Re: 440 six pack - running hot - why
[Re: Challenger 1]
#356070
06/23/09 10:35 PM
06/23/09 10:35 PM
Posts: 533 Williamsport, PA
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
More details needed, shrouds? clutch fans?
new reproduction 26" fan shrouds on both cars. Both cars 26" radiators. Clutch fans on both cars however the six pack has a new Mopar Perf. clutch fan which if I remember correctly is a 5 blade fan and I have the origianl 7 blade clutch fan on my car.
[Re: Rob440Magnum]
#356072
06/23/09 10:45 PM
06/23/09 10:45 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
either he is developing much more heat (lean, bigger bore, clogged cooling passages), or he isn't shedding as much heat (WP, fan, radiator, shroud). Take the temp readings in as many places as possible and compare. Lower radiator hose, WP, Heater hoses, etc.
[Re: MNobody]
#356073
06/23/09 10:50 PM
06/23/09 10:50 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
What waterpump's?
not 100% sure, but I think we have the same ones new from Mancini Racing. Can't remember what model # or specifics. What information about the water pump would you want to know?
[Re: Rob440Magnum]
#356074
06/23/09 10:54 PM
06/23/09 10:54 PM
RapidRobert
what do his/yours plugs look like & he might pull his stat for 1 day. EDIT forgot about timing(his vs yours)MORE EDIT he might block his intake(like yours) & see if that equalizes things & if so then decide how he wants to get the choke to open properly(I'm betting on this last one)
[Re: Rob440Magnum]
#356078
06/23/09 11:03 PM
06/23/09 11:03 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Any other six packs out there with no heat riser, stock choke hooked up, and the heat crossovers on the valley pan open with their motors running hot?
[Re: Rob440Magnum]
#356079
06/23/09 11:21 PM
06/23/09 11:21 PM
Posts: 4,884 Michigan
MNobody
What waterpump's?
Some pumps have more fins on the impeller to move more water, i believe AC cars have 7 versus 5 on the non AC cars.
[Re: MNobody]
#356080
06/23/09 11:53 PM
06/23/09 11:53 PM
Posts: 10,198 Someplace you aren't
SomeCarGuy
Lots of stuff has been covered here.
First, what are the actual temps you are seeing? What gauges are being used?
Was his engine bored over more than yours?
I don't think the heat riser will make the diffeence you are looking for on his car. I don't think the choke will work a whole lot different blocked, mine is and the intake gets plenty hot once the car warms up. He could just wire it open and live with the poor cold running temper, it doesn't tae that long to warm up anyway.
Is his fan belt tight? Might just be a new belt that was put on at the rebuild time that has loosened up.
I want my fair share
[Re: Rob440Magnum]
#356081
06/24/09 12:00 AM
06/24/09 12:00 AM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
It could be anything, tune stands out to me, as well as various cooling parts, but since nobody has touched on it yet...
Has anybody thrown a block in a hot tank and actually CHECKED for silt etc at the bottom of the block? I have and have found some blocks packed with hardened debris. I used all sorts of tools to dig it out through the frost plug holes, I was amazed at what was left in some...
If all else fails it *might* be worth checking as a very last resort..? I have a feeling timing and carbs might be the first area to look at though...
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#356082
06/24/09 06:44 AM
06/24/09 06:44 AM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
both bored the same 30 over
Do you have a six pack? With your crossovers blocked does your choke still function properly?
[Re: MNobody]
#356084
06/24/09 09:19 AM
06/24/09 09:19 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
What waterpump's?
Standard pump has 8 blades,A/C has 6,keeps water in radiator longer with slower circulation.
[Re: Rob440Magnum]
#356085
06/24/09 09:20 AM
06/24/09 09:20 AM
Posts: 74,937 U.S.S.A.
JohnRR
U.S.S.A.
My timing is 13 degrees initial and the six pack is 15 degrees initial timing. We cannot go any higher or they ping on 93 pump gas.
Plugs are fine.
What are you recommending we try with the thermostat?
What is his and your TOTAL timing ? I ASSuME the shop that dynoed the engines recurved the dizzy's as needed ?
If the water temps are very close then it's not really running hot . because his crossover is open the intake is hotter on his engine vs. yours , plus the 6pack air cleaner is alot bigger than yours and will trap the heat coming off the engine.
Did you adjust the timing from what the dyno sessions were set at ? if so which way ?
[Re: JohnRR]
#356086
06/24/09 09:28 AM
06/24/09 09:28 AM
Challenger 1
Cincinnati, Ohio
Plugs are fine.
Yes he mentioned any more than 15 degrees initial it will ping, sounds like the dist is not setup right.
I run 18 initial and 34 total and my 440 six pak which runs great and stays cool even on 90 degree days with the AC cranking. I drove it for about a hour last Sun(90 degree day) and then pulled in the driveway and let it idle for another 15 mins and the temp stayed rock steady. BTW all stock cooling system.
