Flushing tranny cooler and convertor #364806
07/02/09 08:46 PM
07/02/09 08:46 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
The fellow that rebuilt my tranny says that parts of the clutches that failed could be in both and I should flush them.
How do you flush the cooler?
Filling it up and blowing out with compressed air a couple of times?
For the convertor he is recommending rising out with Varsol and spinning the convertor around a few dozen times and repeating with fluid and again with varsol.
Is this right?
Re: Flushing tranny cooler and convertor [Re: GwaiiEagle] #364807
07/02/09 09:04 PM
07/02/09 09:04 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
you can get a can of cooler flush that hooks up to the cooler lines or if you have an old electric fuel pump you can use it to run some mineral spirits through them and then blow them out with air. As far as the converter it is a sealed unit and you cant really get them flushed very good without them being cut open and cleaned.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Flushing tranny cooler and convertor [Re: dusturbd340W5] #364808
07/02/09 09:06 PM
07/02/09 09:06 PM
As said a can of cooler flush for it and my old shop had a machine to power flush converters but EPA regs put an end to that
Re: Flushing tranny cooler and convertor [Re: RapidRobert] #364809
07/02/09 09:09 PM
07/02/09 09:09 PM
Kissimmee Fl.
Kissimmee Fl.
Yeah we had one of those machines also but they didn't even do that great of a job IMO
Re: Flushing tranny cooler and convertor [Re: dusturbd340W5] #364810
07/02/09 09:11 PM
07/02/09 09:11 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
should I not trust the convertor? I do have another I could use.
Re: Flushing tranny cooler and convertor [Re: GwaiiEagle] #364811
07/02/09 09:28 PM
07/02/09 09:28 PM
I'd be afraid of it & you have another one & the trans IS freshly rebuilt. No need to be taking unnecessary chances with this much into it
Re: Flushing tranny cooler and convertor [Re: RapidRobert] #364812
07/03/09 12:02 AM
07/03/09 12:02 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Buy a new TC. You don't want any old friction material re-circulating.
Re: Flushing tranny cooler and convertor [Re: In_The_Pink] #364813
07/03/09 05:07 AM
07/03/09 05:07 AM
Woodbridge,CA
NAS Backyard Offline
Woodbridge,CA
Always use a new TQ with a new trans unless you know it's spotless. If you want to flush the system go to Walmart and get 2 gal of cheap Dex Merc, unhook your return line from the cooler, get a piece of hose that will reach a drain pan, have someone start the car. IN PARK,( or Neutral on MOPARS) let the fluid run into pan until it spits, shut off engine, refill, start, purge into pan, repeat, until fluid is clean, run till it spits, drop pan, change filter, refill. I just did it to my Olds last night. It will flush out everything. If you want to get REAL anal, raise the back of car and run through the gears. Good Luck.
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Flushing tranny cooler and convertor [Re: NAS Backyard] #364814
07/03/09 09:25 AM
07/03/09 09:25 AM
Kissimmee Fl.
Kissimmee Fl.
a stock mopar valve body does not circulate fluid in park that's why you check the fluid in nuet.
Re: Flushing tranny cooler and convertor [Re: dusturbd340W5] #364815
07/03/09 11:01 AM
07/03/09 11:01 AM
Woodbridge,CA
Woodbridge,CA
Your right, I forgot about that. My trans guy modified mine to circulate in Park. So I guess you would have to be in Neutral.
