Re: Big block gear drive question
[Re: StealthWedge67]
#369510
07/08/09 10:42 PM
07/08/09 10:42 PM
Posts: 798 Nebraska
FASTBACK66
mopar addict
mopar addict
Nebraska
Ended up deciding that I didn't want a cheapo part in a spot that if it goes bad, the whole motor is likely toast.
These aren't interference engines. I don't think your engine would be "toast" if it goes out of time. I am sure metal would scatter be it would still be rebuildable. Certainly not "toast". I am a little leary myself about using a off brand product but, hey, It's not permanent and I can change it out if I don't like it.
Vinny
[Re: FASTBACK66]
#369511
07/08/09 10:43 PM
07/08/09 10:43 PM
Posts: 18,389 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Has anyone ever installed a gear drive on a big block Mopar before? This is my first and need advice. First off before anyone says anything, I am already sure it's going to be loud and annoying. That said, I am installing it anyways.
So, my question is, on the middle set of "idler" gears, do the big thicker areas go to the front(timing cover)side or do they face the block side. My instructions suck and not very specific. I have a pic of it installed with the thick side facing front (timing cover)side. I think it may go the other way though.
Thanks,Vinny
* Slide idle gear half way in between both gears with the larger gear on the passenger side and the longer axle toward to engine block.
Dont worry about the slinger. Its not needed.
