which rearend #329083
05/26/09 12:36 PM
05/26/09 12:36 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
I just relocated the perches on my 8 1/4 rear in my 84 shortbed too lower it a little.Was wanderin of the life expectancy of this rear with a 440 and auto?The motor is stock as a rock from an 1972 motorhome.Should i line out something else? will an 8 3/4 work out for me better?
Re: which rearend [Re: bigblock4x4] #329084
05/26/09 02:06 PM
05/26/09 02:06 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I think it'll be fine with a stock 440. What's the engine putting out, 225 hp and maybe 250-275 ft/lbs of torque?
If it's in good shape (i.e there's no excessive backlash or wear), it'd stick with it.
Re: which rearend [Re: In_The_Pink] #329085
05/26/09 02:46 PM
05/26/09 02:46 PM
scratchnfotraction Offline
it will hold for a while
what did you do to the perch to get it lowerd?
did you move the shackle perch?
I did a flip flop on mine and run an A-body 8 3/4 on top of the springs with 12" rims and 29x15x15M/Ts in my 85
did you just flop the axle on top of the springs and slam it?
Re: which rearend [Re: scratchnfotraction] #329086
05/27/09 01:51 PM
05/27/09 01:51 PM
pana illinois
pana illinois
I relocated the spring perches,It looks awesome.Can't wait too flog all over it.
Re: which rearend [Re: bigblock4x4] #329087
05/27/09 02:39 PM
05/27/09 02:39 PM
got a pic
of the relocation?
I used a front spring hanger and flip the shackle then mounted the A-body 8 3/4 axle on top of the springs to lower it
I would like to see some other ways that it has been done, for future projects
lets see the truck
