Re: Why do HEMI Rams have two spark plugs per cylinder
[Re: 340Scamp]
#340048
06/07/09 09:35 AM
06/07/09 09:35 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
They've been doing it for years. Nissan 2.4L had it in the 80s. My impression is they need the burn time of the mixture to be as fast as possible while still being a controlled burn, so they make sure the mixture is squished and moved during hte last few degrees of the compression stroke, then they light it from opposite ends so it takes 1/2 the time with less loss of efficiency.
[Re: DZJim]
#340051
06/07/09 02:58 PM
06/07/09 02:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Airplanes require two independantly powered ignition systems for safety reasons, nothing more. If your plane ran better when you switched the other mag in then your first mag setup has problems. Not that mags are all that great an ignition system.
[Re: Supercuda]
#340052
06/07/09 08:25 PM
06/07/09 08:25 PM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
Hmmm...yeah; I screwed up my first post. I inadvertently took off running on one magneto. You use both magnetos; switching each off in turn for the pretakeoff check. When I selected both "on" was when I picked up that little bit extra power.
I suppose safety is the reason behind the independent self-powered ignitions for airplane recip engines, but its a fact that you get a 50-75 RPM drop when switching one mag off during a runup.
[Re: DZJim]
#340053
06/07/09 09:01 PM
06/07/09 09:01 PM
Posts: 256 Cary, NC
hemifever
super street
super street
Cary, NC
The second is a "wasted spark". It fires 1/2 degree after the primary.
1971 Plymouth Cuda - 451 stroker
2008 SRT8 Charger - B5 Blue SuperBee
2010 Challenger - 6 spd Plum Crazy RT-C
[Re: GO_Fish]
#340056
06/07/09 11:21 PM
06/07/09 11:21 PM
Posts: 3,877 Oregon
hooziewhatsit
I know in rotary engines, since the combustion chamber is fairly long and flat, it would take too long for the fire from one plug to fill/burn the entire chamber, so they have two plugs to speed up the burn. Could be something similar with the Hemi's? Either way, there's probably a list of benefits of using two plugs
[Re: hooziewhatsit]
#340057
06/07/09 11:44 PM
06/07/09 11:44 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
The Nissan (Datsun back then) called their's the NapZ. It was a DOHC Hemi IIRC.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: ZIPPY]
#340062
06/11/09 09:02 PM
06/11/09 09:02 PM
Posts: 2,937 GA
roadrunninMark
GA
6.7 jigawatts? Hey DZ, you also have 2 plugs/mags a cylinder in ur prop so you dont foul a plug and lose the engine since you are usually taking off and landing with full rich (unless high elevation). I am sure when you've done your run ups before you ran into a semi fouled plug, then had to run up and lean the mixture, let run for a little till it cleaned up, then did your mag checks again. Now if only cars could have that leaning knob to coax a few more miles a gallon. Mark
[Re: ZIPPY]
#340063
06/12/09 12:47 AM
06/12/09 12:47 AM
Rug_Trucker
Wow, that's quite a mixed bag of responses.
Anyone want to take a guess what the power difference is between waste spark and firing both plugs in all 8 at the same time, on an otherwise stock 5.7?
Well? How to keep the Rug_Trucker in suspense!
