Carter AVS rebuild kit. Where to get ? #343833
06/11/09 04:24 AM
06/11/09 04:24 AM
Voss,NORWAY
70sportfuryS/23 Offline OP
Voss,NORWAY
Can anyone tell me where to get a rebuild kit for the Carter AVS on my 1970 383 ?
It is the original 4 barrel carb in the car and the number on it reads 4732.
1957 Plymouth Belvedere 2dr HT 1970 Plymouth Sport Fury S/23 2dr HT 1970 Plymouth Sport Fury GT 2dr HT 1994 Chrysler Voyager AWD
Re: Carter AVS rebuild kit. Where to get ? [Re: 70sportfuryS/23] #343834
06/11/09 07:46 AM
06/11/09 07:46 AM
pgh pa
captaindodge Offline
pgh pa
Got mine from CarQuest.
Re: Carter AVS rebuild kit. Where to get ? [Re: captaindodge] #343835
06/11/09 09:13 AM
06/11/09 09:13 AM
Happy Birthday RapidRobert  Offline
A parts house would be able to order one for you but you might contact the carb companies & see if they have kits for them as the regular kits can have poor fitting gaskets and a specialty kit would have better quality gaskets & accel pump. The regular kits will work Ok but you might want to spend a few more $$$ for a real good one(if they are still available).
