Page 2 of 5 1 2 3 4 5
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365497
07/05/09 02:30 AM
07/05/09 02:30 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Only real problem with what you are wanting to do is that you are putting WAY too much stock in MP crap. This site and others has so much more and better info, I can't figure out why you are still looking at their stuff for anything other than a laugh.
Seriously, several guys have posted exact part numbers and experiences- that is worth far more than MP telling you what THEY think will work for YOU, and conveinently they make those very things...
I also don't think the 3" exhaust will be worth the money spent with manifolds. Extude honing would help but for the $$$$$ you could just run some NICE headers, see better gains overall(except nonstock looks) and be done with it.
I want my fair share
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: SomeCarGuy] #365498
07/05/09 02:49 AM
07/05/09 02:49 AM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
Because I feel that the 280 grind cam is really respectable. I've spoken to two different guys who have built every type of mopar motor you can imagine way back in the 60's till now. There is nothing wrong with a 30+ year old cam design. If it works it works. I'm sure comp cams and lunati voodoo cams are great, but the main thing I've heard with comp is that they're having trouble with flattening cam lobes and lunati just changed hands with a different company. At least with the mopar brands its a 3 decade proven technology. Now I do plan on talking with Hughes as well. I haven't spoken with anyone from mopar performance. I'm not here to dog anyone using these brand cams, this is just my opinion.
The idea here is a simple street car that I'm sure can easily pull a mid 13 at the strip. Its not a race car and I shouldn't have to complicate the choosing of a cam because I will probably not notice it on the street. The only time you notice any great changes is if your drag racing, so why get down to the nitty gritty with different name brand cams? Comp cams basically took the MP designs and made slight changes and slapped on the name "Mopar Purple Plus". Thats just my 2 cents
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365499
07/05/09 02:58 AM
07/05/09 02:58 AM
Kirkland, Washington
Pacnorthcuda Offline
Dark---
I ran the .474 280 on a 440 a few years back, even got a best of 13.1 in a low compression 3500 lb cuda, thats not bad.
BUT, Compare it to my current cam--the 60303 Lunati that is a .494/.513 (if memory serves) and approx 268/272 degrees. Thats significantly more lift with a little less duration, meaning the cam is snapping the valves open and closed MUCH faster. That gives you significantly better breathing (and we all know its all about maximizing airflow) since the when the valves are open they are OPEN (and closed for that matter)
Thats old school vs. modern grinds. Duration doesn't make power--LIFT does (again airflow).
You've got those wonderfully fat lifters--use em!
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: Pacnorthcuda] #365500
07/05/09 03:13 AM
07/05/09 03:13 AM
San Antonio, TX
San Antonio, TX
Thanks for the input cuda.
The problem is nowadays there are just so many cams to go with that it just seems easier to go back to basics rather than complicate the decision with advanced technology. My thinking was that the MP284 might be a little too radical to deal with AC and a 4 speed and could take away from driveability. Thats why decided to go with the MP280. And I figured that cam along with those new 440source stealth heads would be a pretty nice set up in a 383 putting out 9.5:1 CR. My roadrunner had all the luxury options of a GTX while having all the performance options the Roadrunner line had to offer. So I'm not going to replace all the motor parts because it's an all numbers matching origional car. That is why I'm trying to keep this relatively simple.
I'm open for opinions, just don't want to be bashed on cause I have a different opinion than everyone else.
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365501
07/05/09 03:24 AM
07/05/09 03:24 AM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
Fine its respectable but still 30 yrs old. A newer cam may get you those numbers but not an older one with that set up you have. Dont waste ur time on the manifolds with 3 inch they wont flow enough to take advantage of the size in the first place. And just because it says mopar performance means nothing nowadays.
'71 383HP FJ6 Charger SE
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: 71 FJ6 Charger] #365502
07/05/09 03:37 AM
07/05/09 03:37 AM
San Antonio, TX
San Antonio, TX
The name means nothing to me, just the proven design that was used. What is wrong with using the hi-po manifolds? I know they're not as good as a header but they must flow pretty good because chrysler used them on all their high perf. motors.
Random question, how old are you guys?
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365503
07/05/09 03:49 AM
07/05/09 03:49 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The fact that a bunch of guys with probably a collective 100+ years of experience are telling you to go in a different direction ought to give you pause for thought.
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: 64Post] #365504
07/05/09 04:01 AM
07/05/09 04:01 AM
San Antonio, TX
San Antonio, TX
So does anyone use the MP cam now? And how many of you guys actually used one of these cams in the past, minus those who provided a direct experience (Thanks again). I want opinions from people who have actually used the MP cam, not people who have never used it telling me that its a 30 year old design. Another thing is that not every guy who owns a mopar built their motor perfectly. It's easy for someone to put in the wrong pistons, intake, carb, etc. and blame it on the camshaft.
And if the MP products are so bad, then why are they still manufacturing and selling them? There must be consumers out there who think their products are worth it.
Somebody please tell me a simple issue of why the MP cams are so bad. Is it too much overlap, lift, duration, or was the mopar world tired of MP cams and decided to just go and try other things?
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365505
07/05/09 04:25 AM
07/05/09 04:25 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Let's put the cam thing aside for the moment.
I just did some quick background on the ET of your car in stock form from a couple of internet sources and came up with 14.5-14.8. Now, how are you going to shave 2 seconds off that ET using nothing more than a stock-rebuilt 383 with a slightly hotter cam?
My point is, regardless of whatever cam you go with, you're not going to hit your target ET with it.
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: 64Post] #365506
07/05/09 04:37 AM
07/05/09 04:37 AM
San Antonio, TX
San Antonio, TX
If you read everything else I posted its not a stock rebuilt 383. The only thing thats gonna be stock is the block itself and the hi-po manifolds, thats it.
I already listed everything that won't be stock such as the stealth aluminum closed chamber heads, the performer rpm or M1 dual plane intake, the carter comp carb, raising the CR to 9.5:1, converting to a 3.55 gear. I dont know how in the world all of this is a stock rebuild for a 383. The only draw back to the whole set up is keeping the AC pump. Other than that I have manual brakes so vacuum doesn't mean a thing to me and a 4 speed which means no torque converter issues either.
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365507
07/05/09 09:48 AM
07/05/09 09:48 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you are going to stay with the small cam don't waste your money on stealth heads that will be starving for air on the small cubes and stock manifolds
Gus
64 Plymouth Savoy
Dana 60
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365508
07/05/09 10:00 AM
07/05/09 10:00 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I'm willing to bet I'm one of the guys who has ran the MoPar Performance cams the MOST on these forums... I've ran maybe 25 to 30 of them over the years in different cars. Most were the 4120235 484 grind in big blocks, mainly 440s.
I like the 484 cam.
I've tried a few Comp Cams over they years, I like them too.
The ONLY brand camshaft I have ever seen troubles with to be honest was the Sig erson cams in 440. My buddy ran them, he loved the performance but he had many go flat, the front of two cams broke at the dowel pin, it was weird. We stopped using them.
I've never had any troubles with MP cams and I've ran many.
CrAzYMoPaRGuY
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CompSyn] #365509
07/05/09 11:06 AM
07/05/09 11:06 AM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
From what I understand, when running factory exhaust manifolds, you’re better off with a 112-to-114 centerline.
Also, as already mentioned in this thread, go with a custom cam for your application.
In my 383, I’m going with a Mr. SixPack custom grind from Engle Racing Cams which is designed by Bob Karakashian. The cost is a bit more than an off the shelf cam but worth it. $235.00 to your doorstep and that dose not include lifters.
But that cam has bone stock 440-6s running in the high 11s on factory polyglass tires. You might be able to get the ETs you’re after with you're 383.
You can give Mr. Karakashian a call and he’ll talk it over with you.
Mr.6Pack Racing Engines - link
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: 68DART360] #365510
07/05/09 11:50 AM
07/05/09 11:50 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Take a look at some of the smaller Crower cams. They have a 112 LSA and good lift/ duration for a street /strip car. I run 12s with a stock converter (1800 stall ) in a 4000+ LB 71 Charger with a stock thermoquad and 355 rear. Also the performer rpm is a good intake but very tall and may not fit under your hood with you stock aircleaner (It did not on my car )The holley intake with a thermoquad is a killer combo.
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365511
07/05/09 01:53 PM
07/05/09 01:53 PM
michigan
black64 Offline
black64  Offline
michigan
My 383 was like yours except mine was auto in a cuda. I ran the lunati 00032 bracket cam which is a .480 lift 292 advertised duration 230 @ .050 and had LSA of 109 I had 10:1 compression, reworked 906 heads, and stock manifolds, and a 750 cfm edelbrock (should have used 800 AVS instead). I had to go with headers to get the engine to breath and a 2800 stall convertor. The cam was good from 2500 on. My gear was 323 but could of used at least a 373 or 391. Idle was good with alot of lumpy idle but good with my convertor or in your case it should do fine with the 4spd. The car had all the power I wanted from out of the hole to top end. I know the performer rpm or the holley street dominator are better but I used the performer since I had it already when I rebuilt the engine.
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365512
07/05/09 02:13 PM
07/05/09 02:13 PM
Canada
Canada
I missed this!
I'm an "old enough to know better, young enough to do it again and again, and again" ..... kinda guy!
CrAzYMoPaRGuY
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CrAzYMoPaRGuY] #365513
07/05/09 02:15 PM
07/05/09 02:15 PM
I missed this!
I can REALLY relate to that!
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: Pacnorthcuda] #365514
07/05/09 02:52 PM
07/05/09 02:52 PM
San Antonio, TX
San Antonio, TX
Does the LSA play that big of a factor when using either headers or manifolds? The LSA on that 280 grind is 110* but I know that new 284 MP cam has 114 LSA along with the previous one that had 108* or so LSA.
That sucks that performer RPM intake doesn't clear cause I do plan on using the factory air cleaner. Has anyone used that M1 dual plane intake before? It looks kinda like the stock intake so I'm curious if the runners are larger and better air flow?
PS I'm the young gun
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CurYellowBird] #365515
07/05/09 03:10 PM
07/05/09 03:10 PM
Canada
Canada
I've never had a newer 484 cam with the larger LSA, but I assume it was done for drivability. Maybe somebody who has used one could chime in, I have only used the old 484.
The M1 intakes are good, I even have one on my motorhome. Better flow for sure, but it depends on which M1 intake.
I was a young kid working on cars and driving junk back in the late 70s!
CrAzYMoPaRGuY
Re: 383 cam suggestions (4 speed owners chime in plz) [Re: CrAzYMoPaRGuY] #365516
07/05/09 03:21 PM
07/05/09 03:21 PM
San Antonio, TX
San Antonio, TX
That's the funny thing I'm the only kid my age driving nothing but olders cars. Everyone else I know is driving imports. My daily driver is my 1980 Chevy Malibu that pulls mid 13's, gets 20mpg, and has the 3.73 posi.
The malibu is the only chevy allowed in the family, everything else is mopar.
