Re: Hologen headlamp conversion
[Re: cataclysm80]
#377426
07/18/09 06:01 PM
07/18/09 06:01 PM
Posts: 565 IA
landon1
IA
i wired-up my own with relays and fuses from radio shack for about $15 (i have wire already) for use with the halogen sealed beams in my car...or you can spend about $100 for a harness already made
'71 Satellite Sebring 440
[Re: LimeliteAero]
#377430
07/19/09 11:49 AM
07/19/09 11:49 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Easy power tap would be the starter relay.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: LimeliteAero]
#377431
07/19/09 12:08 PM
07/19/09 12:08 PM
Posts: 5,336 the house on the left.
cogen80
for the guys who have done the conversion, How did you get your power to the relays? I want to maintain as close to factory look as I can. I want to conceal the conversion as much as possible.
the paionless site says to gain power from the battery. How is that done? right from the battery or not?
TIA!
if ya want it to look stock as possible i would hide the relays under the battery tray and just get main power from the starter relay
[Re: cogen80]
#377437
07/19/09 03:52 PM
07/19/09 03:52 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
I checked out that link. Didn't find any info on light patterns. I'm looking for a brighter, whiter light. And yes i know there different.
Look here: http://www.rallylights.com/hella/Beams.aspx
Orignal question was who makes a good conversion headlamp.
Hella makes an excellent conversion headlamp. I've used Hella E-code conversion lamps on three of my vehicles which previously used sealed beam halogen bulbs and highly recommend them to everyone.
are these the lights your talking about? http://www.autobahnpower.com/products.asp?recnumber=422
Yes they are.
[Re: 72roadrunnergtx]
#377438
07/19/09 04:22 PM
07/19/09 04:22 PM
Posts: 4,165 Florida
cataclysm80
Keep in mind wire has voltage drop, the higher the current the more voltage drop for a given wire diameter per foot. A four headlamp Hella system with standard sized bulbs(2 55/60 watt H4s and 2 60watt H1s), on high beam will pull about 17amps of total current, considerably less voltage drop on a 12ga wire than on a 16ga. H4 and H1 bulbs are available in wattages that will simply melt 16 gauge wiring.
Yikes!
What gauge wire would you recommend, or what wattage should we limit ourselves to if keeping the 16 gauge wire? Would keeping the 16 gauge wire defeat the purpose?
Tav
[Re: cataclysm80]
#377439
07/19/09 05:14 PM
07/19/09 05:14 PM
Posts: 765 Shoreline, Washington
72roadrunnergtx
IMO, 12ga. minimum on the secondary side of the relays. Defeat the purpose? Even if you stick with the 16ga wiring the relays are a must for this conversion.
From a previous thread on this subject, "The sealed beam headlamps used on these cars originally were at best 15-20watts. On a four headlamp car, that is about 3amps for the low beams and roughly 8 amps on all four high beams. All this current passes through the headlight switch, dimmer switch, and the bulkhead connector using 16ga. wiring. Upgrading to a four lamp system with 55/60 watt low beam H4s and 55 watt H1 high beams will bring that current draw to about 8amps on low beam and upwards of 17amps with all four high beams burning. The original 40-yearold switches, wiring and connectors will not last long at that rate. Do yourself a favor and install the relays and run at least 12ga. wires on the secondary side."
