re: Dodge Truck Registry 1972-1980 [Re: blueovalguy] #4252
02/27/11 07:49 PM
02/27/11 07:49 PM
blueovalguy Offline
blueovalguy  Offline
engine pic
Re: Dodge Truck Registry 1972-1980 [Re: blueovalguy] #4253
03/06/11 10:15 PM
03/06/11 10:15 PM
Dysart,Pa.
K
kork340 Offline
kork340  Offline
K
Dysart,Pa.
Here's my 77 Warlock. 360 2v auto 4x4. I have the sideboards for it, just not in the pics.
W1 = W100
3 = convent. cab utiline bed
B = 6001-10000lbs gross vehicle weight
F = 360 LA 2v
7 + 1977
S = Warren truck plant
Do not have radiator support tag, build sheet, or underhood decal. Do have original order sheet stating Warlock package was ordered. Also have original 77 grille that needs to be put back on.
Re: Dodge Truck Registry 1972-1980 [Re: kork340] #4254
03/06/11 10:16 PM
03/06/11 10:16 PM
Dysart,Pa.
K
kork340 Offline
kork340  Offline
K
Dysart,Pa.
2nd pic
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4255
06/03/11 01:25 AM
06/03/11 01:25 AM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
Recently bought a 77 2wd shortbed fleetside that is a factory Bright Orange truck. Bought it 6 miles from my house, from the second owner who inherited it from his uncle (the original owner) in 1981. Was 225 with a 3 on the tree, now has a worked 318 and a 727. Will update with numbers and pics soon. Wondering how rare bright orange is/was on these trucks?
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: Dodge Truck Registry 1972-1980 [Re: 75DART440] #4256
09/19/11 10:45 PM
09/19/11 10:45 PM
dynotune440 Offline
dynotune440  Offline
Been a little while...but picked up a 79 W150 Warlock II Power Wagon. Nicely equipt...260 2bbl, auto, factory a/c, 8-track, buckets, tuff wheel, etc. Truck came out of hawthorne nevada back in august of 2010.
