flywheel torque specs??? (440 flywheel) #373830
07/13/09 10:37 AM
07/13/09 10:37 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i need the torque specs for the 6 bolts from flywheel/crank (bolts new from year one) also the 12 point bolts from around the edge for clutch/pressure plate wich is also new from year one
would you use semi perm locktite? (blue)
build up to the desired torque speck?
order of torqueing them?
thanks in advance ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: flywheel torque specs??? (440 flywheel) [Re: toplescuda] #373831
07/13/09 07:22 PM
07/13/09 07:22 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
anyone?
1971 charger
Re: flywheel torque specs??? (440 flywheel) [Re: toplescuda] #373832
07/13/09 09:05 PM
07/13/09 09:05 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 70 FSM
Re: flywheel torque specs??? (440 flywheel) [Re: Snoopy] #373833
07/13/09 09:08 PM
07/13/09 09:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Ralph, there's a list in the tech section here.
Re: flywheel torque specs??? (440 flywheel) [Re: RobX4406] #373834
07/13/09 09:23 PM
07/13/09 09:23 PM
Snoopy Offline
Snoopy  Offline
2
Re: flywheel torque specs??? (440 flywheel) [Re: Snoopy] #373835
07/13/09 09:35 PM
07/13/09 09:35 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
thanks guys ralph
1971 charger
