Page 3 of 6 1 2 3 4 5 6
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375231
11/23/10 02:18 PM
11/23/10 02:18 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
At about 2:45 am that night/morning.....
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375232
11/23/10 02:19 PM
11/23/10 02:19 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Another side
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375233
11/23/10 02:20 PM
11/23/10 02:20 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Kinda blurry...at this point I didn't care any more. Got in bed at 3:15am and the baby cried for an hour....It was hard to get up for work this morning.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375234
11/23/10 07:09 PM
11/23/10 07:09 PM
Wow, dude, that looks awesome!
Can't get any further apart so it's all downhill from here.
Re: 1970 Barracuda Gran Coupe 383 #375235
12/29/11 12:55 PM
12/29/11 12:55 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
So the guy doing my sheetmetal JUST got started..it only took 13 months...Anyway, the plan is a 6.1 liter, 6 speed, AterKtion with a pro touring inspiration. The ride height/stance you see in the picture is the goal. It feels good to finally see some progress!!
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375236
12/29/11 05:45 PM
12/29/11 05:45 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Cool. Good to hear you are still going at it and that you haven't let it beat you. I will be doing the same in about a years time.. Mine is sitting in a storage facility. I didn't learn with the 1st one,12+ years ago. I figured I'd put myself through it again..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: 1970 Barracuda Gran Coupe 383 [Re: KatFysh] #375237
02/14/12 12:39 AM
02/14/12 12:39 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The car is finally making some progress. The last picture was a mock up to find the right ride height. After that, the tail panel came back off. I decided to go with custom frame rails. from the engine firewall to the the rear. The frame rails will be moved in a few inches for more tire space and the rails will be moved up into the car for clearance issues. Instead of doing coil overs in the rear, I have decided on bagging the rear for ease of adjustment and loading issues. Here are some pics of the new frame rails being fit.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375238
02/14/12 12:41 AM
02/14/12 12:41 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Nother
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375239
02/14/12 12:41 AM
02/14/12 12:41 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
From the rear
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375240
02/14/12 12:42 AM
02/14/12 12:42 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Last one
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375241
03/13/12 11:54 PM
03/13/12 11:54 PM
Tell Matt to quit working on those dorky Brand X street rods and get that thing done!
Re: 1970 Barracuda Gran Coupe 383 #375242
08/01/12 12:18 PM
08/01/12 12:18 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
5K mile 6.1L I picked up. It's dirty and has been sitting in the garage for a couple years.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375243
08/01/12 12:19 PM
08/01/12 12:19 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Pics of the rear frame rails and floor pan over the rails. The hump will be fitted later.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375244
08/01/12 12:20 PM
08/01/12 12:20 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Floor pan from the left. Once the pans are welded in the tunnel will be cut/raised to adjust for the drive line angle.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375245
08/01/12 12:23 PM
08/01/12 12:23 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Floor pan from the right. Used Sherman main floor pans-all other sheetmetal is AMD. Just trimming for frame rails
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375246
08/01/12 12:25 PM
08/01/12 12:25 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Trunk floor pan-will appear mostly stock in the trunk although the frame rails were moved in about 3 inches for some tasteful rear tubs that don't look real square and racecar-ish.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375247
08/29/12 10:42 AM
08/29/12 10:42 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Here are a few pictures of the floor pans welded in
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375248
08/29/12 10:42 AM
08/29/12 10:42 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
another
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375249
08/29/12 10:51 AM
08/29/12 10:51 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Here is my parts car-a 2010 Dodge Challenger SRT8. It doesn't look that bad, but it was in a head on collision on highway 70 that bent the front frame rails to the firewall and buckled the floor. I am using the engine, 6 speed transmission, and pedals in the Barracuda. I also used this Challenger to get my black 2010 Challenger SRT8 back on the road (I bought it as a theft recovery missing interior, NAV unit, HID headlights, intake manifold, front fascia, grille, radiator, condensor, and trunk subwoofer. I sold off the shell and remaining parts to recoup some of my money.
Re: 1970 Barracuda Gran Coupe 383 [Re: 70B5Cuda] #375250
08/29/12 10:56 AM
08/29/12 10:56 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
One more floor pan pic I found
