Page 3 of 12 1 2 3 4 5 11 12
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32953
08/08/07 03:07 AM
08/08/07 03:07 AM
Germany, Northcoast
Buschi340 Offline OP
Germany, Northcoast
Clair, thanks for quik response. It took nearly a year to find these parts. I hope shipping to germany is not that expensive or the parts are not to heavy. I'm coming over in the states next month for my company and can take them home with me. But caused by the weight not all of the parts...
If nobody else is overbidding me I will let them ship to Carlisle where a buddy is located if shipping to germany is to expensive....
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32954
08/08/07 07:48 AM
08/08/07 07:48 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
The flywheel/clutch combo is going to be about 50#, the bellhousing about 10#, and the hydro clutch gear maybe 5#. If you can source the proper clutch disk and pressure plate locally, I'd skip shipping them - that would make the flywheel alone about 32-33#. "Normal" 10.5" clutches will bolt up to the V6 flywheel.
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32955
08/23/07 04:23 PM
08/23/07 04:23 PM
Germany, Northcoast
Germany, Northcoast
Clair,
I found some info's about "our" tranny:
toyo gear boxes
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32956
08/23/07 11:33 PM
08/23/07 11:33 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Nice link, Buschi! Those "manuals" are pretty handy, but I think I'd like to get my hands on a real service manual before opening up my transmission. I think there's a service manual on the web somewhere, I've got a link I think. I'm hoping whoever opened my trans up previously installed the upgraded thrust washer... I'm going to run it as-is first. Not that I'm any closer to running the thing, but you know.
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32957
08/24/07 03:09 PM
08/24/07 03:09 PM
Spokane, WA
48Heap Offline
48Heap  Offline
Spokane, WA
Hey Clair, I've got a 1987 Toyota Supra factory manual. Let me know if I can help.
I plan on running mine "as-is", as well. I don't think my slant 6 is going to hurt it soon, so I'm not too worried.
15 Chrysler 200S 3.6
15 Challenger R/T 6M STP
74 Duster 360 -> original 4 speed car
a.k.a. DionR
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32958
09/10/07 06:13 PM
09/10/07 06:13 PM
Germany, Northcoast
Germany, Northcoast
Hi Clair,
I'm just at a local speedshop here in Hagerstown. And we are not pretty sure what Pilot bushings / bearings to choose.
Do you have correct measurements, descriptions or partnumbers on hand? I would appreciate a response as I ever do....
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32959
09/11/07 10:11 AM
09/11/07 10:11 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Hi Clair,
Hey, Buschi,
Sorry for not getting back to you earlier, too much going on at home these days to spend as much time on Moparts as I'd like...
I don't have a PN on the Toyota pilot bushing/bearing. In fact, I don't know if it is a bearing OR a bushing. I was counting on making a bronze/oilite bushing from some bushing stock that would press in to the Mopar roller pilot bearing sleeve. Going from memory the sleeve for the Mopar roller pilot is about 1" DIA inside. The Toyota pilot shaft is small, though, APPROXIMATELY 0.454" . I would think that you could make a pretty durable bushing in that size, even in bronze/oilite.
Going over my old notes, which I wish were more complete, I show that the Toyota input shaft is 7-7/16" (7.438") long to the tip, and the pilot portion is about 0.75" long. I don't have the exact measurement in front of me, but I think I remember that the AX-15 Jeep/Dak bellhousing is about 1/2" deeper than a normal Mopar bellhousing (7-3/8"), so about 7-7/8" for the AX-15. That's what makes the pilot bushing issue "interesting". The crankshaft sticks out beyond the back of the engine block by 0.608" to the surface that the flywheel mounts to. The converter hub sticks out another 0.250", and that's what the roller bearing sleeve mounts in. The converter hub inside is 0.650" deep, and the roller pilot bearing sleeve is 0.560" thick, so you COULD press the sleeve in to the crank deeper than flush, but that's not useful to you or me.
I need to start mocking things up to see what's real, but *I THINK* that with the Mopar roller pilot bearing sleeve flush with the converter hub, there will be SOME engagement of the Toyota pilot shaft in to the pilot bearing sleeve. HOW MUCH, I'm not sure, as I put my spreadsheet together several months ago, and I need to rethink how I set up the formulas to make sure they make sense. If you can put an AX-15 bellhousing on a block, you can get some measurements to verify that depth, and then can compare them to the crankshaft measurements I have above, as I think those are good. Then it should be simple to see how well - or poorly - the input fits a stock roller bearing sleeve. Some simple machine work can make a bronze bushing, or a Toyota bushing/bearing might be made to work.
I'll try to get some more numbers tonight, I just made some space around my 318 mock-up block this weekend. Oh, and welcome to America! I hope you can find some good beer!
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32960
09/11/07 11:23 PM
09/11/07 11:23 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
To make note of the edits for improved data in RED above...
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32961
09/12/07 06:37 PM
09/12/07 06:37 PM
Germany, Northcoast
Germany, Northcoast
Hi Clair, this is what you wrote before. Now the Speedshop here gave advanced adapter a call and they told him that they never made something for especially a Toyota Turbo Supra. Is it possible that Toyota shares the splines with an other domestic Tranny for that you asked for? We have a problem with ordering than when we don't know exactly what iit is...
Clutch - Advance Adapters makes a conversion clutch for the Toyota spline in a 10.5" diameter. It's not the most heavy-duty piece, but it's built for off-roading, so it's no slouch, and at $120, it's by far the cheapest option I've seen. Clair
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32962
09/12/07 06:41 PM
09/12/07 06:41 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You might check with Castlemain Rod Shop that is where I got my conversion bellhousing and assorted bits from
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32963
09/12/07 09:22 PM
09/12/07 09:22 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Here's the clutch disk on Summit Racing's web site. Says available Sept. 22, so you may want to try to get it from some other source, or directly from AA. I doubt that they specified Supra, but the spline count and shaft DIA are common in Toyotas. Best bet might be trying one of the offroad shops, as Toyota trucks get engine swaps very frequently for more power, but the drivetrains are usually left intact.
Here's a google search for PN 716105
And here it is on AA's own web site, for only a few pennies more than Summit.
Hopefully someone will have one for you. And me, too...
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32964
09/12/07 11:17 PM
09/12/07 11:17 PM
Columbia, Missouri
dtedler Offline
dtedler  Offline
Columbia, Missouri
Clair
please send me another e-mail. I have a drawing that you can use to figure out your application depths with. By the way, I would look at a roller pilot bearing because of the small diameter of the input pilot. Let me know if I can be of any help.
Tony Edler
Classic Mopar 5 Speed
tony@cms-grp.com
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32965
09/20/07 07:12 PM
09/20/07 07:12 PM
Germany, Northcoast
Germany, Northcoast
Thx Clair,
got it. Have it in my hands right now. 140,- bucks net.
Re: 340sb with 5 speed conversion? [Re: dtedler] #32966
09/20/07 10:47 PM
09/20/07 10:47 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Tony,
I'm not sure what kind of bearing/bushing the Toyota uses, but I'll contact you to bounce some ideas off of you when I get a little more info in hand. I'd like to see the drawing you have, as I'm always happy to benefit from someone else's hard work...
Buschi, are you back across the pond? I hope you had a good visit, and were able to sort out some of your swap issues while you were here. Looks like I'm going to start gearing up for some progress here, too, although baby steps at first. Got my engine dolly modified so I could mount the trans to the rear of it and mock up some parts for real. This will be good.
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32967
10/18/07 01:41 PM
10/18/07 01:41 PM
Germany, Northcoast
Germany, Northcoast
Clair,
had a great stay! Looking forward to the next trip, hopfully next year....
How do you think to mount the odometer, speedometer?
I forgot to buy the bearing/bushings for the pilot and pressure plate... me dummy!
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32968
01/12/08 05:09 PM
01/12/08 05:09 PM
Germany, Northcoast
Germany, Northcoast
Hi Clair,
I hope you had a great !
Any news on your swap? I'm starting these days practically.
The speedo cable connection question is still unclear. And new is how do think to mount the tranny. What kinda transmission mount?
I just received a stock 4speed pedal setup from a 70 Dart. Now I'm thinking about how to connect the clutch master cylinder (system from the Dakota) to the pedal I have...
Looking forward to hear from you soon....
Michael
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32969
01/12/08 11:51 PM
01/12/08 11:51 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Hey, Michael,
Sorry for not getting back to you on this earlier - it's been busy around here for the last few months! I think there's a speedo port on the trans, and somewhere I've seen an adapter for the Toyota trans to a more common speedo cable. I'm not on my normal computer, so I can't check my favorites to find the link right now. I'll see what I can find and post back, but I'm pretty sure there's a way to use the mechanical speedo with this trans. I've been concentrating on the electronic speedo for my swap, but I've seen both.
Not much progress on my end, but I have been experimenting with a different bellhousing setup. Need to find the proper starter motor to see if it fits the 10.5" clutch I have as an option.
Hope all's well over there, and I'll post what I find.
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32970
01/13/08 11:19 PM
01/13/08 11:19 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
OK, here's what I'm finding on the speedo cable situation... going back again to the catalog at Castlemain Rod Shop, they show a cable that SHOULD adapt to a late Mopar clip-on like yours (SC2), or an early screw-on unit (SC1). The SC1 SHOULD also work on aftermarket speedos like Auto Meter as well. I don't think I want to order one from Australia, as there MUST be SOME local shop that can build a cable for me/us.
Another source (more local to me, at least) is Jags That Run / Stealth Conversions. They have a couple options for speedo adapters and Vehicle Speed Sensors. Might be worth a call/email to see if they can source a cable, too, but it might not make a difference if their adapter will let you hook your cable up directly.
Hope this helps...
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32971
01/31/08 09:45 PM
01/31/08 09:45 PM
Spokane, WA
48Heap Offline
48Heap  Offline
Spokane, WA
Hey Clair, if memory serves, you were concerned about the length of the Toyota yoke. Correct?
Reason I ask is Greg posted a clip from some other forum with an aftermarket yoke part number on slantsix.org, so I've been doing some research. Part number doesn't match with anything but I did track something down to a manufacturer in Australia (Hardy Spicer).
Long story short, it doesn't appear that the spline engagement is much shorter than a Turbo 400 yoke (per the manufacture’s info) at 4.530" vs. 4.685".
Part # posted was 3-3-3558. Best I can tell, the part # should have been 21R-3-3558, but that is for a 23 spline yoke and the R154 has a 21 spline output shaft. They show two part #'s (2R-3-3188 and 21R-3-3208) for Toyota 5 speeds with 21 splines. In theory (per the forum clip) one of these would allow a larger 1350 u-joint, but the numbers I found for the 21R stuff shows a u-joint cap diameter of 1.078" which is much smaller than 1350 u-joint cap. The 2R stuff was even smaller at 1".
Just some more info, thought I would share.
a.k.a. DionR
Re: 340sb with 5 speed conversion? [Re: 48Heap] #32972
01/31/08 10:48 PM
01/31/08 10:48 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I was concerned, but I think I've about come to the conclusion that the Toyota yoke will probably be OK. The 'Yota yoke is splined for it's whole length, and that turns out to be almost the same as the splined portion of a 904 yoke, too. I need to research those goodies, though, because I'd rather be SURE a part is right than just hope... At least at this stage of the game...
Clair
