727 ID and Q's... #355035
06/22/09 09:13 PM
06/22/09 09:13 PM
Anonymous OP
Anonymous OP
Okayyy... I finally got around to grabbing a trans out of storage for a long awaited rebuild.
I need to ID this Trans/Valvebody before I go spending money I don't have on parts that won't work.
I only found a few numbers stamped on the pan rail and a few casting numbers on the case.
I was hoping someone could decode it and maybe answer a few Q's.
The previous owner said it came out of his 68 charger.
Trans Case Pan rail: G2538334 2425030
Part number: 2466900 on main case body, 2466901 on tail shaft.
There were also some box type date codes but the case is still a little too dirty to ID those (started with 65 and had dots into 9 or 10 of the boxes).
There was no valvebody with that trans when I bought it (previous owner was keeping it).
Can I use any valvebody I want or does each trans use particular valvebodies?
I also have a valvebody from a smallblock 727, will that VB work in the trans I am trying to ID?
Here are the numbers from that smallblock 727 VB...
Part # on top side of VB: 3410925 (has wheel type date code 06/1971)
Part # on bottom side of VB: 3410435
Number stamped on separator plate: 10225/1000041
I also plan to use a Trans-go TF2 if that makes a difference with the valvebody choice.
Last Q... what's the best rebuild/master rebuild kit with the best parts for the money? who's the best to shop with?
I plan to put this trans behind a mild 440, have no idea how many hp but I'm sure will produce way, way, wayyy less than 600hp.
Thx
Re: 727 ID and Q's... #355036
06/22/09 09:37 PM
06/22/09 09:37 PM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
The trans is a 66 originally for a 361/383.
I have the same one. Remember that 66 has the course spline as opposed to 67-later fine spline if you are going with an aftermarket TC.
Re: 727 ID and Q's... [Re: newbee69] #355037
06/22/09 09:46 PM
06/22/09 09:46 PM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
Also first year for external shift lever.
Will only have 3 pinion planetaries.
Old style rear servo piston.
Original VB has a restrictor orifice that delays manual 1-2 upshift. But that doesnt matter cuz you dont have original VB.
I really am not sure if you can use that other VB with this tranny.
Somebody will chime in to answer that one tho.
Re: 727 ID and Q's... [Re: newbee69] #355038
06/23/09 09:08 AM
06/23/09 09:08 AM
Anonymous OP
Anonymous OP
Re: 727 ID and Q's... #355039
06/23/09 04:48 PM
06/23/09 04:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The valve body with the steel separator plate stamped 10225/1000041 is probably gold colored from a B&M Shift Improver kit. This plate might not be compatible with the TF-2 kit so you'd be better off to get an untouched VB.
For a '66 trans you would want a '66-70 VB but a '71-'73 will work.
Makco is a good source for quality rebuild parts at good prices.
http://www.bulkpart.com
