Mopar High Amp alternator? #377822
07/17/09 12:20 AM
07/17/09 12:20 AM
fullmetaljacket Offline OP
Is there a one wire high amp alternator produced by either Mopar or Denso that can hang with the 140 amp GM units out there?
If so, who, what, where?
I am running an MSD 6AL ignition with a 5" shift light tach, electric BG Hot Rod pump, (soon to be replaced by an Aeromotive 1000 pump) high CFM electric single fan, and the stock head lights tails and dashboard.
NO RADIO, NO CREATURE COMFORTS.
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377823
07/17/09 09:30 AM
07/17/09 09:30 AM
Well? LOL.
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377824
07/17/09 10:18 AM
07/17/09 10:18 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Are you looking for an internal regulator like the GM unit? There the later Dodge truck ones work well, and they have high amp models. I also rebuilt my original with a 120 amp kit from JCwhitney.
Ryan
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377825
07/17/09 10:21 AM
07/17/09 10:21 AM
O
OLD318 Offline
OLD318  Offline
O
The answer to this is yes, but the alternator
does not lool like a stock mopar unit.
Powermaster offers a high output GM Style
alternator 140 amps for mopars
I think they also offer the very high output
Toyota style as well...
Check out
http://www.powermastermotorsports.com/
you'll see the links for mopar
Good luck
Re: Mopar High Amp alternator? [Re: OLD318] #377826
07/17/09 10:54 AM
07/17/09 10:54 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Did any Mopars come stock with a GM-Style Delco-appearing alternator? Was walking thru the boneyard and I came across an 88 5th Avenue small block with what looked like a Delco unit.....
Re: Mopar High Amp alternator? [Re: Sixpak] #377827
07/17/09 10:59 AM
07/17/09 10:59 AM
Thank you much Gents.
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377828
07/17/09 11:09 AM
07/17/09 11:09 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i'm running the alternator from the durangos. its a denso unit and i believe has 120 amps stock and 150 or 160 optional.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377829
07/17/09 11:12 AM
07/17/09 11:12 AM
US of A
A38s! Offline
A38s!  Offline
US of A
Have you considered something from a late model Charger?
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377830
07/17/09 11:17 AM
07/17/09 11:17 AM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
I use the Powermaster 140 GM alt on a modified AMC 258 alt bracket .
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377831
07/18/09 09:49 AM
07/18/09 09:49 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Something to consider, the high amp units may require a serpentine conversion.
A standard v belt can literally burn up from the friction.
Re: Mopar High Amp alternator? [Re: ToddP] #377832
07/18/09 10:45 AM
07/18/09 10:45 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I got ts 120 amp unit from mancini Racing and man does it charge. On my 68 you ground one feild other is to MP blue regulator and power straight to battery in trunk with doubled 10 soon to be #4 as you need to limit voltage drop and have at least # 6 for that amperage.
Re: Mopar High Amp alternator? [Re: Dodgem] #377833
07/18/09 10:46 AM
07/18/09 10:46 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Mopar High Amp alternator? [Re: Dodgem] #377834
07/18/09 10:58 AM
07/18/09 10:58 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://s542.photobucket.com/albums/gg408/dodgeboy8/?action=view&current=Alt2.jpg
http://s542.photobucket.com/albums/gg408/dodgeboy8/?action=view&current=Alt1.jpg
No the belt does not burn up ROTFLMAO!!!!!!
Trick is to tighten a new belt warm car right up and re tighten after belt has stretched. then I keep it fairly tight.
I run 10.7s @ 125 mph shifting at 7500 (been to 7800) and go out the end 7000 to 7300 depending when I lift like to run past a good bit sometimes! LOL!!!
Re: Mopar High Amp alternator? [Re: fullmetaljacket] #377835
07/19/09 03:29 AM
07/19/09 03:29 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I have the 120 amp Denso with the AndyF design low mount brackets. The Denso keeps up with my twin 16" electric fans and 4 headlights turning on without dropping a single volt at idle. I bought the setup as a kit from Mancini. The alternator is a two wire.
Re: Mopar High Amp alternator? [Re: Lefty] #377836
07/19/09 11:19 AM
07/19/09 11:19 AM
AndyF Offline
AndyF  Offline
I'd think that the Denso 120 amp kit would satisfy most any electrical demand. The wiring certainly needs to be upgraded when going with that many amps. The firewall connection wasn't ever designed to handle very many amps so it all needs to be upgraded or replaced.
Re: Mopar High Amp alternator? [Re: Lefty] #377837
07/19/09 11:52 AM
07/19/09 11:52 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Lefty or any members running the 120 amp Denso,I see in your pictures a two groove pulley but the web sites I've looked at always show a single groove.I need a duel groove because I have factory a/c.Did yours come that way,is it a option?
Re: Mopar High Amp alternator? [Re: AndyF] #377838
07/19/09 11:52 AM
07/19/09 11:52 AM
Plano, Texas
Dallasdart Offline
Dallasdart  Offline
Plano, Texas
Andy, What If I have rewired the entire car with the harnesses from year one. New Dash/engine forward/rear lights. Can I still upgrade the alt. without changing the stock harness?
72 Dart Swinger 360 Project
Re: Mopar High Amp alternator? [Re: Dallasdart] #377839
07/19/09 12:28 PM
07/19/09 12:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
mines a two groove
Re: Mopar High Amp alternator? [Re: Dodgem] #377840
07/19/09 12:28 PM
07/19/09 12:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Mopar High Amp alternator? [Re: Dodgem] #377841
07/19/09 01:24 PM
07/19/09 01:24 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I use a 130amp denso alt of an 02 one ton ram van. bolts right in, it's externally regulated so you can use your stock reg. cheap on ebay if you can settle for a bit less amps. I see them a lot for 30-100 bucks. as said before, upgrade wiring. not a huge deal. I ran a 4g wire from the alt to the starter relay. I have since added extra fuseblock and relays for lights, fans, electric fuel pump. I got all my power for the relays from the starter relay where I ran that 4g wire.
