ford transmission questions #353599
06/21/09 04:03 PM
06/21/09 04:03 PM
WI.
Scotts71chall Offline OP
WI.
Will a 1989 ford trans from a 351w f250 truck bolt to a 460 big block?
If so how to tell if its a c6?
Could this trans be built for high performance?
Re: ford transmission questions [Re: Scotts71chall] #353600
06/21/09 04:18 PM
06/21/09 04:18 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Ford C6 is a heavy duty unit that can easily be modified for high HP use. The pan shape is almost square except for a cutout in the rear portion.
The 460 case will not mate to a 351W.
MB
