Re: 727 VB with shiftkit - TF1 or what shiftkit is that?
[Re: 6o4o]
#359855
06/27/09 10:13 PM
06/27/09 10:13 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
sounds a lot like a TF1 if so the kit came with a cardboard templet you use to set the pressure with.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 6o4o]
#359857
06/28/09 06:50 PM
06/28/09 06:50 PM
dusturbd340W5
Kissimmee Fl.
same template for both TF-1 and TF-2
[Re: dusturbd340W5]
#359858
06/28/09 06:51 PM
06/28/09 06:51 PM
dusturbd340W5
Kissimmee Fl.
also I keep the template and use it to set the PR spring on all rebuilds even bone stock ones
[Re: dusturbd340W5]
#359859
06/29/09 01:21 AM
06/29/09 01:21 AM
Posts: 2,273 Bern, Switzerland
6o4o
Bern, Switzerland
I just found my old TF2 instructions. There the TF1 kit is also covered: http://www.mopar.ch.vu/bilder_public/TF2/TF2_old_instructions.pdf The stock PR spring is used, setting is set as stock BUT the throttle valve is only cut on TF2 and it's spring is pink or yellow. In my VB the throttle valve is cut like on TF2 and the spring was silver/chrom. And it also writes to leave the 1-2 shift ball out on only TF2 kits. On mine that ball is missing. I also got no hole in the line pressure limit ball and the spring looked to be original. So I GUESS someone here didn't do his homework when installing the TF1 kit OR this is another kit that is similiar to the TFx kits...
