LBJ to spindle question.... #373371
07/12/09 07:27 PM
07/12/09 07:27 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I am swapping my drum brakes to disc and cannot find the OEM bolts to bolt the LBJ to the spindle. Do I have to use OEM or can I use a grade 8 nut and bolt??
THNX!!!
Re: LBJ to spindle question.... [Re: moparrulzzz] #373372
07/12/09 10:00 PM
07/12/09 10:00 PM
Andrewh Offline
Andrewh  Offline
I lost one while driving and that is all I did to replace it.
The catch is that I could not find one with a deep shoulder, and I could not find one the right length. I had to go longer. But it works.
Re: LBJ to spindle question.... [Re: moparrulzzz] #373373
07/12/09 10:24 PM
07/12/09 10:24 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'd use an OEM one. Check the classifieds or post a wanted ad.
Re: LBJ to spindle question.... [Re: TC@HP2] #373374
07/13/09 08:04 PM
07/13/09 08:04 PM
Mansfield,Ohio
Mansfield,Ohio
Thats what I figured. Like Andrew said, I knew I wouldn't be able to get the proper legnth and the shoulder wouldn't be right.
Have to hit the classified's and see how many replies I get wanting $30 or more!!
Re: LBJ to spindle question.... [Re: moparrulzzz] #373375
07/13/09 11:21 PM
07/13/09 11:21 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
FWIW, I've used grade 8 bolts many times without issue.
I can't see them working any worse than a set off of a parts car, or found in an old bolt bin somewhere.
Re: LBJ to spindle question.... [Re: dave571] #373376
07/13/09 11:29 PM
07/13/09 11:29 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
I also have used grade 8's when original bolts were gone from spindles on donor cars in the wrecking yards.
RF-4C Phantom 69-370 Zweibrucken, Germany
