my 74' barracuda project #350295
06/17/09 05:54 PM
06/17/09 05:54 PM
Oshkosh WI
barrakudaman Offline OP
Oshkosh WI
I have always loved the cuda's looks, my first car was a 73' cuda that i restored with the help of others when i was 17. I ended up having to sell that one. Now; 22 I picked up another cuda. It was on craigslist close by and was supposed to be pretty complete for 3k . So late last year I baught it and have been dissasembling and replacing body panels as i go. Car was originally a 318 4-speed barracuda, I plan on making this car a street machine with a built small block stroker or a 3rd generation hemi. I also want to do some sort of two tone paint job. I am sure this will all change by the end of the project. I will post pictures of my project as i go. The first part of this project i was using a throw away camera and almost all the pictures did not turn out. so the posted pic's are of the car in its present state. My uncle is a bodyman so he has been giving me pointers, and my dad has a nice shop that he lets me use with a welder, plasma cutter, and a torch
Re: my 74' barracuda project [Re: barrakudaman] #350296
06/17/09 05:56 PM
06/17/09 05:56 PM
Oshkosh WI
Oshkosh WI
I Found a good used rocker on e-bay for $200 and welded it in when i had the firewall all apart
Re: my 74' barracuda project [Re: barrakudaman] #350297
06/17/09 05:58 PM
06/17/09 05:58 PM
Oshkosh WI
Oshkosh WI
The AMD 2 piece firewall seemed to fit just about perfect. I was not planning on having to change the firewall when i purchased the car, but it was needed and i was really glad they make aftermarket ones
Re: my 74' barracuda project [Re: barrakudaman] #350298
06/17/09 05:59 PM
06/17/09 05:59 PM
Oshkosh WI
Oshkosh WI
firewall
Re: my 74' barracuda project [Re: barrakudaman] #350299
06/17/09 06:00 PM
06/17/09 06:00 PM
Oshkosh WI
Oshkosh WI
I used zinc weld through primer between all panels that i welded together
Re: my 74' barracuda project [Re: barrakudaman] #350300
06/17/09 06:05 PM
06/17/09 06:05 PM
Oshkosh WI
Oshkosh WI
I spot welded the inner fenders all in and welded an auto rust technician frame cap on the drivers side front frame rail. It seemed to fit good. And i welded it solid, no stitch welding. Thats all the pics for now, I am working on the back half now...
Re: my 74' barracuda project [Re: barrakudaman] #350301
06/17/09 06:07 PM
06/17/09 06:07 PM
Oshkosh WI
Oshkosh WI
I installed year one / goodmark front floor pans in. they fit great too.
Re: my 74' barracuda project [Re: barrakudaman] #350302
06/18/09 05:57 PM
06/18/09 05:57 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
nice project. looks like you're doing some good work there. wanna hang a couple 1/4 skins?
keep the pics comming!
1981 Dodge D150 360 auto
Re: my 74' barracuda project [Re: basketcase] #350303
06/28/09 11:29 AM
06/28/09 11:29 AM
Oshkosh WI
Oshkosh WI
Moved to the back end and replaced both rear frame sections
Re: my 74' barracuda project [Re: barrakudaman] #350304
06/28/09 11:30 AM
06/28/09 11:30 AM
Oshkosh WI
Oshkosh WI
Re: my 74' barracuda project [Re: barrakudaman] #350305
06/28/09 11:31 AM
06/28/09 11:31 AM
Oshkosh WI
Oshkosh WI
Re: my 74' barracuda project [Re: barrakudaman] #350306
06/28/09 11:33 AM
06/28/09 11:33 AM
Oshkosh WI
Oshkosh WI
Test fit the AMD trunk pan... That is a nice piece The pan fit perfect.
Re: my 74' barracuda project [Re: barrakudaman] #350307
06/28/09 11:34 AM
06/28/09 11:34 AM
Oshkosh WI
Oshkosh WI
Re: my 74' barracuda project [Re: barrakudaman] #350308
06/28/09 11:37 AM
06/28/09 11:37 AM
Oshkosh WI
Oshkosh WI
Re: my 74' barracuda project [Re: barrakudaman] #350309
06/28/09 11:38 AM
06/28/09 11:38 AM
Oshkosh WI
Oshkosh WI
underneath
Re: my 74' barracuda project [Re: barrakudaman] #350310
06/28/09 11:39 AM
06/28/09 11:39 AM
Oshkosh WI
Oshkosh WI
Two of the most usefull tools...in my opinion
Re: my 74' barracuda project [Re: barrakudaman] #350311
06/28/09 11:41 AM
06/28/09 11:41 AM
Oshkosh WI
Oshkosh WI
now I just have to clean everyhting up and tack the pan in place. Next I will remove the wheel wells and tail panel
