Re: Part # for '71 e-body turn sig. switch?
[Re: bremotorsports]
#338536
06/05/09 01:41 PM
06/05/09 01:41 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
wondering if the RIGHT unit with thin hazzard knob and turning on by push in instead pull out like laters is available. I have found the new pieces made are the later kind, and nothing like the 70/ first half 71 kind
[Re: NachoRT74]
#338538
06/05/09 02:04 PM
06/05/09 02:04 PM
NachoRT74
Valencia, España
note the right one on MOST earliers setup ( it does appear diff PN on box ): this is still pull out ON function maybe the 3488477 PN is with the push in ON function here is the later one with cornering lights with 3488805 PN note the diff on hazzard knob this is the new one available ( non Mopar )... note the horn switch is not anymore a roller to roll againts the horn track on wheel/adapter, now is really simply a brass stud. Later hazzard button kind New Mopar part, with cornering light ( new 3488805 piece made ) is with same horn switch kind than the one above( not anymore a roller ) everyone without tilt wheel
[Re: NachoRT74]
#338541
06/05/09 09:10 PM
06/05/09 09:10 PM
Posts: 2,901 New Jersey Bada Bing
bremotorsports
Superceded by 3488805.
Bill Rolik
This PN is with cornering lights and is the later kind... won't fit correctly on push in hazzard kind setup what as far I know is 70 and firts 71 half... just by the thick of hazzard knob. maybe trimming will fit and of course would get the reveresed ON operation
without cornering light, ends on 04 on PN
Correct. The SUPERCEDED switch for 70 cars is 3488804.
Bill Rolik
#338542
06/08/09 10:21 AM
06/08/09 10:21 AM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Bill Rolik
Bill Rolik
For 1971 cars, 3488805 will work?!?!?
[Re: 2fast4yourBrain]
#338543
06/08/09 01:45 PM
06/08/09 01:45 PM
NachoRT74
Valencia, España
the diff between 04 and 05 is just the extra harness to cornering lamps. now, would need to confirm the knob size. this pictured one is supposelly correct for 70 and maybe 71s ? Maybe first 71 half ? on ebay it was on $500 knob is diff thick
[Re: Snoopy]
#338549
06/08/09 03:41 PM
06/08/09 03:41 PM
NachoRT74
Valencia, España
amazing all the diff info and kind of switches, but basically the same 3488805 the same than 3488477, however newer pieces are without roller on horn switch stud. then 3488804 is the same without cornering lamp harness. But if E bodies doesn't have cornering lamps should use 3488804... right ? then we have 2947905... right piece to 70 E body, maybe also first 71 half then I have in B bodies the same than 2947905 but with PUSH IN to knob ON... maybe 2947503 ?
[Re: Snoopy]
#338553
06/09/09 02:04 AM
06/09/09 02:04 AM
NachoRT74
Valencia, España
GREAT INFO!!! thanks.
My car does have whoever the key courtesy light, diff than that one, but steering collar have a cutout for that. I mounted recently. It had before a plastic plug to fill the cutout bolted at same point. Removed the plug and fit the light.
of course we are talking about diff years and bodies, but trying to make a further info research, about what and where was used that or this setup
[Re: NachoRT74]
#338559
06/09/09 08:05 AM
06/09/09 08:05 AM
Posts: 4,165 Florida
cataclysm80
I believe that's right. I've taken apart several E body columns, and haven't found one of those cornering light switches yet.
If you needed to though, you could probably use it and tape them out of the way like Snoopy said.
I think the cornering light switches were C body right?
Tav
[Re: cataclysm80]
#338562
06/09/09 12:53 PM
06/09/09 12:53 PM
NachoRT74
Valencia, España
Tav
Yes C bodies.
Now, maybe the replacement 3488805 part maybe is being made to get a generic part to everything, and simply don't using the parts not needing. No need to remake two diff parts ( 04 and 05 ) for that.
However I don't like those NEW 3488805 BEING MADE, without the roller on horn switch.
[Re: NachoRT74]
#338563
06/09/09 12:58 PM
06/09/09 12:58 PM
NachoRT74
Valencia, España
Snoopy, since you posted those pics. DID YOU FIND SOME DIFF BETWEEN 3488805 AND 3488477 SWITCHES ? I find on pics they are the same except for flasher or hazzard words casted and arrow. My 04 switch turns on PULLING OUT the knob ( NOS, not a replacement )
[Re: Snoopy]
#338568
06/09/09 03:32 PM
06/09/09 03:32 PM
NachoRT74
Valencia, España
I haven't looked at them under a magnifying glass, but one obvious difference is in the wording on the knob. 3488805 - Hazard 3488477 - Flasher
thast what I said, thats the only diff I can note... but maybe the ON position it could be a diff ? dunno... I'm telling that just for the arrow pointing out.
cataclysm80... I have parted out some switches too for internal parts. Inner tabs are the pieces that commonly get damage. In fact a damaged switch can be fixed, opening and bending the tabs, then clening contacts and assmbly again with tiny machined scres and nuts OR, using a wire solder to melt down the plastic studs. I'm thinking on that to fix My buddy's 70 Charger, beingg that I haven't able to find the right switch around.
71rm23... yes, as stated by 472 R/T SE, you can find aftermarket pieces cheaper than pentastar pieces that works the same, just some diff colored wires and plastic parts. REALY REALLY if you ask me the correct Pentastar part will be the 3488804 unit, since thats is the one without conrering lamps, BUT is not available as new Mopar replacement parts, just NOS. So 3488805 ( if not aftermarket TW7 ) will be a replacement part, but without use the cornering harness.
I was able to get 2 NOS 3488804 switches in less than $30, one of them never arrived ( thats was the reason to get the second one )
[Re: NachoRT74]
#338569
06/10/09 02:30 PM
06/10/09 02:30 PM
Posts: 2,592 None
71rm23
None
Thanks Nacho. Sorry if I'm not clear on one thing..Are you talking about the front side marker lights in refering to "conering lights" Thanks again
[Re: 472 R/T SE]
#338571
06/10/09 08:28 PM
06/10/09 08:28 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Chryco Psyco said Standard part # TW7 would work and it cost $30 versus the over $100 some want. Now this was a year ago so hard telling what the cost is now.
Where do you get these $30 turn signal switches???
#338572
09/16/10 10:47 AM
09/16/10 10:47 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I know this is an old thread but I need some guidance.
I bought a MOPAR Turn signal Switch (part number on the box is 1-04293103) that was supposed to be for a 70 Challenger over a year ago. I'm just now doing the rebuild on the column and notice that the hazard button is larger as some of you mentioned before. The connector is correct. So, are you guys saying that I need to swap my old hazard button to this new switch or is there a new switch out of the box that has the correct narrower hazard button for a 70 Challenger?
Thanks, Joe
65 Barracuda 70 Challenger
#338573
09/16/10 04:03 PM
09/16/10 04:03 PM
Posts: 21,399 It's a dry heat
gtx6970
It's a dry heat
I've used one of those $30 aftermkt switches, the turn signal cancelling cam lever broke in less than a week. I'll stick with New Mopar as long as I can get them.
[Re: jrwoodjoe]
#338577
09/27/10 01:02 PM
09/27/10 01:02 PM
Posts: 7,195 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Thanks, Joe
You'll need to swap out your original button onto the new assembly...Be careful, delicate and take your time during the process...Now, am I reading this correct??? The original still works ???If that's the case just clean it up and use it until something goes bad...{How often do you really use the 4-ways?}...Then you'll need to do the swap...Cutting the column components would be the last option on the list IMO...
[Re: screamindriver]
#338578
04/18/13 01:09 AM
04/18/13 01:09 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Just found this thread doing a search, I'm surprised it came up as it's been three years... FWIW lots of good info & pictures, thanks to those who contributed..
Could this be archived?
