For the 68/69/70 Charger Owners out there #371819
07/10/09 06:55 PM
07/10/09 06:55 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Whats your opinion on installing the inner headlight bezel on the Charger? You know that molded ABS with the design of the grill on it that stays stationary when the headlight doors open.
Anyone have pics?
Is it pointless to put them on?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: For the 68/69/70 Charger Owners out there [Re: Pyper70] #371820
07/10/09 07:08 PM
07/10/09 07:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I don't encounter that problem?
Re: For the 68/69/70 Charger Owners out there [Re: DAYCLONA] #371821
07/10/09 07:54 PM
07/10/09 07:54 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
I like them. They are a 68 item, however the bolt right up to a 69 as well and i think they look much better with them installed
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: For the 68/69/70 Charger Owners out there [Re: Pyper70] #371822
07/10/09 08:27 PM
07/10/09 08:27 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I have a 68 and just finished fixing it after a major front end hit, I have the covers, but i'm considering NOT putting them back on. since I restored the grille, it all looks so nice in there and nobody will EVER see them since they only are visible with headlights on.
Re: For the 68/69/70 Charger Owners out there [Re: Pool Fixer] #371823
07/10/09 08:59 PM
07/10/09 08:59 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
That was my consensus as well....I am just trying to avoid a situation is all. I dont plan on driving in the rain but since I am upgrading to the H4 Angel Eyes and the ballasts have to get mounted somewhere. I figured I could mount them behind the headlight buckets and the grille inserts I mentioned might keep some rain water out.
Re: For the 68/69/70 Charger Owners out there [Re: Pyper70] #371824
07/11/09 12:02 AM
07/11/09 12:02 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
Its part of the stock grill on my 68 and I like it.
Re: For the 68/69/70 Charger Owners out there [Re: badblack68] #371825
07/12/09 10:46 AM
07/12/09 10:46 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
BadBlack....do you maybe have a pic you can post of the front grill with headlight door up?
Re: For the 68/69/70 Charger Owners out there [Re: Pyper70] #371826
07/12/09 06:18 PM
07/12/09 06:18 PM
QLD Australia
Keith Black® Offline
QLD Australia
Do you have part numbers/manufacturer of the H4 Angel eyes????
I am doing the same! thx!
Darren Beale
Keith Black Racing Engines®
Re: For the 68/69/70 Charger Owners out there [Re: Keith Black®] #371827
07/13/09 08:33 AM
07/13/09 08:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hummm...I still don't have mu headlight buckets in yet... I was thinking of using the pass side like a ram air. drop the high beam out and run a cold air duct right to the 6-pack.
Coming soon!!!!
Re: For the 68/69/70 Charger Owners out there [Re: Mr.Yuck] #371828
07/13/09 09:54 AM
07/13/09 09:54 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
but when you want the cold air you have to raise the headlight door which means your headlights will be on (even in the daytime) unless you hook up a relay to have the doors open up from the electric motor on a separate circuit.
I miss the electric motor from my 70. Both doors would open up at the same time but with my 69...she winks one at a time opening and closing....bit of personality for all the pretty ladies out there...(even with a vacuum assist motor)
Re: For the 68/69/70 Charger Owners out there [Re: Pyper70] #371829
07/13/09 10:03 AM
07/13/09 10:03 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll pull the bar and leave the one door open. Just for the track...not for daily driving.
Coming soon!!!!
Re: For the 68/69/70 Charger Owners out there [Re: Pyper70] #371830
07/13/09 10:27 AM
07/13/09 10:27 AM
badblack68 Offline
badblack68  Offline
I`ll try and get the wife to take a pic. Her camera is a whole lot better than mine.
