Re: 440 six pack - running hot - why
[Re: Challenger 1]
#356070
06/23/09 10:35 PM
06/23/09 10:35 PM
Posts: 533 Williamsport, PA
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
More details needed, shrouds? clutch fans?
new reproduction 26" fan shrouds on both cars. Both cars 26" radiators. Clutch fans on both cars however the six pack has a new Mopar Perf. clutch fan which if I remember correctly is a 5 blade fan and I have the origianl 7 blade clutch fan on my car.
[Re: Rob440Magnum]
#356072
06/23/09 10:45 PM
06/23/09 10:45 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
either he is developing much more heat (lean, bigger bore, clogged cooling passages), or he isn't shedding as much heat (WP, fan, radiator, shroud). Take the temp readings in as many places as possible and compare. Lower radiator hose, WP, Heater hoses, etc.
[Re: MNobody]
#356073
06/23/09 10:50 PM
06/23/09 10:50 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
What waterpump's?
not 100% sure, but I think we have the same ones new from Mancini Racing. Can't remember what model # or specifics. What information about the water pump would you want to know?
[Re: Rob440Magnum]
#356074
06/23/09 10:54 PM
06/23/09 10:54 PM
RapidRobert
what do his/yours plugs look like & he might pull his stat for 1 day. EDIT forgot about timing(his vs yours)MORE EDIT he might block his intake(like yours) & see if that equalizes things & if so then decide how he wants to get the choke to open properly(I'm betting on this last one)
[Re: Rob440Magnum]
#356078
06/23/09 11:03 PM
06/23/09 11:03 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Any other six packs out there with no heat riser, stock choke hooked up, and the heat crossovers on the valley pan open with their motors running hot?
[Re: Rob440Magnum]
#356079
06/23/09 11:21 PM
06/23/09 11:21 PM
Posts: 4,884 Michigan
MNobody
What waterpump's?
Some pumps have more fins on the impeller to move more water, i believe AC cars have 7 versus 5 on the non AC cars.
[Re: MNobody]
#356080
06/23/09 11:53 PM
06/23/09 11:53 PM
Posts: 10,177 Someplace you aren't
SomeCarGuy
Lots of stuff has been covered here.
First, what are the actual temps you are seeing? What gauges are being used?
Was his engine bored over more than yours?
I don't think the heat riser will make the diffeence you are looking for on his car. I don't think the choke will work a whole lot different blocked, mine is and the intake gets plenty hot once the car warms up. He could just wire it open and live with the poor cold running temper, it doesn't tae that long to warm up anyway.
Is his fan belt tight? Might just be a new belt that was put on at the rebuild time that has loosened up.
I want my fair share
[Re: Rob440Magnum]
#356081
06/24/09 12:00 AM
06/24/09 12:00 AM
Posts: 16,452 Canada
CrAzYMoPaRGuY
Canada
It could be anything, tune stands out to me, as well as various cooling parts, but since nobody has touched on it yet...
Has anybody thrown a block in a hot tank and actually CHECKED for silt etc at the bottom of the block? I have and have found some blocks packed with hardened debris. I used all sorts of tools to dig it out through the frost plug holes, I was amazed at what was left in some...
If all else fails it *might* be worth checking as a very last resort..? I have a feeling timing and carbs might be the first area to look at though...
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#356082
06/24/09 06:44 AM
06/24/09 06:44 AM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
both bored the same 30 over
Do you have a six pack? With your crossovers blocked does your choke still function properly?
[Re: MNobody]
#356084
06/24/09 09:19 AM
06/24/09 09:19 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
What waterpump's?
Standard pump has 8 blades,A/C has 6,keeps water in radiator longer with slower circulation.
[Re: Rob440Magnum]
#356085
06/24/09 09:20 AM
06/24/09 09:20 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
My timing is 13 degrees initial and the six pack is 15 degrees initial timing. We cannot go any higher or they ping on 93 pump gas.
Plugs are fine.
What are you recommending we try with the thermostat?
What is his and your TOTAL timing ? I ASSuME the shop that dynoed the engines recurved the dizzy's as needed ?
If the water temps are very close then it's not really running hot . because his crossover is open the intake is hotter on his engine vs. yours , plus the 6pack air cleaner is alot bigger than yours and will trap the heat coming off the engine.
Did you adjust the timing from what the dyno sessions were set at ? if so which way ?
[Re: JohnRR]
#356086
06/24/09 09:28 AM
06/24/09 09:28 AM
Challenger 1
Cincinnati, Ohio
Plugs are fine.
Yes he mentioned any more than 15 degrees initial it will ping, sounds like the dist is not setup right.
I run 18 initial and 34 total and my 440 six pak which runs great and stays cool even on 90 degree days with the AC cranking. I drove it for about a hour last Sun(90 degree day) and then pulled in the driveway and let it idle for another 15 mins and the temp stayed rock steady. BTW all stock cooling system.
[Re: Challenger 1]
#356089
06/24/09 09:40 AM
06/24/09 09:40 AM
JohnRR
U.S.S.A.
Plugs are fine.
That's what I'm wondering , if it was set up right on the dyno and they backed the timing off to stop the pinging then the TOTAL is not enough which will cause the engine to run hotter .
[Re: JohnRR]
#356090
06/24/09 09:44 AM
06/24/09 09:44 AM
Challenger 1
Cincinnati, Ohio
You mean not enough initial timing right?
[Re: 62maxwgn]
#356092
06/24/09 02:14 PM
06/24/09 02:14 PM
MNobody
What waterpump's?
Ahh thank's for the correction on that i wasn't sure but i knew they were different.
[Re: MNobody]
#356093
06/24/09 04:37 PM
06/24/09 04:37 PM
Posts: 7,506 Az
Crizila
Az
R U both running the vacuum advance on your distributors?
Fastest 300
[Re: Mopar-Al]
#356097
06/24/09 07:53 PM
06/24/09 07:53 PM
JohnRR
U.S.S.A.
wonder if 1 block has thinner cylinder walls
He still hasn't answered if his friends car is ACTUALLY OVERHEATING or if the complaint is the heat coming off the engine ?
[Re: Rob440Magnum]
#356098
06/24/09 08:00 PM
06/24/09 08:00 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Rob,.....I have a 440/6 THAT use to run hot in my Daytona, professionaly built by a "known" race shop down south, dyno's at 450 HP, 030 over, KB forged pistons, roller valvetrain 520 lift, 10:1 compression, yada,yada,yada....15 degress initial, almost 40 total by 2500 RPM,...solid factory blade fan, factory shroud,brand new 26" High Effienciency micro tube 5 row radiator fan and shroud properly spaced, plus being a wingcar, has a complete rubber "flap work" of sheilds that boxes in the radiator to the front grille, plus foam seals around the radiator,.....tried everything when I first put this car together, to try and keep it under 250,....It was fustrating, confirmed running tempertures with infrared, and thermocouple probes to calibrated independant equipment in hopes the "rebuilt" factory gauges were wrong,... NOT!..... plus the car puking green stuff everwhere I went! kinda confirmed it! .... tried timing changes, thermostats, no thermostats, fans, spacers, clutch, solids, 5-7 blades, etc, shroud spacing, jetting/fuel enrichment,....you name it,..... running factory HP manifolds the heat riser is removed, the exhaust is not restictive,...Chambered 2 1/2" pipe, exiting thru factory tips, no mufflers ....intake crossover is functional,....after several months playing all the combos, and really no improvements,....kinda stumpled apon this,.....dumped the Prestone green stuff,....Completely flushed the system,...replaced with ZEREX G-05, clear in color, not sticky,...and it's not that DEXCOOL crap that GM's use, that clog/rot your system,....I used the Zerex G-05 with 50/50 water mix, and 8 oz bottle of Redlines waterwetter (avaliable at Autozone),......with no other changes, other than the fluids, the car went from running 220-250, to 190-200 consistently (running a 180 stat) and no more puking green after a run! PS, the Zerex G-05 is designed as a replacement for cars running the "greenstuff",....says so on the bottle!.....I tried the Zerex first, was worth about 20 degrees off my heat, the waterwetter took another 20 degrees off......I've been running that combo of "juice" for 5 yrs now, no cooling issuses/problems, even in bogged traffic, super hot days, high RPM runs, etc....I do flush, and replinesh the system every year Mike
[Re: DAYCLONA]
#356099
06/24/09 08:20 PM
06/24/09 08:20 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Technically it is not overheating. The needle on his restored rallye gauges runs at the top of the safe zone a little below the line that is located just below the H.
[Re: Rob440Magnum]
#356101
06/24/09 08:42 PM
06/24/09 08:42 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Ok so what thermostat is he running? what are his actual temps? all things being equal he might be a tad lean. Your 4bbl probably uses/flows more gas then his center carb. I bumped my centers up to 64.
180 or 185 degree thermostat. We both have the same.
I will have to check what he has written down but I think his center carb is 64 or 65.
This weekend we will mess around with some of the ideas everyone shared. I cannot remember the different temps we got with my laser temp gun at the diff locations, but we will try that and compare versus my car at the same locations and let everyone know.
Thanks, Rob
[Re: RapidRobert]
#356105
06/29/09 06:26 PM
06/29/09 06:26 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Guys, we have not had a chance to try any of your suggestions yet. It has been raining a lot in PA.
Question:
What is the correct location of the clutch fan inside the fan shroud. If I stand to the side of the car I can see approx. 80% of my fan blades with only 20% inside the shroud. I can see only 30% of the fan blades with 70% inside the shroud on the six pack motor.
Which is correct?
Thanks, Rob
[Re: RapidRobert]
#356107
06/29/09 06:35 PM
06/29/09 06:35 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Any thoughts?
I'm not sure on this but I think at least 2/3 in. 20% in for sure is not enough, yes add a spacer when you find out the correct amt
My car is the one that does not run hot. So do you think mine would run cooler if I made that change or should I just let well enough alone?
I just looked at my buddy's six pack and his is about 2/3rds in so I guess his is correct.
[Re: RapidRobert]
#356108
06/29/09 06:42 PM
06/29/09 06:42 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Any thoughts?
start with getting a 50/50 spacing in the shroud, 75 % in, has the same effect as 75 % out, from what I've found with playing with wingcars, buy placing a sheet of typewriter paper on the grille at idle, and playing with nothing but a handful of spacers with the same car, 50/50 seemed to hold the paper to the grille, where as to far in, or out wouldn't hold the paper to the grille,....unscientific perhaps?
[Re: Rob440Magnum]
#356112
07/19/09 10:51 PM
07/19/09 10:51 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Temps comparison done today on both cars:
six pack: 205 degrees - top of radiator 230 degrees - intake manifold area 210 degrees - water pump area 215 degrees - block
my car 4 bbl: 175 degrees - top of radiator 160 degrees - intake manifold
Can't remember the rest of the numbers. I should have written them down but the six pack was much much hotter than mine in every comparison.
When I first popped my hood my radiator temp (4 bbl car) was 165 degrees and then it moved up towards 175 as it set there for a little. Do you think that is because my fan blades are too far out and not 50-50 within the shroud?
The six pack car the fan blades are 50% in and 50% out of the shroud, so that looks to be ok.
Thanks, Rob
What do you guys think? Is the six pack running too hot? Is there concern based upon those temps?
[Re: Classof70Chally]
#356115
07/20/09 01:54 AM
07/20/09 01:54 AM
RapidRobert
More thoughts. On the hot one(the six pack) I'd (1)wire the heat riser open & R&R the intake & block the passage & try it out (2) R&R the clutch fan w a fixed blade one & try it out (3) pull the stat & try it out (4) rejet the center carb 4 sizes up & try it out (5) bump the initial up 5-7.5 degrees & try it out (6) jack up the front end high, take out the stat & rev the eng several times to possibly push an air bubble up & out just like burping a baby(hey it's after midnite here).(7) have a radiator shop check that there are no combustion gasses in the coolant
[Re: Rob440Magnum]
#356116
07/20/09 03:36 AM
07/20/09 03:36 AM
Posts: 306 Texas
bogusracer
Texas
Thanks, Rob
Take your lazer temp gauge and measure the temp of the exhaust manifolds immediately after having cruised the car for 10 to 15 mins. at approx. 55 mph. Do a comparison of the 6 pack vs. the 440 mag. car. I think you'll find the 6 pack is running in a lean mode at cruise and most likely at idle also causing a much higher exhaust temp reading than the 4 bbl. 440. My experience with a stock cammed 6 pack has been to go to # 66 jets on the center carb with a #65 power valve. You'll also have to pull the outboard carbs base lead plugs to get to the carb idle screws at the front of the carb baseplates. I'd probably start at about a 1/2 turn out from a closed position on the outboard carbs. (Be careful trying to adjust these idle screws as they may be stuck and forcing them will break them - you may have to spray some type of solvent like "Let-go" to free them up) This will put you around 2-3 turns out on the center carb idle adjustment screws. You can "Balance" the idle screw adjustments on the outboard carbs by placing your finger tips over the Idle bleed holes with the car idling. (the idle bleed hole are visible when looking down the throat of the carbs forward of the booster venturies (There will be 2 bleed holes at each venturi and you can ID them by looking at them and they look like small brass plugs with holes drilled thru them)) With the engine running at idle, cover both outboard bleed holes with your fingertips on one of the outboard carbs and if you have it adjusted properly there should be no noticable change in the RPM of the engine at idle. If the RPM increases then you are too lean so open up the idle screw a little on the outboard carb you are checking. If the rpm drops then close the screw some. Adjust the outboard carbs only this way, making sure you keep the total idle speed in the 700 to 800 rpm range after each adjustment. (a timing light with a digital tach readout is a great help when doing this). Then do the 2nd outboard carb the same way. Once you have the ouboards adjusted then adjust the center carb to achieve the proper idle speed. This should balance the carbs at idle and stabalize the temp at each exhaust port so you don't have any cylinder running too lean at idle and causing excessive heat. If you are running anything other than a stock cam, then check your engine vacuum at idle and install a power valve that is at least 1/2 the value of the vacuum reading. ie. vacuum reading of 9 in. vacuum then run a 4.5 power valve or even a 4.0. This will get you out of an over rich issue at idle on a hotter than stock cam and eliminate the black smoke, burn your eyes issues from the exhaust on a non-stock cammed sixpack. Also if you have an engine backfire on a sixpack it generally will blow the power valve and you'll run rich at idle and pour black smoke out the exhaust at idle that will burn your eyes. (Jeg's sells a power valve saver for Holley Carbs that keeps this from happening and it's a breeze to install on the center carb). Doing these things should help you with your running hot issues. Also using a Fel Pro #1215 Intake Valley Gasket with the heat crossover blocked will help too. Just wire the choke flap open and about 2 pumps on the acellerator pedal on a cold start up should get it too fire off pretty quick. Once the engine is hot it should start pretty easy.
Anyway I hope this helps you with your issues. Feel free to PM me and I'll get you a phone number to contact me if you need any clarification on this.
Good Luck and Mopar to Ya'
Jeff - a.k.a.- Bogusracer
[Re: Rob440Magnum]
#356118
07/20/09 07:36 AM
07/20/09 07:36 AM
Posts: 306 Texas
bogusracer
Texas
One more thought, the six pack cars warms up 3 times as fast as the 4 bbl car. The 4 bbl car has to drive 3 times as far as the six pack car to get to full operating temp.
I don't know if this information means anything to anyone?
Potential issue with the thermostat not opening all the way on the Six Pack car. Allowing it to heat up faster.
Possible Non A/C water pump impellor with eight blades vs. an A/C water pump impellor with 6 blades. Use the A/C one as it moves the water a little slower allowing the radiator to transfer heat better and cool the water more when running vs. a Non A/C water pump.
Or -
Possible difference in compression ratios:
Six Packs had a 10.5 to 1 factory compression ratio (1970 & 71)
440 Magnums had a 10.0 to 1 (67 to 69) and a 9.7 to 1 in 1970 & 71.
Running todays lower Octane fuel could cause a difference in the running temps with the higher compression ratio engine especially if you have different timing curves on the distributors and different initial timing on the 2 engines. Also be sure the R/S exhaust manifold has the heat control valve fixed to be open all the time. You may have to validate it by disconnecting the exhaust pipe to physically check that it is open. Myself I just cut the flapper valve out of the manifold and leave the rod running through so it looks OEM but has no restriction.
Good Luck
Jeff - aka - bogusracer
[Re: bogusracer]
#356119
07/20/09 10:32 AM
07/20/09 10:32 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
BINGO
Just went thru this with my 71 Bee - Would run 200-210 even on the hwy at cruising speeds this spring
4 core 22" radiator and all componets had worked perfect last spring/summer when i popped in a new 180 degree Mr Gasket high flow thermostat
This spring after a few trips the temps started running a little higher then i liked , 200-210 so i looked at coolant mixture / straight water and water wetter blah blah blah - Was just about to pull the radiator for a flush when i called and found locally a Milodon 160 degree high flow thermostat (They didnt have the Milodon 180 high flow in stock)
Popped her in and WOW - Yesterday took us 45 minutes to move two blocks for a local 1,200 count car show and not a degree over 160 on my Auto Meter Ultralight Gauge - Flawless on the hwy cruising at 3000/3500 Rpms also for an hour with my 3:91 gears - I would have been screwed if i still had the Mr Gasket in there yesterday
Sometimes its the simple things that are overlooked - That My Gasket Thermostat had one summer on it when it started to go south this spring - I posted under another thread about Mr Gasket a few days ago
My point is like mentioned - Thermostats due fail even when new or slightly used
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#356120
07/20/09 01:52 PM
07/20/09 01:52 PM
Posts: 306 Texas
bogusracer
Texas
BINGO
Just as a followup to the above testimony, you can check the thermostat by putting it in a pan of water and heating it up on the stove to see how much it is opening. Also check the thermostat housing to make sure there is no interference with the functioning of the thermostat when installed, and check the thermostat housing gasket for interference upon installation.
One other trick to do especially if putting together a new motor or a rebuild is to drill a small 1/16 to 1/8 Inch hole through the thermostat to allow air to bypass through when filling the radiator with water/antifreeze. This will allow the block to completely fill with water/antifreeze and not trap air in the block causing a potential overheating issue on run in with a new/rebuilt engine. It will not affect the operation of the thermostat if done correctly.
Good Luck.....
Jeff - aka. Bogusracer
[Re: Rob440Magnum]
#356122
07/20/09 08:19 PM
07/20/09 08:19 PM
RapidRobert
so definitely cooler. What does that tell you guys, bad t-stat? He bought a new t-stat
(1)thats real good news. (2) yes (3)I'd push it open several times w your fingers to make sure it's not stuck & suspend it in a pot(not touching the bottom)along w a candy thermometer & see if it opens all the way(what the prior stat problem was) and note what temp it starts to open & what temp it's open all the way as you bring it close to a boil & I would drill the 1/16" hole to aid getting the air out. EDIT while you are at it suspend the old stat also & see how it acts
[Re: Rob440Magnum]
#356124
07/20/09 08:44 PM
07/20/09 08:44 PM
RapidRobert
anywhere in the flat part roughly halfway in from the edge, just not so close to the edge that it interferes w the gasket. Set it in the housing and you want it so that it's location lets it flow & doesn't interfere with either the outer gasket or the actual thermostat mechanism in the center
[Re: Rob440Magnum]
#356125
07/21/09 03:16 AM
07/21/09 03:16 AM
Posts: 306 Texas
bogusracer
Texas
Here is what we tried tonight. We removed the 180 degree t-stat and ran it without a t-stat. The car ran much cooler. I forgot my laser temp gun so I could not measure the exact temp, however the car's factory temp guage was reading much lower. I could hold my hand near the engine all night without it feeling like my skin was going to melt, so definitely cooler.
He bought a new 180 degree t-stat from NAPA today and was going to put that on tomorrow and then see how it runs.
Rob,
I agree 100% with Rapid Roberts followup responses, and I appreciate his added input. You might however want to consider a 160 degree thermosat, just to keep the engine as cool as possible as quickly as possible. Additionally, just a heads up though concerning the jetting I mentioned on my earlier post. I would still run the test after cruising the car (Once you have the thermostat/excessive heat issue resolved). and make the appropriate jetting mods, since the Six Packs in stock form were jetted lean from the factory and you'll see a definite decrease in exhaust gas temp at cruise by going to the # 66 jets on the center carb, and balancing the idle on all 3 carbs. Throttle response will improve slightly too.
But the choice is yours on that one.
Anyway I hope I've been of some assistance in troubleshooting your problem along with all the other guys valuable input.
Good Luck and keep us posted.
Jeff - aka. - Bogusracer
[Re: bogusracer]
#356126
07/21/09 07:00 AM
07/21/09 07:00 AM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
If we put the 160 t-stat in, the motor will not heat up anymore than about 160 degrees correct?
I've heard you lose power if the motor runs too cool and that it may not be good for the motor long-term if it does not run hot enough. This is a street car not a drag car.
Any follow-up comments on my reply?
Thanks, Rob
[Re: Rob440Magnum]
#356128
07/21/09 07:54 AM
07/21/09 07:54 AM
Posts: 15,478 the boonies
aarcuda
the boonies
Thanks, Rob
if you put a 160 in, the thermostat will open and try and maintain a 160 degree temp. but, if your cooling system is weak or your car is way too hot so the cooling sys cant keep up, it wont stay at 160.
imo, 160 is way too cool. 180 is the min for me. you said it ran cooler without a thermo. the 180 may have been bad. I'd try another one
[Re: bogusracer]
#356129
07/21/09 08:50 AM
07/21/09 08:50 AM
RapidRobert
I would highly suggest a 180 and read the 160 vs 180 stat thread on this page which will put you in a better (informed) position to make your choice.
[Re: RapidRobert]
#356130
07/23/09 07:00 PM
07/23/09 07:00 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Last night we drilled 1/8" hole in the new 180 stat and installed. When we started adding coolant we noticed crap floating around in the new radiator (less than 1,000 miles on new radiator). So we took off the lower radiator hose and drained the coolant and tried to flush the radiator with a hose. Refilled and took for a ride. The motor ran cooler than it did before we changed the stat but not as cool as when we ran with no stat.
We are going to do the following on Saturday:
1. remove stat again and put some miles on it to try to move any crap that may be in the block or cooling system and hope it ends up in the radiator. Then Sunday, remove radiator and take to a radiator shop and have it professionally flushed. 2. drive the car at a steady speed on the highway for 10-15 mins and compare the exhaust manifold temps to my 440 4 bbl to see if the six pack is running lean. What temp would you consider too hot for the exhaust manifolds that would lead you to beleive a lean center carb? 3. when we turn the car off, make sure the fan does not keep spinning more than 1 or 1 1/4 turns. If so, I am told the clutch is bad on the clutch fan. (any comments on this to confirm how to test)
What are your thoughts while the radiator is off to hook up a wet/dry shop vac to the bottom radiator hose coming out from the motor. Will this accomplish anything?
Any other thoughts or suggestions we should try while we are at it?
Thanks, Rob
[Re: Rob440Magnum]
#356134
07/25/09 04:23 PM
07/25/09 04:23 PM
bee1971
Sobieski Wi
Today we removed the stat. Looked in the radiator and there was an orange thing floating around. We were able to extract it and it was an orange rubberized or silicon glob about 1/4" by 1/4".
Hate to say it - But there could bee a 100 more of those plugged up inside your radiator core Permatex copper silicone
First things first - Pull the radiator and bring it to your radiator shop or at least call them and see what they want to do
Original factory radiator ? Has it ever been re-cored ? Professionally cleaned or boiled ?
Silicone in the radiator is not a good sign
[Re: bee1971]
#356136
07/25/09 05:53 PM
07/25/09 05:53 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Hate to say it - But there could bee a 100 more of those plugged up inside your radiator core. Permatex copper silicone
How & where did that come from?
The radiator is a new YEARONE radiator installed when the car was restored and motor rebuilt. Less than 1,000 miles ago.
[Re: Rob440Magnum]
#356137
07/25/09 05:55 PM
07/25/09 05:55 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
I would have the rad flushed(along w the rest of the system) to get that crap out of there.
I know you pull the radiator and take it to a radiator shop, but how do you flush the rest of the system?
[Re: Rob440Magnum]
#356138
07/25/09 05:57 PM
07/25/09 05:57 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Can you sub in a fixed blade fan for a test and WHERE in the shroud is your fan located?
It's 1/2 in and 1/2 out of the shroud. I'll have to check to see if he has a fixed blade, I know I don't.
[Re: THESHAKERPROJECT]
#356140
07/25/09 07:40 PM
07/25/09 07:40 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Did you use a HIGH FLOW robertshaw type thermostat??? Milodon also sells this type of thermostat but my local NAPA did not sell them. Also use more water and less antifrese and the water wetter as mentioned by Dayclona, Try a Milodon or Edelbrock pump (440source sells them too) if you really want to run cool and check your cap for holding pressure.
Bought a 180 stat from NAPA so I guess that is not a high-flow stat. Where do I buy a high-flow stat?
We put Prestone 50-50 mix in, no water added.
How do you check the cap for holding pressure?
[Re: Rob440Magnum]
#356141
07/25/09 07:48 PM
07/25/09 07:48 PM
bee1971
Sobieski Wi
I didnt realize the radiator was new - Sometimes you go with the flow , no pun intended , then going back to the original posts if you already mentioned
Anyways
How much silicone did you use on the water pump housing gaskets - How much silicone on the actual water pump itself and thermostat housing gasket
It would definetly take alot to break loose to plug up a brand new radiator so with that said next
[Re: bee1971]
#356142
07/26/09 12:29 AM
07/26/09 12:29 AM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Well this is a whole lot of work....but....Yours is not overheating...his is. Swap parts from yours to his. There is no better test than the last line on a diag flow chart...swap with a known good component. Sorry Curt
Oh yeah...THAT'S gonna leave a mark!
[Re: Curt]
#356143
07/26/09 12:36 AM
07/26/09 12:36 AM
RapidRobert
The fan does need to be farther in
[Re: 1_WILD_RT]
#356146
07/26/09 07:48 PM
07/26/09 07:48 PM
Posts: 328 Missouri, U.S.A.
JSSuperbee
Missouri, U.S.A.
As you may recall, I too am having an overheating problem with my 383. No one has said anything about the post entered by DAYCLONA on June 24 about removing the Prestone antifreeze and substituting with ZEREX G-05. Seems as though he's done everything to eliminate the problem and then the G-05 solved it. Could it be that easy? Anyone got any thoughts on this?
James Stinebaker
[Re: JSSuperbee]
#356147
07/26/09 08:16 PM
07/26/09 08:16 PM
Posts: 18,153 Mass
DAYCLONA
Mass
James, my daytona had hot running situations, only a few times, it really lost it and puked,....I'd run a constant 200-220 moving around town, if I got stuck in bumper to bumper crawling traffic for more than 10-15 minutes, the temp would rise to 240-250 real quick!.... hyway, it would drop to 200 degrees,.....and I played with all the combo's, EVERYTHING was new, as this was a fresh total restoration/build,....carburation was addressed (6pak), timing, cooling system, everything,......the Zerex G-05 was a guess at best,.....but with no other changes, other than flushing the system, the car went from running in the 200-220 in traffic, to 180-200, running a 50/50 mix G-05/water,....after reading some mag reports on what waterwetters worked and what didn't, I went with the Redline product, 8 oz bottle to the 50/50 G-05,.....that was good for a 20 degree drop, now I have the opposite problem, waiting for the engine to warm up!,.....I took the Mellon out for a ride yesterday, it was quite humid, temp was around mid 80's, in the past it would hit 200+ easily cruising even at that temp,.....I was lucky if I saw no more than 180,....and I'm running a 180 thermostat, and I have a 5 row micro tube radiator, shroud, solid blade factory fan, plus wingcar seals through out the nose, and radiator channeling air to just the radiator
I'd highly recommend the G-05 Zerex brand and Redline waterwetter, it's not to be confused with Dexcool, which is junk, the Zerex is intended as a replacement for "green juice" users
[Re: DAYCLONA]
#356148
07/26/09 11:01 PM
07/26/09 11:01 PM
JSSuperbee
Missouri, U.S.A.
I've got Prestone in it now. I added water wetter...didn't help at all, not one bit. Because I'm desperate (I've tried every trick in the book like you did), I'm going to drain the Prestone and substitute the Zerex G-05 and add another bottle of water wetter. It just seems too easy and no one reading this thread has commented on this procedure one way or the other.
James Stinebaker
[Re: JSSuperbee]
#356149
07/27/09 12:09 AM
07/27/09 12:09 AM
SomeCarGuy
It won't hurt to try that.
Hey Dayclona, I would look for a clutch fan that would fit the melon. Should free up some power and not run too hot now that you have things under control. My car is actually running better with a stock temp 190 high flow stat. Now it maintains 185-190, before it was running 170-180.
[Re: SomeCarGuy]
#356150
07/27/09 12:16 AM
07/27/09 12:16 AM
Posts: 18,153 Mass
DAYCLONA
Mass
Actually the wingcars run hotter with clutch fans, the factory has several TSB's to replace clutch fans in Daytona's returing to dealerships complaining of hot run conditions,....the Superbirds were TSBed, at their "assembly line", although a few "escaped" with clutch fans
[Re: JSSuperbee]
#356151
07/27/09 12:20 AM
07/27/09 12:20 AM
Posts: 18,153 Mass
DAYCLONA
Mass
Jim,
I did the same thing at first, tried waterwetter with Prestone and saw no change,....the Zerex G-05 is completely different in it's chemical "make up", you'll see if you try it, it's clear in color, dosen't leave a sticky mess like the green stuff, wipes off with no trace,....and it less filling, and tastes great
Mike
[Re: DAYCLONA]
#356152
07/27/09 12:44 AM
07/27/09 12:44 AM
SomeCarGuy
True, but G-05 and Water Wetter weren't out in 69-70.
[Re: DAYCLONA]
#356155
07/27/09 06:13 PM
07/27/09 06:13 PM
JSSuperbee
Missouri, U.S.A.
Mike:
I took a copy of your post to my radiator man that's been trying to help me with my overheating problem. He had an empty bottle of Zerex G-05 and read me the warning on the back of it and suggested I run the language by you and see what you think...before I put it in the cooling system. It says on the back: IMPORTANT CONSUMER INFORMATION....."Antifreeze/coolant chemistries are different. Products that contain Organic Acid Technology (OAT) chemistry are NOT approved by Ford & Daimler Chrysler for HOAT/G-05 applications. Products using OAT chemistry may be damaging to cooling systems that specify HYBRID ORGANIC ACID TECHNOLOGY (HOAT) chemistry based on OEM recommendations." Sounds rather serious. What do you think?
James Stinebaker
[Re: SomeCarGuy]
#356157
07/28/09 01:16 AM
07/28/09 01:16 AM
Posts: 18,153 Mass
DAYCLONA
Mass
I think that means don't run it with Dexcool since Dex has a rust eating organism.
Drain what you have and run it.
Exactly!,......I've been running the stuff(Zerex G-05) for about 5 years now in all my toys, daily drivers as well, with no problems, NOTHING,.....I wouldn't tell you to do something I haven't allready done, or use(d), when I refere to my Daytona's heating issuses, that was almost 5 years ago, when I "discovered" the Zerex G-05,....I haven't had a overheating issuse since, no corrosovive, or clogged componets, nothing,....the only issuse I have is now waiting for the car to "warm up"
The Dexcool is the crap you want to avoid, I'd heard to many horror stories from it's use to even consider it!,.....I do recommend if you use the Zerex G-05 with Redline waterwetter, you flush the system every year, and renew, as I see a slight increase in temp, as the year ends, I believe the effectiveness of the Zerex breaks down, plus it's a good idea to flush your system every year regardless IMHO
Just remember to really flush your system with clean water, don't leave any traces of the old coolant, if you know all your cooling componets are sound, and in excellent shape, don't replace any componets when changing over to the Zerex G-05 and WW, so that you can judge for yourself if it has any merit, on it's own in altering your cars cooling
[Re: Rob440Magnum]
#356164
07/28/09 07:16 PM
07/28/09 07:16 PM
RapidRobert
May I suggest you get the rad in & try it w plain water(its not going to rust up in an hour for a test) & see where the temp is then drain it & put the 05/ww in which will take very little additional effort & will tell you(& us) exactly how good this stuff is. That much of a claimed drop is miraculous(just from using different fluids) but if you do more than one change at a time you'll never know & if it's good I'm on it.
[Re: Rob440Magnum]
#356165
07/28/09 08:18 PM
07/28/09 08:18 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Where do you buy: Zerex G-05 and Redline waterwetter?
How much waterwetter do you add per gallon of zerex?
Thanks, Rob
Zerex G-05 can be had at CarQuest, Auto zone, Pep boys,.....I've only seen the Redline at Autozone, it comes in a 8 oz bottle use the whole thing, I wouldn't substitute another WW manufacturer
Like I mentioned to Jim, if everything is up to snuff on your cooling system, don't make any changes, just add the Zerex and WW, and post your results,....and as Robert mentioned you have the rad flushed, just install, flush your motor, fill the system with just water run it/drive it, record your results, then bleed off enough fluid, usually a gallon, or close to it, and add the Zerex and WW, test drive record any/all changes,....then post your results
[Re: RapidRobert]
#356167
07/29/09 04:03 PM
07/29/09 04:03 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Dayclona has already proven Zerex works. I am not sure just plain water would be a fair comparison. I suspect plain water would run hotter than any coolant.
We have everything clean, flushed and drained. We will just be doing the zerex and hope for the best. Tired of messing around with the problem.
[Re: Rob440Magnum]
#356168
07/29/09 04:44 PM
07/29/09 04:44 PM
bee1971
Sobieski Wi
I would assume this Zerox Product is already premixed 50/50 in the bottle - Look at the container when you buy it
Water dissipates heat much much faster then any coolant/antifreeze will ever do - Alot of guys run straight water in the summer with some type of additive for corrosion protection (Hence Redline Water Wetter) - If your cooling system is working properly you dont have to worry about it boiling over with straight water - Remember straight water will dissipate heat much much faster
Antifreeze helps lower the boiling point - Protects against freezing - Corrosion protection Blah Blah Blah
Check the bottle to make sure its 50/50 mix or straight , and if its straight , mix with distilled water and call her a day
[Re: bee1971]
#356169
07/29/09 06:52 PM
07/29/09 06:52 PM
Posts: 18,153 Mass
DAYCLONA
Mass
The Zerex G-05 is straight, not 50/50,......I tried straight water, straight water and no thermostat, I still experience hot running/near boil over conditions,.....The Zerex and WW was just one among may attempts at getting my car to run consitantly in a "manageable" zone 180-200, it worked for me after many failed attempts at trying to solve the problems this particuar car of mine was having, usually cooling problems are easy to isolate, but being a wingcar with reduced grille area,(24"X6") it's opening is almost 36" away from the radiator, presents some issuses
FYI, just a note, Antifreeze RAISES the boiling point of water, at a maxium mixture of 70% antifreeze and 30% distilled water, the boilng point of water (220) can be raised to 270 degrees,.... running pure antifreeze, will gaurantee you of problems, and the boilng point is reduced to about 200 degrees, not a wise choice,.....I'd recommend a 50/50 mix to start with regarding the Zerex G-05,......there's many types/grades of Zerex, make sure to use the G-05 formulation, usually the "gold" bottle, but double check!
Mike
[Re: Rob440Magnum]
#356170
07/29/09 07:07 PM
07/29/09 07:07 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Should we fill the entire cooling system with Zerex and one bottle of water wetter or should the Zerex be diluted with some water added?
I start off putting 1 gallon of Zerex in, then the 8 oz, of waterwetter, the add water to the rest, usually 1 gallon, start the engine, let every thing run thru/mix, wait for the thermostat to open for operational tempatures,....I do recommend you drill an 1/8" diameter hole in the actual thermostats base flange,(nNOT the housing! ) as this bleeds the system of all or most air, and helps fill the system when dry, plus allows a small amount of fluid movement when the thermostat is closed, don't go no larger than 3/16", even a hole that size can flow pretty good!.....1/8" is ideal
Mike
[Re: Rob440Magnum]
#356171
07/29/09 07:12 PM
07/29/09 07:12 PM
Posts: 18,153 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#356172
07/29/09 09:34 PM
07/29/09 09:34 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Mike
Is tap water ok?
[Re: DAYCLONA]
#356174
07/30/09 04:05 PM
07/30/09 04:05 PM
JSSuperbee
Missouri, U.S.A.
Update: Just changed over to Zerex G-05. Didn't do a bit of good. Still runs hot. I knew it was too good to be true but I am frustrated and had hope that the Zerex would help.
James Stinebaker
[Re: DAYCLONA]
#356176
07/30/09 10:06 PM
07/30/09 10:06 PM
JSSuperbee
Missouri, U.S.A.
Mike:
It runs warm on the highway but tolerable. When I stop it really starts to rise. It gets to about 230 and I have to either get out on the road running 40 M.P.H. or just shut it off. About 30 seconds after shutting it off, I turn the ignition to accessory and check the gauge and it is always pegged to the right.
James Stinebaker
[Re: SomeCarGuy]
#356178
07/30/09 10:51 PM
07/30/09 10:51 PM
JSSuperbee
Missouri, U.S.A.
I took it to the local radiator shop and the technician pointed his infared meter at all points on the engine and radiator. The gauge proved accurate. The car never came with a shroud but I purchased a used one, installed it, and removed the thermostat. Just took longer to heat up. However, there is about a 3/8 inch gap all the way around the shroud. I'm going to put black duct tape all the way around it and see if that helps. That's going to look real nice on an all original under hood appearance. The fan is 2" deep and exactly 1/2 of the blades are inside the shroud.
James Stinebaker
[Re: JSSuperbee]
#356179
07/30/09 11:17 PM
07/30/09 11:17 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Jim,....have you tried adapting (temporaryly) in the sending unit on the pump a thermocouple probe(radiator shop should have one) to record ACTUAL water temp, as hand held IR units are nice, they leave a little to be desired, your fan spacing sounds OK, a shrouud dose wonders also, what kind of fan/blade are you running?,
Do you experience boil over at idle/slow traffic conditions, I know we try to avoid that, but will the car spew if allowed to?
[Re: SomeCarGuy]
#356181
07/30/09 11:53 PM
07/30/09 11:53 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
What Jets is the 6-Pack car running? Bet he is way to lean on the center carb.....
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: DAYCLONA]
#356182
07/31/09 12:19 AM
07/31/09 12:19 AM
JSSuperbee
Missouri, U.S.A.
Mike:
No I haven't tried a thermocouple. However, the radiator tech pointed his infared directly at the sending unit and it read the same as the gauge. I had all the gauges checked for operation and accuracy by that guy in Arkansas that does instrument clusters and gauges. The fan blade is the stock unit. A fixed/solid 7 blade that came on the non cool pack cars. The radiator does not boil over, but probably because I panic and shut the engine down. The radiator tech remade my radiator into a brand new 3 row. Now it just takes longer to heat up. I put a spring from an old hose in the brand new Gates lower radiator hose. So far I've thrown about $800 at the problem. I don't know if it will spew if allowed to and am reluctant to allow it with only 170 miles on the car.
James Stinebaker
[Re: SomeCarGuy]
#356184
07/31/09 12:33 AM
07/31/09 12:33 AM
JSSuperbee
Missouri, U.S.A.
OK here are the specs. The car is all original with 75,000 miles on it. I had the entire engine rebuilt with a .030 over bore and a one notch higher cam from MOPAR Performance(can't get the exact same original cam anymore). The car came with the solid/fixed 7 blade fan, 22" radiator, and no shroud. I had the timing checked and it is running 34 degrees total. Then, I had the radiator changed to a 3 row and installed a fan shroud, removed the thermostat, and put a spring in the lower hose. With all this, the engine just took longer to overheat. Earlier today, I put black duct tape all around the shroud as there is a 3/8 gap all around. That seemed to help. Now at idle it runs warm...about 210 but nowhere near what it was running. Then Mike said try Zerex G-05. Crossed my fingers and drained the Prestone and put in the Zerex. No good. Still idles as about 210 degrees with an outside temperature at a below normal 82 degrees.
James Stinebaker
[Re: SomeCarGuy]
#356185
07/31/09 12:37 AM
07/31/09 12:37 AM
JSSuperbee
Missouri, U.S.A.
Both the pulley and water pump are original pieces. I had the water pump professionaly rebuilt and looking inside the radiator while the engine is running looks as though the pump is doing its job.
James Stinebaker
[Re: SomeCarGuy]
#356187
07/31/09 12:57 AM
07/31/09 12:57 AM
JSSuperbee
Missouri, U.S.A.
Yep the timing mark is right on. However, the car runs sluggish. The tune up tech says it is only pulling 13" of vacuum but he doesn't thing that is the over heating problem. My 6 cylinder Buick Lucerne can run circles around the bee. Never attempted to check the compression. I could try some race fuel as that is one thing I haven't tried. What ratio with gas should I try? Burped the system on each attempt. Now running with no thermostat. Yeah...we checked the pulleys and the belt today. It's a tiny bit loose but nothing to cause overheating. The pump was rebuilt during the engine overhaul process and the coolant moves quite well through the top of the radiator. The radiator tech recommends I continue to run without a thermostat and try to get about 600 miles on the rebuilt engine. I just don't think that the engine being freshly overhauled would cause it to over heat. Heck these engines didn't overheat when they were brand new.
James Stinebaker
[Re: JSSuperbee]
#356189
07/31/09 01:29 AM
07/31/09 01:29 AM
Posts: 18,153 Mass
DAYCLONA
Mass
Jim, If you'd like, try this, won't cost anything but time, and a little gas,.....if you have a standard radiator cap, not one of those snap locking rad caps,.....check the fluid level in the radiator, put the cap on, tighten it, then back it off to the point were its loose, but can't be removed unless you fully depress and turn it past the locking tabs, the point were it's ready to be removed, but just flops around, leave it like this, start the car, let it warm up, slowly rev it, causeing the overflow tube to purge what fluid it don't need for top tank volume, usually 1 inch below the filling neck,.....if the car is running within temp, take it out for a drive, reason for keeping the cap loose is for pressure not to build in the ststem, as you drive you may purge some fluid out the overflow as engine RPM increases,.....post your results with this test if you would please Mike
[Re: DAYCLONA]
#356190
07/31/09 08:03 AM
07/31/09 08:03 AM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Did you dilute the Zerex-05 with distilled water and secondly did you add a bottle of water wetter?
[Re: Rob440Magnum]
#356192
07/31/09 11:11 AM
07/31/09 11:11 AM
Posts: 1,527 minnesota
Kirby
minnesota
Running without a stat can cause the motor to run hotter because the coolant never stays in the radiator long enough to be cooled.
After all the different things you recently tried, you may want to put the stat back in and see how it works now.
That is exactly what I was thinking- You pretty much have to have a stat in there, it constantly opens and closes to keep the water in your radiator long enough to cool it, then opens a bit and closes back and forth. With out one, your system is just going to heat up to a certain temp without regulation.
[Re: Kirby]
#356193
07/31/09 04:30 PM
07/31/09 04:30 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Two things:
1) Question I need answered - Does drilling the thermostat 1/8" really help keep the temp down?
2) Years ago my dad was changing freeze plugs and dropped one in the water passage of the block; He said car developed a "hot Spot"? and it always ran hotter after that incident. It was a chevy small block if that matters.
The reason I mention this is the remote possiblity that someone at some point might have left an old punched out freeze plug in the block or head causing a small blockage?
I'm not as knowledgable as some of the previoius posters here on this tgopic, but I thought this might help.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: DAYCLONA]
#356195
07/31/09 05:54 PM
07/31/09 05:54 PM
JSSuperbee
Missouri, U.S.A.
Mike:
I'm taking the car out tomorrow night to the local cruise spot. I'll try leaving the radiator cap 1/2 on and loose and let you know. However, the radiator tech did fill the radiator to within about 1 inch from the top yesterday.
James Stinebaker
[Re: DAYCLONA]
#356197
08/01/09 10:46 PM
08/01/09 10:46 PM
JSSuperbee
Missouri, U.S.A.
Mike:
Just got back from the cruise. I did like you said and loosened the radiator cap one notch so it was still on but loose. When I got to the cruise spot it wasn't running hot but it was purging coolant out of both the overflow hose and the radiator cap. About a pint was pushed out on to the ground.
James Stinebaker
[Re: JSSuperbee]
#356198
08/02/09 12:13 AM
08/02/09 12:13 AM
Posts: 18,153 Mass
DAYCLONA
Mass
Mike:
The radiator was "adjusting" fluid level due to Engine RPM, heat expansion, etc
Jim, the reason I asked you to do that "test", and I would repeat another driving run to see if the car overheats, you say it didn't overheat this time, was it at "operational" temp, what was the highest temp you hit?......on the next run, check the fluid level, if you can see it in the radiator, don't add anymore, make sure you have enough fluid in it though, the engine running with the cap loose, purged what it didn't/couldn't hold at full level,.......I had you do this Jim, because I suspect several things, leaving the cap loose, dosen't allow the system to pressurize, I suspect you have a bad head gasket(s), or a cracked head(s), and the exhaust is pressurizeing and heating the cooling system, I've seen this before, in severe cases the cooling system appears to boil over and spew at normal operation tempatures, I 'll assume your running a 14-16 lb cap,........if you were to run a 5-7 lb cap, I'd suspect you'd boil over/spew the system even at a nominal running temp,......what happens is the exhaust gas in the pressurized, and capped, cooling system creates a steam bubble, and prevents the fluid from moving thru the cooling system, so temps go up, pressure builds, eventually spewing,.....buy keeping the radiator cap off slightly, you alow combustion gases/pressures to vent to the atmosphere
run the car a few times up to temp with the radiator cap "loose", if no more overheating/spewing happens, try a 5-7 lb cap, if it overheats/spews,....my money is on the heads/head gaskets,.....I've worked on an engine that had similar problems once, blew 2 head gaskets, would overheat with the cap on, but off was fine, the culprit I found was the machine shop had inserted a block dowl for the head upside down, the tapered end should have been up, the barrel end was holding the head off the deck and gasket by ever so much, it didn't allow the head to fully compress the gasket, resulting in a leak, causing a pressurized cooling system, I've found that you can pressurize a cooling system without having the usual symtoms, like oil in water, or water in the cylinder misting/plumeing out the exhaust, etc........you said the engine was rebuilt?, low mileage, after intial break in, did you retorque the head bolts?....if not, you might get lucky, and try that, you "might" solve the problem, if it's the gaskets,( if they aren't damaged) if it's cracked head(s),.....you know the drill, you might want to have a leakdown compression test done on all the cylinders to pinpoint a cylinder, or bank, or which head, if that's the case,......this is my honest opinion as to what I would suspect, and approach as being the possible problem, from past experience with it,....but keep in mind, I'm on a computer,....not under the hood, hands on, on your car, I can only "see" what you tell me
Mike
PS,...Has your "radiator guy" used an exhaust gas detector to check/take reading for spent exhaust in the coolant/radiator?
[Re: DAYCLONA]
#356199
08/02/09 05:41 PM
08/02/09 05:41 PM
JSSuperbee
Missouri, U.S.A.
Mike:
As I mentioned before....after I put black duct tape around the shroud, the engine runs cooler. At idle and outside temperature of about 82 degrees it idles and maintains a temperature of about 210 degrees. I had just gotten off the highway and drove about 1/4 mile to the cruise spot and the temperature was normal. The needle showed mid way on the gauge. That's probably 195 to 200 degrees. I got out of the car and coolant was running out on the ground. The next run will be Friday afternoon for another local cruise about 10 miles away. The reason I don't think I have a cracked head is because the engine rebuilder did a magnuflux check. You're right....I'm running a stock 16lb. cap. I had the coolant checked twice for combustion gasses and both times proved negative so it would seem that the Fel Pro head gaskets are'nt leaking. The radiator tech suggests getting 600 miles on the newly rebuilt engine and then returning to his shop for more tests. I've got 203 miles on it now. Also, the thermostat has been removed. Here again, it seems to now be holding its own at about 210 degrees at an idle. Maybe I can live with this. Some say putting a Miloden 180 thermostat in it will cause it to run cooler. I was going to wait until I had the 600 miles on it before re-installing a thermostat. At the cruise last night a couple of guys gave me the names of so-called experts to take the car to. I figured that may be a good idea since what ever is making this car run real sluggish may be what is causing the warm running condition (no longer completely overheats after installing the duct tape around the shroud). I did not retorque the headbolts....thought I would run that task by the experts when I take it to one of them. I would think they would also do a leakdown compression test. I'm printing your last post to take to either expert for their review as your input seems helpful and contains some probable causes. Since I hi-jacked this thread...maybe I should PM you with the results of the next test that you suggested.
James Stinebaker
#356203
08/03/09 10:06 AM
08/03/09 10:06 AM
bee1971
Sobieski Wi
Did you ever pull any spark plugs from each head to check color/appearance ??? - Lean condition at idle / cruise condition like so many others have mentioned
I agree on the thermostat 160/180 milodon high flow - Has to bee in there
[Re: bee1971]
#356204
08/03/09 05:43 PM
08/03/09 05:43 PM
JSSuperbee
Missouri, U.S.A.
A couple of weeks ago I took it to a profesional engine tuner and he pulled a plug from one head and said it looked perfect.
James Stinebaker
[Re: SomeCarGuy]
#356205
08/03/09 05:48 PM
08/03/09 05:48 PM
JSSuperbee
Missouri, U.S.A.
I ordered a 180 high flow Miloden stat from Year One about 1/2 hour ago. They said it would take 2 weeks to get it. Right now the Zerex G-05 and water wetter are in it from when Mike suggested it. Ill be leaving that combo as is. In a couple weeks I'll be able to perform that test.
James Stinebaker
[Re: 1fastrunner]
#356210
08/04/09 06:06 PM
08/04/09 06:06 PM
JSSuperbee
Missouri, U.S.A.
Too late! I'm commited. I can wait. I have to get 600 miles on the car before going back to the radiator shop and I've only got 218 on it now. I may have to run it up and down the highway a bunch of times. It runs normal temperature on the highway.
James Stinebaker
