convert 3310 vac secondary to mechanical? #376818
07/15/09 11:27 PM
07/15/09 11:27 PM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
what's the pros and cons to doing the screw in the linkage trick tp convert your vacuum secondarys to mechanical ones on a race only application?
4bbl If you can't hear it coming what's the point.......
Re: convert 3310 vac secondary to mechanical? [Re: 4bbl] #376819
07/15/09 11:42 PM
07/15/09 11:42 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
good idea if you want to go slower !
if you want a mech secondary use a 750 double pump carb . list 4779
Re: convert 3310 vac secondary to mechanical? [Re: calrobb2000] #376820
07/15/09 11:48 PM
07/15/09 11:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Theres a reason a Mechanical Secondary carb is often refered to as a "Double Pumper"... You need a second accelerator pump to compensate for the big hole in the fuel curve created by opening the secondaries without air velocity...
Re: convert 3310 vac secondary to mechanical? [Re: 4bbl] #376821
07/16/09 12:14 AM
07/16/09 12:14 AM
MNobody Offline
MNobody  Offline
Holley doesn't recommend it and like said there is no advantage to it.
Re: convert 3310 vac secondary to mechanical? [Re: MNobody] #376822
07/16/09 01:24 AM
07/16/09 01:24 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the engine will have one big bog...no acelerator pump to cover the lean condition as the secondaries are throw open...
Tony
70 AARCuda Vitamin C
Re: convert 3310 vac secondary to mechanical? [Re: 70AARcuda] #376823
07/16/09 03:43 PM
07/16/09 03:43 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
put a bb in the kill bleed and a big shooter with a 50cc pump. check out old mopar performance book for instructions.
