OIL PRESSURE LOW #361798
06/29/09 04:36 PM
06/29/09 04:36 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Dodge D150 Stock 360la. My Oil pressure is really low on my gauge. usually at 50 psi but is now reading at half that or lower. and at idle the gauge doen't even move up. Just changed oil used valvoline sae 30 and a K&N filter. Changed the Copper Line and plugs leading to the gauge. It's weird it's not knocking or making any noises that would point to not getting oil pressure. What may be the cause?
Re: OIL PRESSURE LOW [Re: midnite360] #361799
06/29/09 04:44 PM
06/29/09 04:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take the filter off and see if it has oil in it. If not then fill it up about 1/2 way and try it again. It sounds like you lost your prime and it does happen occasionally.
Re: OIL PRESSURE LOW [Re: midnite360] #361800
06/29/09 04:44 PM
06/29/09 04:44 PM
Northern VA
1970440six Offline
1970440six  Offline
Northern VA
Eliminate any guessing with this and install an oil pressure gauge on the engine and check it. Better safe than sorry.
Re: OIL PRESSURE LOW [Re: 1970440six] #361801
06/29/09 05:07 PM
06/29/09 05:07 PM
Goodyear Arizona
Goodyear Arizona
Ok Thanks guy's I'll give this a try. I really hope my motor isn't going to take a Sh#$ anytime soon it's all I got LOL I'll let you know if it works.
Re: OIL PRESSURE LOW [Re: midnite360] #361802
06/29/09 05:27 PM
06/29/09 05:27 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Put on a cheap filter and see if the pressure goes back up. Just had the same problem with a fram Xtended Guard™ filter. Worth a try.
Re: OIL PRESSURE LOW [Re: mopars4ever] #361803
06/30/09 02:58 PM
06/30/09 02:58 PM
P
Paul_Fancsali Offline
P
Check the oil pickup for valve seals and related garbage bet its plugged I had that problem on my 79 and it will only get worse so pull the pan and get it down no big deal couple hours of work
