Clutch problem - 1965 Hemi Coronet #374929
07/14/09 12:30 PM
07/14/09 12:30 PM
Switzerland
swissmopar Offline OP
Switzerland
Hi,
I bought through Summit Racing a Zoom HP1647-1 - Zoom High Performance Clutch Kit and installed it into a 1965 Hemi Coronet with a 23-spline 4-speed transmission.
After the first start at the strip after trying to change into the second gear the clutch was blocked. I could not change any gears anymore...
I opened the dust cover and saw that one of the 3-fingers of the pressure plate moved over the Throwout Bearing. While installing the clutch I got the impression that the 3-fingers of the Beck and Borg-type pressure plate were too short or the diameter of the throwout bearing too small!
(1) Please can you explain me why this happened.
(2) Did I do anything wrong while installing the clutch?
(3) What do I have to check that this does not happen again?
Your help is appreciated!
Karl from Switzerland
Re: Clutch problem - 1965 Hemi Coronet [Re: swissmopar] #374930
07/14/09 12:48 PM
07/14/09 12:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
First thing was you bought a Zoom.Ive had nothing byt bad luck with them.One I went thru on a 361 with street tires in about 1000 miles.I have a CF dual disc and my buddy has one in his Hemi.No problesm.They last and bite maybe even a little too good.I also ran McCleod with lots of luck.That adn I think you mean throw our bearing.The pilot is in the crank.Did they give you a hemi throw out bearimg?The size difference is a lot.Lots of people like to say hemi.If you bought a 23 spline clutch and said hemi then you screwed up and got an 18 spline TO bearing.Rocky
Chrysler Firepower
Re: Clutch problem - 1965 Hemi Coronet [Re: swissmopar] #374931
07/14/09 03:39 PM
07/14/09 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the throwout bearing is traveling far enough to allow it to bypass the levers you need to install a pedal stop. Adjust the stop to allow a friction disc clearance of .060" (1.5MM).
Re: Clutch problem - 1965 Hemi Coronet [Re: swissmopar] #374932
07/14/09 07:32 PM
07/14/09 07:32 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
What are you using for a bell housing? Had a problem with the wrong pivot. I used the stock pivot when I switched to a bell that allowed a 130 or 143 tooth flywheel. The fork was not deep enough in to the throw out bearing. Worked most of the time, but on a few occasions one side of the fork came out of the bearing/retainer. I didn't realise there was more than one pivot. Installed the correct pivot and all was well.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Clutch problem - 1965 Hemi Coronet [Re: oldiron] #374933
07/14/09 08:06 PM
07/14/09 08:06 PM
New York
K
Ken25 Offline
Ken25  Offline
K
New York
not trying to but in but anyone have problems with luk cluch's?
Re: Clutch problem - 1965 Hemi Coronet [Re: Ken25] #374934
07/14/09 10:02 PM
07/14/09 10:02 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
same thing happened to this week.. the 3 fingers were set too wide and the throw out bearing went past the fingers on the new NAPA parts clutch..put a new Mc Leod clutch in and its fine
