'68' IGNITION SWITCH TO BULKHEAD WIRING HARNESS? #329820
05/26/09 09:07 PM
05/26/09 09:07 PM
Anonymous OP
Anonymous OP
Could you interchange this harness and plug,taken out of my friend's '68' Charger, and install it on a '69' B-Body car(GTX)??? Thanks in advance! RandyB.
Re: '68' IGNITION SWITCH TO BULKHEAD WIRING HARNESS? #329821
05/27/09 01:08 AM
05/27/09 01:08 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The ignition switch connector should be the same, but the entire wire loom is different from rally and non rally dashes.
I have a 68 non rally harness from a Satellite if you are interested, PM me.
