Swapping out 8.75 with a Dana 60 on a 70 E Body #373321
07/12/09 06:17 PM
07/12/09 06:17 PM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
I am getting ready to buy the parts to do the swap.
What all is needed? I.E. do I need a driveshaft etc.
Plan is to use the Drum brakes currently on the old set up.
Re: Swapping out 8.75 with a Dana 60 on a 70 E Body [Re: scrag] #373322
07/12/09 06:36 PM
07/12/09 06:36 PM
BDW Offline
BDW  Offline
Just did this myself, plan on spending a small fortune.
Dana driveshaft is 1" shorter compared to 8.75.
Re: Swapping out 8.75 with a Dana 60 on a 70 E Body [Re: BDW] #373323
07/12/09 08:51 PM
07/12/09 08:51 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
There is a difference in cuda and challenger
driveshaft length.
logan426
Re: Swapping out 8.75 with a Dana 60 on a 70 E Body [Re: BDW] #373324
07/12/09 09:42 PM
07/12/09 09:42 PM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
Thanks. You're making a decision on my rear end situation (see other thread) much easier...
Until total honesty is on the table, we're not even talking about reality...
Re: Swapping out 8.75 with a Dana 60 on a 70 E Body [Re: MLR426] #373325
07/12/09 09:43 PM
07/12/09 09:43 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yes, challenger is longer...Get the rear in and do some measuring for your application...Don't rely on a textbook length chart...
Re: Swapping out 8.75 with a Dana 60 on a 70 E Body [Re: screamindriver] #373326
07/13/09 02:13 PM
07/13/09 02:13 PM
scrag Offline OP
scrag  Offline OP
Thanks - it is going in a 70 Cuda and my concern was with the drive shaft and any other little glitches or lessons learned.
